C Kingsbury wrote:
: Yes, based at BED, tower ramp. You mght want to check with Ernie Carrol at Integrity Air Services over at WST. (401-348-0018). He's very good, and very reasonable. He's also very busy because of that! Ask him what he recommends. He's the shop that did my install. PS, my GPS was interfaced with my autopilot as well for that price I mentioned before. PPS, if you'd like to see my GPS install drop me a line and we'll work something out - I'm based at 1B9. -- Aaron Coolidge |
![]() "C Kingsbury" wrote in message ink.net... I would like a decent moving-map capability, but given that we have none in the plane right now, even a simple airspace depiction like the KLN-89B would be a significant gain. If we want something snazzy we can get it better on a handheld anyway. I would spend an extra $500 for a better map, but $1000 or $1500 I'd wonder about. What would you guys do? I'd stay away from Northstar and the King 89B, but go with the Garmin/Apollo or the King 90. |
What is wrong with the 89/B? I had the same problem that Colin is
writing about. I have a '65 C-172 and it came with a VFR GPS. It had an non functioning ADF and no DME. Rather that sink money into that I purchased a reconditioned 89/B. It is not a 430, but it works pretty nice once you get to know it beyond Direct To. Yes, you need to have additional equipment installed, but no big deal. I think I got away less that $4500 complete. I get updates quite painless with the King Dataloader. I would like to remove the card to reprogram, but I have to take the laptop to the plane. I am done in about 15 minutes and I get to see the plane. You can get a set up to take the 89/B to the computer, but I didn't like the idea of continually removing the GPS. Ross "Tom S." wrote: "C Kingsbury" wrote in message ink.net... I would like a decent moving-map capability, but given that we have none in the plane right now, even a simple airspace depiction like the KLN-89B would be a significant gain. If we want something snazzy we can get it better on a handheld anyway. I would spend an extra $500 for a better map, but $1000 or $1500 I'd wonder about. What would you guys do? I'd stay away from Northstar and the King 89B, but go with the Garmin/Apollo or the King 90. |
There is nothing, operational, that you can do with one IFR GPS that
you can't with any of the other units (so long as it's approach unit). Well, the Vnav units are the exception. I have a King KLN90B, and it's advantage over the 89 is it has a better display. More readable as it is brighter. Personally, I would get one of the King units, but any of them would work. Look into cost of updates and ease of update. "C Kingsbury" wrote in message link.net... Hi all, Currently examining options for upgrading a 1979 172N with an IFR-certified GPS. We currently have two good nav/coms, M-1 Loran, and ADF that we want to replace. Goal is to find the most cost-efficient IFR GPS install to replace the ADF and add legal /G and DME capabilities. Keeping in mind that the plane is worth maybe 50k we are not going to spend 10-12k on a GNS-430 class box, so as I see it we have these options: - Northstar M-3 Approach - Garmin 155 or 155XL - King KLN-89B or KLN-90B - Apollo GX-50 AFAICT one can pick up a decent used example of any of these for between $1500 and $3000 depending. I know we'll also need the annunciator and CDI, and that installation/certification will comprise 50% of the total cost. One of my big concerns in buying an older GPS is database updates. I want to make sure we will not end up say a year or two down the road with an expensive VFR GPS because updates are no longer available. Also, general mfr. support. I would like a decent moving-map capability, but given that we have none in the plane right now, even a simple airspace depiction like the KLN-89B would be a significant gain. If we want something snazzy we can get it better on a handheld anyway. I would spend an extra $500 for a better map, but $1000 or $1500 I'd wonder about. What would you guys do? Best, -cwk. |
You will probably never have trouble getting King updates.
