Wrinkly flat panels
Old March 5th 04, 02:10 AM
Blueskies
I saw a set of rollers with the corrugation profiles in them, and the 2024 was 'simply' hand cranked between them. Once
you have the rollers is should be pretty easy, but getting the rollers...
They crank out roof gutters from the back of vans on the building site, maybe someone knows someone who has an old
gutter rig...
Dan D.
wrote in message ...
In article , "Blueskies" wrote:
ala TriMotor - corrugations
I kind of like the idea of corregations. Any ideas on how to accomplish them?
thanks,
tom
Old February 25th 04, 01:21 AM
jls
I've seen a few homebuilts with part of the fuselage panel that are flat
aluminum that are quite wrinkly and tend to "oil can" and make noise in
various flight attitudes. I haven't seen cross breaks used to stop this,
although it is used in duct work to stiffen flat panels. (cross breaks
are
slight bends in the metal, done diagonally from corner to corner)
Another thought to reduce this noise is to spray urethane foam on the
panels.
I know that this foam is combustable, but I figure for it to get on fire
would
mean the pilot and passenger cabin is already engulfed, so it wouldn't
really
matter.
What do you think?
thanks,
tom pettit
A stiffening bead pressed into the panel or aluminum channel or angle
riveted to the back of the panel. My old Taylorcraft has half-circle
pressed beads on the firewall to stiffen it, and I notice the old Cessna I
have the cowl off of has a flange running horizontally across the middle of
the firewall, plus a few other neat stiffening devices. That stiffens it
for you. You can countersink the rivets for appearance's sake if you wish.
Stiffening a panel of fiberglas is great fun: all you have to do is make a
sandwich with foam in between, the thicker the foam the stiffer. As a
matter of fact as the thickness increases the stiffness and strength go up
at a staggering rate. There are formulas for that and not being a
mathematician I'd best not delve into the theory of beams but if you double
the height of a beam you have increased the stiffness and strength of the
beam by exponents of the increase in height. Let Billy B. Badd explain it
to you in his most inimitable articulate way.
Old February 25th 04, 03:41 PM
Bob Chilcoat
The stiffness goes up by the third power if the thickness. Double the
thickness of a plate, and it's eight times as stiff.
Bob (Chief Pilot, White Knuckle Airways)
" jls" wrote in message
this,
are
panels.
would
really
matter.
What do you think?
thanks,
tom pettit
of
wish.
a
double
Old February 25th 04, 02:28 AM
Chris Batcheller
The solution is simple. Cut the panel from 0.090 2024. The panel will
never wrinkle. Then paint the panel with an epoxy based paint. It will look
great for years.
We have them CNC machined all the time and they look great. email me if you
need me to set you up with a place that can do that.
Thanks, Chris
are
panels.
would
really
matter.
What do you think?
thanks,
tom pettit
Old February 25th 04, 03:40 PM
Wright1902Glider
Curiously enough, I've seen pannel wrinkling on the front end of a B-52!
Harry
Old February 25th 04, 06:14 PM
Bob Kuykendall
Earlier, "Chris Batcheller" wrote:
The solution is simple. Cut the panel from 0.090 2024...
I think that the original poster was using the term "panel" in a
somewhat generic sense, and not necessarily to refer to an instrument
panel. But that was the way I first read it, too.
Thanks, and best regards to all
Bob K.
