Winter is comming to Ohio ( thou the 60 deg day today disagrees) and the
subject of engine preheat arrises. I have a Tannis for the cylinders and a pad to heat the oil. I can call the FBO and have them plug it in an hour before I arrive and the engine is, at least, not cold to the touch. Still there is the time when I fly somewhere for dinner or overnight and park in the cold, cold outside. The question, why is preheat necessary? If it is OK to start the engine cold when the temp is 60deg F and let the cyl head temp go up to 500 or 600 deg, why is preheat recommended when the cold temp is 10 or 20 deg? The percentage difference in the delta T is less than 10%. Are the engine parts that critical that this small percentage change makes that difference? I use 15/50 oil so the "cold" oil should be a good at the lower temp. Chuck |
Preheat is far more important on Lycoming engines because the camshaft is at
the top. Oil is supplied to the valve lifters only by being sprayed from the camshaft and crankshaft bearings. Colder oil is thicker and does not spray very well. On oddity about the dynamics of the valvetrain is that the pressure of the camshaft lobes on the lifter is highest at low RPM and least and high RPM. The metal pressures on the lifters are very high anyway. Oil also cushions and distributes the load of the cam lobes against the lifters. Everything is therefore working against the lifters on startup. The oil has drained off while the engine was not running, the oil is thick so doesn't flow easily through the oil passages and bearings, the thick oil doesn't spray well, the pressure of the cam against the dry lifters is highest due to low RPM. The high cam pressures bend the surface of the lifters microscopically and the metal fatigues. Small pieces come out in exactly the same mechanism as potholes forming in a road. Then the edges of the holes breakdown and the "potholes" become larger. The lifters then start to wear away the camshaft. The faster a good oil film gets established on the cam, the less chance there is of lifter damage. Anything under 60 degrees carries some risk. We preheat below 40. A single cold start when it is really cold can damage a lifter. -- Roger Long "PaulaJay1" wrote in message ... Winter is comming to Ohio ( thou the 60 deg day today disagrees) and the subject of engine preheat arrises. I have a Tannis for the cylinders and a pad to heat the oil. I can call the FBO and have them plug it in an hour before I arrive and the engine is, at least, not cold to the touch. Still there is the time when I fly somewhere for dinner or overnight and park in the cold, cold outside. The question, why is preheat necessary? If it is OK to start the engine cold when the temp is 60deg F and let the cyl head temp go up to 500 or 600 deg, why is preheat recommended when the cold temp is 10 or 20 deg? The percentage difference in the delta T is less than 10%. Are the engine parts that critical that this small percentage change makes that difference? I use 15/50 oil so the "cold" oil should be a good at the lower temp. Chuck |
there is of lifter damage. Anything under 60 degrees carries some risk. We preheat below 40. A single cold start when it is really cold can damage a lifter. Which always leads me to this same question: Does anyone here have a "pre-oiler" installed in their airplane? It would seem so logical, yet I've never met anyone with one installed (other than on big warbird engines...). -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
The preoilers oil everything except the cam and lifters. The Ney nozzles
spray oil directly on the cam and lifters but not until there is oil pressure. Neither one is the answer to the Lycoming cam problem but the two together probably are. You would still want to preheat though to be sure the oil was thin enough to get onto the cams. -- Roger Long "Jay Honeck" wrote in message news:_Uykd.324061$wV.233990@attbi_s54... The faster a good oil film gets established on the cam, the less chance there is of lifter damage. Anything under 60 degrees carries some risk. We preheat below 40. A single cold start when it is really cold can damage a lifter. Which always leads me to this same question: Does anyone here have a "pre-oiler" installed in their airplane? It would seem so logical, yet I've never met anyone with one installed (other than on big warbird engines...). -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
PaulaJay1 wrote: The question, why is preheat necessary? Most aviation engines turn fairly slowly. That allows the manufacturers to use valve springs that are pretty weak, compared to those in an auto engine. That, in turn, allows them to build the entire valve train pretty light. That's the weak point in the design, and you can snap a valve stem if you don't preheat. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Aluminum (like crankcases) shrinks faster than steel (like crank and cam
shafts). At some temperature (like 10 deg. F), there is NO clearance left between the bearings and the crank. Starting the engine leads to very rapid bearing and journal destruction. PaulaJay1 wrote: Winter is comming to Ohio ( thou the 60 deg day today disagrees) and the subject of engine preheat arrises. I have a Tannis for the cylinders and a pad to heat the oil. I can call the FBO and have them plug it in an hour before I arrive and the engine is, at least, not cold to the touch. Still there is the time when I fly somewhere for dinner or overnight and park in the cold, cold outside. The question, why is preheat necessary? If it is OK to start the engine cold when the temp is 60deg F and let the cyl head temp go up to 500 or 600 deg, why is preheat recommended when the cold temp is 10 or 20 deg? The percentage difference in the delta T is less than 10%. Are the engine parts that critical that this small percentage change makes that difference? I use 15/50 oil so the "cold" oil should be a good at the lower temp. Chuck |
head temp go up to 500 or 600 deg, CHT's of 500/600 degrees? Definitely not. Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
"pre-oiler" installed in their airplane? It would seem so logical, yet I've never met anyone with one installed I have one on my Glasair Experimental. It is a Moroso (performance auto) unit. It acomplishes 3 things. Pre-oil and pre-pressurize engine oil system 3 quart capacity, Stabilized oil pressure (steady pressure), will maintain oil pressure for the prop durring aerobatics. |
"pre-oiler" installed in their airplane? It would seem so logical, yet I've never met anyone with one installed I have one on my Glasair Experimental. It is a Moroso (performance auto) unit. It acomplishes 3 things. Pre-oil and pre-pressurize engine oil system 3 quart capacity, Stabilized oil pressure (steady pressure), will maintain oil pressure for the prop durring aerobatics. Thanks for the update. What engine is this installed on? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| Preheat / Pre-Oiler | Fastglasair | Home Built | 6 | November 13th 04 06:40 AM |
| BRAC - The Preheat Mode | Yofuri | Naval Aviation | 17 | May 24th 04 01:47 PM |
| Cold Starts | Viperdoc | Owning | 66 | February 26th 04 09:51 PM |
| PIREP - Reiff Preheat Systems | Joe Young | Owning | 19 | December 14th 03 07:38 PM |
