http://www.aso.com/i.aso/AircraftVie...craft_id=84399
I flew this yesterday and it was nice (but what the hell do I know) He is asking 105k but Vref says it is worth $113k. That seemed high but again what do I know. Any Mooney owners out there want to give an opinion on the M20J? Thanks in advance. Jon Kraus PP-ASEL-IA Student airplane purchaser |
"Jon Kraus" wrote in message
... http://www.aso.com/i.aso/AircraftVie...craft_id=84399 I flew this yesterday and it was nice (but what the hell do I know) He is asking 105k but Vref says it is worth $113k. That seemed high but again what do I know. Any Mooney owners out there want to give an opinion on the M20J? Thanks in advance. If you're in the market for a fast, fuel-efficient single-engined tourer, there are 4 reasons not to buy a Mooney: 1) It doesn't haul as much payload over short ranges as some comparable tourers. On ours, one the IFR equipment was on board, it was 480 lb with full fuel, which means 670 lb with half fuel. Of course half-fuel still keeps you in the air for 3 hours at 160 KTAS. By the time you get to longer range missions, it matters less because the others have to carry more weight in fuel. If most of your missions are two up, no problem. 2) It doesn't like rough surfaces. In my part of the world there are a much greater proportion of grass runways than in the US. I've landed on grass, it's OK, but I'd be very reluctant to base a Mooney at a grass field as I'd be worried about the prop the whole time. If you don't intend to operate on grass, it's not an issue. 3) Its landing distance is greater than many compatible tourers: because the airframe is clean, it floats. So for short fields it tends to be the landing distance that is limiting. I wouldn't want to operate a M20J regularly out of much less than 2700 ft as you don't have much safety margin at less than that. If you have that and don't visit short strips very often, no problem. 4) Its crosswind performance is ugly, particularly for take-offs. The undercarriage uses rubber disks for its springs, and the wing is very low to the ground. Hence any bumps and you lose any side force from the wheels, and you have a lot of lift relatively early in the take-off roll. If you operate an M20J from a single runway airport in a windy part of the world, this may be an issue. If you only rarely have to deal with 20 knot crosswinds, no problem. If none of those things bother you, just buy the aircraft and spend 12 years, like me, enjoying 160 knots on 10 gallons per hour and trying to figure out why anyone would buy anything else. :-) Julian Scarfe |
Great post !! Thanks!!
Jon Julian Scarfe wrote: "Jon Kraus" wrote in message ... http://www.aso.com/i.aso/AircraftVie...craft_id=84399 I flew this yesterday and it was nice (but what the hell do I know) He is asking 105k but Vref says it is worth $113k. That seemed high but again what do I know. Any Mooney owners out there want to give an opinion on the M20J? Thanks in advance. If you're in the market for a fast, fuel-efficient single-engined tourer, there are 4 reasons not to buy a Mooney: 1) It doesn't haul as much payload over short ranges as some comparable tourers. On ours, one the IFR equipment was on board, it was 480 lb with full fuel, which means 670 lb with half fuel. Of course half-fuel still keeps you in the air for 3 hours at 160 KTAS. By the time you get to longer range missions, it matters less because the others have to carry more weight in fuel. If most of your missions are two up, no problem. 2) It doesn't like rough surfaces. In my part of the world there are a much greater proportion of grass runways than in the US. I've landed on grass, it's OK, but I'd be very reluctant to base a Mooney at a grass field as I'd be worried about the prop the whole time. If you don't intend to operate on grass, it's not an issue. 3) Its landing distance is greater than many compatible tourers: because the airframe is clean, it floats. So for short fields it tends to be the landing distance that is limiting. I wouldn't want to operate a M20J regularly out of much less than 2700 ft as you don't have much safety margin at less than that. If you have that and don't visit short strips very often, no problem. 4) Its crosswind performance is ugly, particularly for take-offs. The undercarriage uses rubber disks for its springs, and the wing is very low to the ground. Hence any bumps and you lose any side force from the wheels, and you have a lot of lift relatively early in the take-off roll. If you operate an M20J from a single runway airport in a windy part of the world, this may be an issue. If you only rarely have to deal with 20 knot crosswinds, no problem. If none of those things bother you, just buy the aircraft and spend 12 years, like me, enjoying 160 knots on 10 gallons per hour and trying to figure out why anyone would buy anything else. :-) Julian Scarfe |
is asking 105k but Vref says it is worth $113k. That seemed high but again what do I know. Any Mooney owners out there want to give an opinion on the M20J? You've looked at two Mooneys now. If you are serious about getting one, you really must join the Mooney list. You'll get more good information there than anywhere else: http://www.aviating.com/mooney/subscribe.html At minimum, read Bob Kromer's flight test reports on the various Mooney models: http://www.mooneypilots.com/flight_test_reports.html The 'J' will have newer avionics than the 'C' you looked at previously, it also cruises faster and burns more fuel. Plan on 10-15 kts difference in cruise speed between the 'C' and 'J', one gallon per hour more in fuel burn in the 'J' and 50% or more in operating costs, considering both fixed and variable costs. Of course the purchase price of a 'J' is twice what a 'C' is. Personally, I chose to buy 100% of a 'C' model Mooney rather than 50% of a 'J'. You're looking at the same money up front and ongoing expenses either way. --- Ken Reed http://www.dentalzzz.com |
