Gary Wilcox wrote: When I bought the plane the pre-buy inspection was a complete annual and the mechanic didn't mention any "aluminum in the oil" so apparrantly this just started. If the previous owner changed the oil and filter just before your pre-purchase, there wouldn't be any particles in the filter for your A&P to find. Check the engine log book. Assuming that an oil change was made and that the change was properly logged, you'll know whether it just started or not. What is the likely source of this aluminum? Don't know that one. Most of the critical components such as bearings, cylinder sleeves, wrist pins, etc. are not aluminum. I'd say that's encouraging. If I had to guess, I'd say that a bearing is loose and eating away at it's housing, but that usually makes a good deal of noise. The mechanic suggested that I fly for 10 hours and change the oil again to see if the problem goes away. Stay close to home. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
The O-540 in our Pathfinder was making metal at the pre-buy inspection. It turned out to be aluminum from the piston pin plugs, and the amounts we found convinced us to slash our purchase offer, and put in a new engine when it was accepted. (BTW: The new piston plugs are made of a harder alloy that won't spall, supposedly.) If you found a "few slivers" that's not abnormal. If there are a lot of slivers, and you're flying a C-172 with the H2AD engine, you may have some serious trouble brewing. (That engine was known for making metal, although the latest oil additives supposedly have alleviated this problem.) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
How many years has it been since the engine was overhauled?
They hate sitting around. Karl |
A possible guess based on experience from a C-150 which has the same
cylinders - It could be a wrist pin end plug scrubbing the cylinder wall. This was caused by a loose (i. e. floating) wrist pin rod bushing. A C-150 of ours always had produced a very small amount of aluminum which our mechanic condemmed as having a lemon engine. On teardown we found one wrist pin bushing loose in the rod end, & that mechanical rectification was causing the wrist pin end to scrubb slightly on the cylinder wall. I suspect the bushing had been cracked loose during a previous disassembly. We redid it with Millenium cylinders & a new rod of course. It has been good ever since. It now is again at or beyond TBO. |
| Thread Tools | |
| Display Modes | |
| Epoxy Bonding to Aluminum and Magnesium | Ryan Young | Home Built | 25 | September 16th 04 03:45 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
