What is the TT on the engine, and what is the SMOH on the engine? If
either are high, you may be in for a total rebuild. ONE cylinder with 62 would concern me. If it's near TBO, you're probably in for a rebuild. Typically as an engine ages, compression goes down and oil usage goes up. Also check to see if the last rebuild included crankshaft bearings, was it a total rebuild or just a top? Look for oil in the front of the engine, this is evidence of main bearings going out. A recently rebuilt engine can have cylinder replacements be successful, but a good engine shouldn't need them. Like I said, if it's near TBO, you're probably in for a rebuild, and if the last rebuild wasn't a major, your probably going to have to major it. Its not worth it to top a high time engine, IMO. You haven't made a deal yet, so you can do whatever you want at this point. Nothing wrong with buying knowing it will need a rebuild so long as the buy price reflects this. You might get lucky and get 500 more hours, doing nothing. If the compressions were all good, and no oil usage, you usually can count on 500 more hours, REGARDLESS of the time on the engine. Usually, not always. And nothing unusual about running it past TBO. These Lycomings typically will run well past TBO. Jon Kraus wrote in message . .. My new partner and I are looking at a 1975 Mooney M20C. It is a nicely upgraded IFR plane with a 400 hour O-360 engine. It is a rather high time airplane (7000) hours and the price reflects this fact. It is being sold by the owner of the FBO we fly out of for one of his friends. They just finished up an annual inspection on it. My IFR instructor has owned Mooneys in the past and even had the M20C for years. He suggested that we fly the plane to Byerly Aviation in Peoria IL (a little over an hour flight from Indianapolis) and have them do the pre-buy. He said it would probably cost in the $500.00 range. My partner and I think it is a good idea too. We are both buying our first plane and think the money would be well spent. One of the cylinders has a compression of 62 while the others are in the 70's. This concerns me even though it is within tolerances. Of course we would hate to buy something that needed immediate major engine work. The plane has not flown much for the past 2 years so I am wondering if after flying the thing a while if the compression might come back some (probably wishful thinking I know). I am interested in opinions or experiences in first plane purchases. Experience with Byerly Aviation. Or comments on the engine situation I described. Thanks!! Jon Kraus PP-ASEL-IA Student aircraft purchaser |
Doug - Thanks for your remarks. The engine has 420 hours SMOH which
included a new camshaft, new bearings ect. I'm wondering if the main issue (with the low compression) is that the 420 hours has been over 6 years (and the last year it hardly flew at all). IMHO the plane has not been flown enough. Like I said I'm an no expert but wouldn't you think that 70 hours a year is a little light on usage? Could this be the cause of the low compression on the cylinder? Maybe and mabe not. I have a mechanical background but it has been years since I turned a wrench but if I remember about compression checks the procedure was to take a reading and if it was low then you squirt oil into the low cylinder (wet compression check)and if the reading came up then the rings were either worn or sticking. This is because the oil would temporarily seal the rings but do nothing to seal up the valves. If the reading stayed the same then you would suspect a valve problem. Please don't flame me too bad on this because it has ben a while since I've done any engine work. Although I suspect I'll be doing some owner assisted things with whatever plane I end up. :-) Jon Kraus PP-ASEL-IA Student airplane purchaser Doug wrote: What is the TT on the engine, and what is the SMOH on the engine? If either are high, you may be in for a total rebuild. ONE cylinder with 62 would concern me. If it's near TBO, you're probably in for a rebuild. Typically as an engine ages, compression goes down and oil usage goes up. Also check to see if the last rebuild included crankshaft bearings, was it a total rebuild or just a top? Look for oil in the front of the engine, this is evidence of main bearings going out. A recently rebuilt engine can have cylinder replacements be successful, but a good engine shouldn't need them. Like I said, if it's near TBO, you're probably in for a rebuild, and if the last rebuild wasn't a major, your probably going to have to major it. Its not worth it to top a high time engine, IMO. You haven't made a deal yet, so you can do whatever you want at this point. Nothing wrong with buying knowing it will need a rebuild so long as the buy price reflects this. You might get lucky and get 500 more hours, doing nothing. If the compressions were all good, and no oil usage, you usually can count on 500 more hours, REGARDLESS of the time on the engine. Usually, not always. And nothing unusual about running it past TBO. These Lycomings typically will run well past TBO. Jon Kraus wrote in message . .. My new partner and I are looking at a 1975 Mooney M20C. It is a nicely upgraded IFR plane with a 400 hour O-360 engine. It is a rather high time airplane (7000) hours and the price reflects this fact. It is being sold by the owner of the FBO we fly out of for one of his friends. They just finished up an annual inspection on it. My IFR instructor has owned Mooneys in the past and even had the M20C for years. He suggested that we fly the plane to Byerly Aviation in Peoria IL (a little over an hour flight from Indianapolis) and have them do the pre-buy. He said it would probably cost in the $500.00 range. My partner and I think it is a good idea too. We are both buying our first plane and think the money would be well spent. One of the cylinders has a compression of 62 while the others are in the 70's. This concerns me even though it is within tolerances. Of course we would hate to buy something that needed immediate major engine work. The plane has not flown much for the past 2 years so I am wondering if after flying the thing a while if the compression might come back some (probably wishful thinking I know). I am interested in opinions or experiences in first plane purchases. Experience with Byerly Aviation. Or comments on the engine situation I described. Thanks!! Jon Kraus PP-ASEL-IA Student aircraft purchaser |
