Metal fatigue in Lycoming engines limiting its TBO?
Old November 4th 04, 03:29 PM
PaulH
For corrosion and other reasons stated by other posters, there is also
a time limit of 12 years that Lycoming suggests as TBO. If the engine
has not been torn down and inspected for 20 years, relying on hours
only is risky.
Old November 5th 04, 03:03 AM
The limiting factor isn't generally crank/rod/ or other major
component fatigue (especially in those bullet-proof O-320s)but is
probably corrosion and cam/lifter spalling. Oil analysis might catch
either one. I doubt the factory has any info beyond that they would
or even could release.
From a strictly cumulative fatigue analysis standpoint there could
have been an innocent relatively short term event in the engine life
such as simply max throttle on a bitterly cold winter day that has
done most of the fatigue damage. Or it could simply be long term
operation at a wrong RPM where the crankshaft & prop are resonant.
This type of "abuse" exists, but the wise ones (i. e. the certifiers)
have decided and found that there is enough metal in this engine that
it seems to be able to handle it. Hence for example there is no
prohibited RPM range. Certainly the operating experience of a large
fleet helps reinforce this. Whether that is true for precisely all
supposedly identical engines and all conditions is impossible to say,
but the history on this engine series is probably the best in the
business. But engineering is an art, not a science. As one
(mechanical) I can understand why the factory is reluctant to say to
keep operating it.
I have an O-320 E2D in a 172M last assembled over 29 years ago, & now
at 1700 hrs TTSN. It has been opened only slightly for the oil pump
gear AD, but otherwise it has shown no deterioration in compression,
smoothness, or oil consumption over its lifetime. I'd like to think I
have run it pretty carefully, but I realize I am running a slight
chance. On the other hand, seeing the occasional AD show up on newly
manufactured parts scares me too. The comfort I have is that I
personally know the entire history of its operation. My decision is
to keep operating it.
Our IA once mentioned a Citabria in fish spotting duty out over the
Atlantic that had 3800 hrs on it without overhaul.
Unfortunately the limits of technology has to make it your call. But
others are doing it too.
Old November 7th 04, 02:46 PM
Roger Long
Oil analysis will NOT alert you to lifter spalling. The pieces are too big.
You will see those in a careful inspection of the oil filter element. Once
the first pin head, or smaller, size piece shows up, the lifters will go
fast. It's like taking the first brick out of a brick wall.
If you have one of the engines where the lifters can be pulled easily, you
should have them looked at every 100 hours after about the first 500. Catch
the problem early in an engine where the lifters can be pulled any you may
save the cam and an engine tear down. If you find a single speck of
metallic metal in your oil filter, pull the lifters and check.
Rocker arms are a potential fatigue failure point. In an O-320, the rocker
arm is fairly thin, it may even be stamped, and there is a dimple to form
the recess that the pushrod goes in. I've seen that dimple simply popped
out of the rocker arm in a way over TBO engine.
There were evidently a lot of lifters with sub standard metallurgy released
into the supply stream in the late 90's. We'll probably hear something from
the FAA about that before the end of the year. Despite compulsive care of
our O-320 H2AD and awareness that even a single cold start can the spalling
process in a lifter, two of ours came apart and destroyed the cam at 1000
hours.
You will so performance evidence of a cam that is grinding down due to
lifter spalling until it is worn to a startling degree. There will be a
gradual loss of horsepower but it will progress so slowly that you won't
notice unless you monitor and record performance very compulsively.
Roger Long
m...
keep operating it.
Old November 4th 04, 05:38 PM
On 3 Nov 2004 10:25:09 -0800, (Wolfgang) wrote:
Many of the small Lyc. engines have a TBO of around 2,000 hours. My
O-320-D3G (TBO 2,000hrs) has now 2,200 hrs since new, it's never been
opened for any reason. Of the above time, 1,100 hrs have been flown in
my RV-6.
I change oil (15W50) and full-flow filter every 50 hrs, cut-open the
filter for inspection, and have the oil analyzed. The compression is
still in the mid-70s.
I plan to continue flying until any of oil analysis/compression/oil
consumption would indicate a noticeable departure from their historic
values.
I am flying the same engine (O-320-D3G) with 2500 hours on it, a Lycoming
factory reman in a Warrior. I do all the things you do. Compression was
consistently in the mid 70s. This year's annual showed a drop in compression on
one cylinder. It was noticeable, but not unairworthy, so we are still flying
it. We are checking the compression often and planning a engine replacement for
this winter.
Catastrophic failure is a concern for all engines, new and old. Fly the thing
until it tells you it is tired. Test the compression often. If you can do it
yourself, do it every oil change when you rotate the sparkplugs - you are
rotating your plugs, yes?. The differential gauge is less than $100 and if you
already have a compressor it's your only expense. Google for information on how
to test compression or contact me and I can point you to what I have found.
Demonick
Old November 4th 04, 09:43 PM
George Hamilton
I flew an 0-320 to 2400 hours. The only reason I changed it out was
the general condition of the valves and guides. Knowing what I do now
I would buy four complete jugs and put them in and run the engine
until the oil pressure became an issue. Metal fatigue is probably not
a problem. Bearings, yes.
Book Review:Maintenance/overhaul guide to Lycoming aircraft engines, Christy Paul Home Built 11 December 26th 04 04:24 AM
Metal fatigue in Lycoming engines limiting its TBO? Wolfgang Home Built 11 November 7th 04 02:46 PM
Lycoming engines "code" Philippe Home Built 3 September 11th 04 03:25 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
