In article , Mike H
writes: No, no, no.... You DON'T want to try to repair that ADF. We went that route for close to two years in our Archer, trying to repair the Narco ADF and Navs/Coms. We just threw good money after bad. We probably ended up sinking $2000 over a 2 year period before finally giving in and going for a Garmin 430 and new King Nav/Com. It cost a pretty penny (about $12000) but sure is nice now! I agree that you don't repair the ADF. I have the 430 installed (with a 330 transponder for TIS) in my 79Archer but a used Garmin 195 is a pretty good inexpensive solution for VFR. Chuck |
![]() "C Kingsbury" wrote in message om... Googling the group yielded little so here goes... 1979 172, overall average condition with mostly original radios and wiring (one RT-385 recently replaced by a TKM radio, M1 Loran from a few centuries ago) The Cessna 300 ADF has gone flaky. The box tests fine on the bench which suggests a wild goose chase may be in store to find the gremlins. One of the two ILS approaches at my home field require ADF, and a few fields I go to are ADF/GPS-only so I need one of the two. My idea is to find a good used Apollo GX-50/GX-60 unit and replace the ADF. No need to touch the Loran, it makes a good backup. I'll get legal ADF and DME capability not to mention a moving map. Trying to convince 4 other partners this is a good idea b/c it will make it easier to sell shares in the future and even if they are VFR-only the moving map is a big plus. [snip] If I remember correctly, you can use a GPS as a substitute for ADF for darn near everything except an actual ADF approach. You can navigate to/from the "ADF", hold at it, use it to define a marker/compass locator. Many NDB approaches have some sort of GPS overlay, but I've seen a few around here that didn't. Somebody correct me if I'm wrong (i was wrong last year, i guess i'm due again...) |
ADF. No need to touch the Loran, it makes a good backup. I have a GX 60 NO 1, Gx65 NO 2, Radar Altimeter, Annunciator, Glideslope, but the main and most used GPS was and is a 195, 295, 196, 296 in that order of purchace. Outside of the comm the portables have a lot more features. Look at these closely before you buy a GX 60 or 430. |
If you are budget conscious, it may make more sense to find the best deal
you can on an acceptable IFR GPS. King, Garmin, Apollo whatever works. Just make sure that its worth the price of installing the thing. No point installing something worthless. Talk to the different avionics shops until someone with a lot more money trades in a reasonably new unit on the latest thing. Then grab it. "C Kingsbury" wrote in message om... Googling the group yielded little so here goes... 1979 172, overall average condition with mostly original radios and wiring (one RT-385 recently replaced by a TKM radio, M1 Loran from a few centuries ago) The Cessna 300 ADF has gone flaky. The box tests fine on the bench which suggests a wild goose chase may be in store to find the gremlins. One of the two ILS approaches at my home field require ADF, and a few fields I go to are ADF/GPS-only so I need one of the two. My idea is to find a good used Apollo GX-50/GX-60 unit and replace the ADF. No need to touch the Loran, it makes a good backup. I'll get legal ADF and DME capability not to mention a moving map. Trying to convince 4 other partners this is a good idea b/c it will make it easier to sell shares in the future and even if they are VFR-only the moving map is a big plus. The local flight school says they've been spending an average of $6000 to do this with their birds at the local shop. Those of you who've done this recently, any thoughts? Bet, -cwk. |
Also recall that $6000 is about 15% of the value of a basic IFR 172. If
you are going to even bother, try finding a used Garmin 430. Installation and database update cost is going to be the same in either case, but the Garmin software can be updated ad nauseum... not so with the GX series. |
Whether or not the Apollo units are a good idea or not is not something I
will address. Don't forget that they are essentially "orphaned" units. Also, to be legal, there may be instances where you need to have the ADF equipment on board. I thought that an IFR GPS was a legal substitute for an ADF in ALL cases???? |
Dude wrote:
Whether or not the Apollo units are a good idea or not is not something I will address. Don't forget that they are essentially "orphaned" units. Also, to be legal, there may be instances where you need to have the ADF equipment on board. I thought that an IFR GPS was a legal substitute for an ADF in ALL cases???? An IFR GPS *with a current database* is a leagal substitue for an ADF. (Currently in MI with a current Garmin West/Central DB. Guess where the West/Central DB ends. ) -- Frank Stutzman Bonanza N494B "Hula Girl" Hood River, OR |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