Ken,
I jsut subscribed to the Mooney list. Guess there is no turning back now... :-) Thanks. Jon Kraus PP-ASEL Student airplane owner Ken Reed wrote: I flew this yesterday and it was nice (but what the hell do I know) He is asking 105k but Vref says it is worth $113k. That seemed high but again what do I know. Any Mooney owners out there want to give an opinion on the M20J? You've looked at two Mooneys now. If you are serious about getting one, you really must join the Mooney list. You'll get more good information there than anywhere else: http://www.aviating.com/mooney/subscribe.html At minimum, read Bob Kromer's flight test reports on the various Mooney models: http://www.mooneypilots.com/flight_test_reports.html The 'J' will have newer avionics than the 'C' you looked at previously, it also cruises faster and burns more fuel. Plan on 10-15 kts difference in cruise speed between the 'C' and 'J', one gallon per hour more in fuel burn in the 'J' and 50% or more in operating costs, considering both fixed and variable costs. Of course the purchase price of a 'J' is twice what a 'C' is. Personally, I chose to buy 100% of a 'C' model Mooney rather than 50% of a 'J'. You're looking at the same money up front and ongoing expenses either way. --- Ken Reed http://www.dentalzzz.com |
Julian,
but I'd be very reluctant to base a Mooney at a grass field as I'd be worried about the prop the whole time. And the gear doors. -- Thomas Borchert (EDDH) |
be worried about the prop the whole time. "Thomas Borchert" wrote in message ... And the gear doors. Yeah but gear doors are cheaper... :-) I've bent both :-( Julian |
Ken,
I just subscribed to the Mooney list. Guess there is no turning back now... :-) Thanks. Jon Kraus PP-ASEL Student airplane owner Ken Reed wrote: I flew this yesterday and it was nice (but what the hell do I know) He is asking 105k but Vref says it is worth $113k. That seemed high but again what do I know. Any Mooney owners out there want to give an opinion on the M20J? You've looked at two Mooneys now. If you are serious about getting one, you really must join the Mooney list. You'll get more good information there than anywhere else: http://www.aviating.com/mooney/subscribe.html At minimum, read Bob Kromer's flight test reports on the various Mooney models: http://www.mooneypilots.com/flight_test_reports.html The 'J' will have newer avionics than the 'C' you looked at previously, it also cruises faster and burns more fuel. Plan on 10-15 kts difference in cruise speed between the 'C' and 'J', one gallon per hour more in fuel burn in the 'J' and 50% or more in operating costs, considering both fixed and variable costs. Of course the purchase price of a 'J' is twice what a 'C' is. Personally, I chose to buy 100% of a 'C' model Mooney rather than 50% of a 'J'. You're looking at the same money up front and ongoing expenses either way. --- Ken Reed http://www.dentalzzz.com |
On Sun, 05 Sep 2004 17:17:07 GMT, "Julian Scarfe"
wrote: Julian, I'll take issue with you on items 3 and 4. 3) Its landing distance is greater than many compatible tourers: because the airframe is clean, it floats. So for short fields it tends to be the landing distance that is limiting. I wouldn't want to operate a M20J regularly out of much less than 2700 ft as you don't have much safety margin at less than that. If you have that and don't visit short strips very often, no problem. Usually, the only reason it floats is because folk come in at well over 1.3Vso. I would have no hesitation about being based at a 2,000' strip (at sea level). Going into KBGR regularly, I rarely have a problem turning off at the first taxiway (1100') and I'm usually off the ground from my home base in about 1000', without using short-field technique. 4) Its crosswind performance is ugly, particularly for take-offs. The undercarriage uses rubber disks for its springs, and the wing is very low to the ground. Hence any bumps and you lose any side force from the wheels, and you have a lot of lift relatively early in the take-off roll. If you operate an M20J from a single runway airport in a windy part of the world, this may be an issue. If you only rarely have to deal with 20 knot crosswinds, no problem. Again, I think this is a technique issue, both on takeoff and landing. I do agree with you about rough field operation. There just isn't the clearance that other a/c have. --ron |
Ron Rosenfeld wrote: I do agree with you about rough field operation. There just isn't the clearance that other a/c have. And beware those who say the 3-bladed prop has more clearance -- it's the same diameter. -- Ben Jackson http://www.ben.com/ |
Any opinions on the Garmin GNS 480 ! ! ! | RonLee | Instrument Flight Rules | 18 | January 18th 05 12:33 PM |
Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 09:08 PM |
Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 04:15 AM |
OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 10:43 PM |
Rallye/Koliber AD's and opinions | R. Wubben | Owning | 2 | October 16th 03 05:39 AM |