There are TONS of KLN89's out there. Quite a few 90's also. Garmin will probably continue to support the 155 as they are going great guns and will support all their products as they have the money and protect their reputation. "C Kingsbury" wrote in message link.net... Hi all, Currently examining options for upgrading a 1979 172N with an IFR-certified GPS. We currently have two good nav/coms, M-1 Loran, and ADF that we want to replace. Goal is to find the most cost-efficient IFR GPS install to replace the ADF and add legal /G and DME capabilities. Keeping in mind that the plane is worth maybe 50k we are not going to spend 10-12k on a GNS-430 class box, so as I see it we have these options: - Northstar M-3 Approach - Garmin 155 or 155XL - King KLN-89B or KLN-90B - Apollo GX-50 AFAICT one can pick up a decent used example of any of these for between $1500 and $3000 depending. I know we'll also need the annunciator and CDI, and that installation/certification will comprise 50% of the total cost. One of my big concerns in buying an older GPS is database updates. I want to make sure we will not end up say a year or two down the road with an expensive VFR GPS because updates are no longer available. Also, general mfr. support. I would like a decent moving-map capability, but given that we have none in the plane right now, even a simple airspace depiction like the KLN-89B would be a significant gain. If we want something snazzy we can get it better on a handheld anyway. I would spend an extra $500 for a better map, but $1000 or $1500 I'd wonder about. What would you guys do? Best, -cwk. |
![]() "Al Marzo" wrote in message ... On 8 Oct 2004 20:58:55 -0700, (Doug) wrote: Not sure if that's entirely true. Another way to put it is that Garmin will support their product as long as they can turn a profit that is acceptable to the fat cats on top. How many of the portable I actually like the Apollo GX units best out of all of these, but the support factor really worries me. Though Jeppesen has every incentive to keep selling database updates, Garmin also has plenty of incentives to make supporting them a low priority. Likewise the Garmin first-gen boxes. I can imagine them at some point saying, we won't support this anymore, but we'll give you $500 off a new GNS-XXX or a year of free database updates if you trade it in. Garmin doesn't really have to compete too much right now. They've lapped King in terms of panel-mount GPS and even nailed Avidyne to the wall on glass panels. After all, while the G-1000 is an all-garmin product, the Entegra always seems to come with Garmin radios. So they don't even need to buy that one out like they did Apollo. -cwk. |
![]() "C Kingsbury" wrote in message link.net... "Al Marzo" wrote in message ... On 8 Oct 2004 20:58:55 -0700, (Doug) wrote: Not sure if that's entirely true. Another way to put it is that Garmin will support their product as long as they can turn a profit that is acceptable to the fat cats on top. How many of the portable I actually like the Apollo GX units best out of all of these, but the support factor really worries me. Though Jeppesen has every incentive to keep selling database updates, Garmin also has plenty of incentives to make supporting them a low priority. Likewise the Garmin first-gen boxes. I can imagine them at some point saying, we won't support this anymore, but we'll give you $500 off a new GNS-XXX or a year of free database updates if you trade it in. Garmin doesn't really have to compete too much right now. They've lapped King in terms of panel-mount GPS and even nailed Avidyne to the wall on glass panels. After all, while the G-1000 is an all-garmin product, the Entegra always seems to come with Garmin radios. So they don't even need to buy that one out like they did Apollo. -cwk. I do have experience with Jeppesen support and it seems very good. I have a Trimble (remember them) TLN-2000 panel mount combo GPS/Loran. Think I bought it in 1994 and still can get data base cards from Jeppesen even though Trimble has gotten out of the general aviation market (liability perhaps?). I haven't gotten an replacement GPS yet because it would require from the ground up installation. None of the existing interfaces (antennas, autopilot, trays, etc) could be reused. Have Garmin 196 for mapping and non GPS instrument install for instrument flight. All that being said I don't think I could get a decent IFR certified GPS installed and interfaced to my autopilot (STEC 50) for less than 10K. Probably would be more. Howard C182P Howard --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/2004 |
![]() "Howard Nelson" wrote in message ... I do have experience with Jeppesen support and it seems very good. I have a That's my point- The way Jeppesen sees it, they make (roughly) the same money selling you an update for a first-generation steam-powered GPS as they do a G-1000. Discontinuing support for a particular unit would in most cases cost more than it saves. But what happens if the box needs repair? Are there 3rd-party shops that can fix this stuff, or do you rely on the mfr. giving a crap? King I'd feel comfortable relying on but Garmin, nope. All that being said I don't think I could get a decent IFR certified GPS installed and interfaced to my autopilot (STEC 50) for less than 10K. Probably would be more. I wish I had an autopilot that needed interfacing to. Heck, I wish I had an autopilot period. In any case that adds significantly to install cost. One of the flight schools on my field has been spending about 6k each putting IFR GPSs in all their Warriors and Skyhawks over the past couple years. -cwk. |