The oil-in-the-cylinder thing is for the "automotive" type compression
test. There is another way to tell with the "leak down" type test given to aircraft. A mechanic should be able to tell you if its valves or rings. They can "hear" it leak with the leakdown test. What frequently goes on these Lycomings is the camshaft, which will be valve related on the compression, and that is a major overhaul (tear the engine apart). If you pull a cylinder, have the mic the cam. Engine life is always a bit of a gamble. Does it do book speeds and climb at book rates? Performance is also a good measure, but HARD to measure accurately. Is fuel consumption normal for the speeds being flown? That is probably the easiest way to tell. Use a GPS for you speeds and compensate for the wind and altitude to get IAS, as that is most accurate. Airspeed indicators are not always accurate. If you buy an Mooney, or any airplane like it, you need to be able to spring for an engine rebuild at any random moment in time. But these engines can run a long time without needing a rebuild. It partly depends on you, and how safe you feel with a questionable situation. I have a similar Lycoming 0360 in my Aviat Husky, and its 2200 on the tach. Still going strong. No compression problems or oil usage. But it is 2200 SNEW and has immaculate care. Jon Kraus wrote in message .. . Doug - Thanks for your remarks. The engine has 420 hours SMOH which included a new camshaft, new bearings ect. I'm wondering if the main issue (with the low compression) is that the 420 hours has been over 6 years (and the last year it hardly flew at all). IMHO the plane has not been flown enough. Like I said I'm an no expert but wouldn't you think that 70 hours a year is a little light on usage? Could this be the cause of the low compression on the cylinder? Maybe and mabe not. I have a mechanical background but it has been years since I turned a wrench but if I remember about compression checks the procedure was to take a reading and if it was low then you squirt oil into the low cylinder (wet compression check)and if the reading came up then the rings were either worn or sticking. This is because the oil would temporarily seal the rings but do nothing to seal up the valves. If the reading stayed the same then you would suspect a valve problem. Please don't flame me too bad on this because it has ben a while since I've done any engine work. Although I suspect I'll be doing some owner assisted things with whatever plane I end up. :-) Jon Kraus PP-ASEL-IA Student airplane purchaser Doug wrote: What is the TT on the engine, and what is the SMOH on the engine? If either are high, you may be in for a total rebuild. ONE cylinder with 62 would concern me. If it's near TBO, you're probably in for a rebuild. Typically as an engine ages, compression goes down and oil usage goes up. Also check to see if the last rebuild included crankshaft bearings, was it a total rebuild or just a top? Look for oil in the front of the engine, this is evidence of main bearings going out. A recently rebuilt engine can have cylinder replacements be successful, but a good engine shouldn't need them. Like I said, if it's near TBO, you're probably in for a rebuild, and if the last rebuild wasn't a major, your probably going to have to major it. Its not worth it to top a high time engine, IMO. You haven't made a deal yet, so you can do whatever you want at this point. Nothing wrong with buying knowing it will need a rebuild so long as the buy price reflects this. You might get lucky and get 500 more hours, doing nothing. If the compressions were all good, and no oil usage, you usually can count on 500 more hours, REGARDLESS of the time on the engine. Usually, not always. And nothing unusual about running it past TBO. These Lycomings typically will run well past TBO. Jon Kraus wrote in message . .. My new partner and I are looking at a 1975 Mooney M20C. It is a nicely upgraded IFR plane with a 400 hour O-360 engine. It is a rather high time airplane (7000) hours and the price reflects this fact. It is being sold by the owner of the FBO we fly out of for one of his friends. They just finished up an annual inspection on it. My IFR instructor has owned Mooneys in the past and even had the M20C for years. He suggested that we fly the plane to Byerly Aviation in Peoria IL (a little over an hour flight from Indianapolis) and have them do the pre-buy. He said it would probably cost in the $500.00 range. My partner and I think it is a good idea too. We are both buying our first plane and think the money would be well spent. One of the cylinders has a compression of 62 while the others are in the 70's. This concerns me even though it is within tolerances. Of course we would hate to buy something that needed immediate major engine work. The plane has not flown much for the past 2 years so I am wondering if after flying the thing a while if the compression might come back some (probably wishful thinking I know). I am interested in opinions or experiences in first plane purchases. Experience with Byerly Aviation. Or comments on the engine situation I described. Thanks!! Jon Kraus PP-ASEL-IA Student aircraft purchaser |
Jon Kraus wrote:
My new partner and I are looking at a 1975 Mooney M20C. Hi John, Sorry, I'm a little late to this party, and this is not in direct answer to your specific question, but be sure you have looked at the Mooney prepurchase inspection article in the MAPA Log. Surf over to http://www.mooneypilots.com and click on the link "prepurchase inspections" under "MAPA Log Sample Articles". Dave |
Thanks Dave. They have some good stuff there !! JK
Dave Butler wrote: Jon Kraus wrote: My new partner and I are looking at a 1975 Mooney M20C. Hi John, Sorry, I'm a little late to this party, and this is not in direct answer to your specific question, but be sure you have looked at the Mooney prepurchase inspection article in the MAPA Log. Surf over to http://www.mooneypilots.com and click on the link "prepurchase inspections" under "MAPA Log Sample Articles". Dave |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Home Inspection Listings | Patrick Glenn | Home Built | 4 | April 26th 04 11:52 AM |
Service Manual - 50 hour inspection | O. Sami Saydjari | Owning | 1 | April 8th 04 03:17 PM |
51st Fighter Wing betters rating to ‘excellent’ with inspection | Otis Willie | Military Aviation | 0 | February 20th 04 11:29 PM |
100 Hour Inspection Question | FryGuy | General Aviation | 59 | November 19th 03 04:01 AM |
