Jim Weir wrote
Two years of college chemistry does not a chemist make out of me You're not asking a chemistry question, you're asking a chemical engineering question. Not the same thing at all. Anyway, I happen to be one. is there a cheap and easy way to chemically (or mechanically) take the alcohol out of gasoline? Yes. Extraction. Mix gasoline with equal quantity of water, agitate (shake or stir), let sit in cool place. The alcohol will (almost) all be in the water phase on the bottom. Drain water off bottom. Gasoline is ready to use. Your problem is the water. It now has a few percent alcohol, and traces of organics from the gasoline. Can't just toss it (legally). You need to flash off the alcohol and organics. Fill jug with the water, stopper it but let a tube come out. Warm to 180F, give or take. This will drive off some gases, which you can feed into a small flame (a candle will do). When the water level goes down a few percent, you're good. You can reuse that water for the next batch. Michael |
On Mon, 16 Aug 2004 16:38:20 GMT, Roger Halstead
wrote: Which brings to mind the question: How does anyone in Michigan use a Mogas STC? Our gas is not labeled as to whether it contains Alcohol or not. The pump sticker only states, "Meets Michigan fuel standard (something or other) call this 800 number for specifics or complaints", or something to that effect. We have the same problem here in Alaska, since our fuel doesn't meet whatever ASTM specification the mogas STCs require. ================================================== == Del Rawlins-- Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ Remove _kills_spammers_ to reply |
