Opinions on a M20J
Old September 5th 04, 08:15 PM
Ron Rosenfeld
On Sun, 05 Sep 2004 17:17:07 GMT, "Julian Scarfe"
Julian,
I'll take issue with you on items 3 and 4.
3) Its landing distance is greater than many compatible tourers: because the
airframe is clean, it floats. So for short fields it tends to be the
landing distance that is limiting. I wouldn't want to operate a M20J
regularly out of much less than 2700 ft as you don't have much safety margin
at less than that. If you have that and don't visit short strips very
often, no problem.
Usually, the only reason it floats is because folk come in at well over
1.3Vso. I would have no hesitation about being based at a 2,000' strip (at
sea level). Going into KBGR regularly, I rarely have a problem turning off
at the first taxiway (1100') and I'm usually off the ground from my home
base in about 1000', without using short-field technique.
4) Its crosswind performance is ugly, particularly for take-offs. The
undercarriage uses rubber disks for its springs, and the wing is very low to
the ground. Hence any bumps and you lose any side force from the wheels,
and you have a lot of lift relatively early in the take-off roll. If you
operate an M20J from a single runway airport in a windy part of the world,
this may be an issue. If you only rarely have to deal with 20 knot
crosswinds, no problem.
Again, I think this is a technique issue, both on takeoff and landing.
I do agree with you about rough field operation. There just isn't the
clearance that other a/c have.
--ron
Any opinions on the Garmin GNS 480 ! ! ! RonLee Instrument Flight Rules 18 January 18th 05 12:33 PM
Opinions on Cessna 340, 414 and 421 john szpara Owning 55 April 2nd 04 09:08 PM
Opinions wanted ArtKramr Military Aviation 65 January 21st 04 04:15 AM
OPINIONS: THE SOLUTION ArtKramr Military Aviation 4 January 7th 04 10:43 PM
Rallye/Koliber AD's and opinions R. Wubben Owning 2 October 16th 03 05:39 AM
