Dead Stick Landings
Old July 29th 03, 08:04 PM
Michael
"Yossarian" wrote
I don't understand how you can pull a 180 from only 400' with no engine
power.
More easily than you might imagine. Most singles in that class have a
power-off descent rate of about 800 fpm (give or take a bit) in the
normal takeoff configuration at normal glide speeds. It will be a
little more in a steep turn. That gives you a little less than 30
seconds to work with - tight but doable. Generally glide speeds tend
to be 70 kts give or take a bit, and that means with 45 degrees of
bank you're doing more than 3 times standard rate - which means a 180
takes less than 20 seconds. So from 400 ft you have enough time to
make a 180, do a minor correction to line up with the runway, and
flare.
Part of glider training is an intentional tow release at 200 ft or so,
with a return to the field. This means making more than a 180 -
sometimes as much as a 270 - plus another turn to get lined up,
sometimes as much as 90 degrees. The turns are made at normal glide
speed and 45 degrees of bank. Glider sink rates being what they are,
this gives the pilot a little more than a minute to work with - which
isn't even tight. It's a presolo maneuver that a pilot with less than
10 hours total time is expected to perform correctly, and in my
experience most pilots get it right on the first or second attempt.
Michael
Old July 29th 03, 05:54 PM
Kevin Chandler
I think I would have knocked out my instructor for doing something that
stupid.
"altekocker" wrote in message
I did fly gliders for awhile. Then, after I'd acquired about 250 hours
asel,
during a BFR in a 182, we were at 400 feet on takeoff when my instructor
reached over and took the key out of the mag switch.
I turned 180 but not back to the runway (that would have been 270) and
landed on a taxiway.
I have two friends who made successful landings after catasrophic engine
failures. One put his 182 onto a landfill, damaging only the wheelpants.
The
other turned 180 on takeoff at 600 feet in a Tiger and parked it neatly on
the runway -- three pax, no airframe damage, and she now wears the melted
exhaust valve mushroom, in a silver setting, on chain around her neck.
Seth
Comanche N8100R
"Rocky" wrote in message
om...
Aside from glider pilots.... how many of you have ever experienced an
engine out dead stick landing? Care to talk about it? I've done quite
a few of them. Some were intentional, some were during training, and
some happened at the most inopportune time with mechanical failures of
one sort or other. This included helicopters and airplanes.
Old July 30th 03, 03:14 AM
Art Johnson
"altekocker" wrote in message ...
I did fly gliders for awhile. Then, after I'd acquired about 250 hours asel,
I would hit this Motherf*****r so hard and often, he never would done
that agin to anyone. Regards, Art
Seth
Comanche N8100R
om...
Old July 29th 03, 05:14 AM
Robert M. Gary
I kinda lost an engine in a J-3 once due to carb ice. The carb heat
was actually on at the time but I guess it took that long for the ice
to become water. However, by the time I completed my 180 back to the
field, it had cleared.
(Rocky) wrote in message . com...
Old July 29th 03, 05:56 AM
Ditch
In 5000 hours, I have had 3 full engine failures (two at low altitude), 4
partial failures and once (and I kid you not) I have had both prop governors
fail on a Twin Otter. The left one failed first and I shut the motor down and
the right one failed as I was turning a very high final. Interesting day.
One of the low altitude failures resulted in the airplane going in to a ditch
on airport property. Totalled the airplane, but my student and I walked out ok.
-John
*You are nothing until you have flown a Douglas, Lockheed, Grumman or North
American*
Old July 29th 03, 04:51 PM
Ditch
Flying jumpers, right?
Yup...the scary thing, this was one of the better Twotters out there.
Near as he could figure, the failure rate in jumpship service was
about 300 times higher than in Part 121 service.
I can believe it.
-John
American*
Old July 29th 03, 09:32 PM
john
snip
had a prop governor drive failure in a PA32 (T-tail Lance) after T/O
from Port St. Joe FL, a 4230 x 65 grass strip. Took off from 18 & was
climbing through 600' agl on downwind when what I thought was rain
began to spray on the windshield. Trouble was, there wasn't a cloud in
the sky. As I was 3/4 of the way on downwind the little idler shaft
driving the governor spit out behind the flywheel & it puked 10-11 qt
of oil out the front. The oil actually rained inside the cockpit
through the overhead fresh air vents. Abeam the numbers 36, I shut the
engine down, got the wheels out (got lucky & saved the bearings).
With the luxury of a 4000+ rwy, I was able to put it into a slip so I
could see out the left side window & get it on the ground (killed a
lot of grass from the oil). The engine was overhauled 400 hrs earlier
& it seemed that they didn't safety wire the crankcase plug which
retained the little prop governor driveshaft at the front of the
engine. Having flown the Lance in a lot of IMC, night, over mountains,
out to the Bahamas, etc, I kinda shake when I think of other times it
could have let go!
I have instructed "the impossible turn" back to the rwy in my 172. As
others have said here, 60 deg bank worked best for me. The teardrop
turn involves a total of 270deg of heading change. In standard
conditions, 400' - 450' agl was a comfortable minimum altitude. I
certainly don't advocate teaching this emergency maneuver as a part of
primary training due to the vagaries of reaction time, density
altitude. etc; but its a fun exercise if approached carefully & only
with someone who has had spin training & knows what rudder pedals are
for.
john
Old July 30th 03, 01:30 AM
H. Adam Stevens
"john" wrote in message
snip
could have let go!
for.
john
Go up a few thousand feet and practice where there's some room.
A few years back I had the delightful opportunity to attend a reunion of B24
pilots from the Ploesti raid.
IIRC they were the Crusaders, the 392nd bomb group.
I shook the hand of a pilot who "dead sticked" a B24.
H.
N502TB
Old July 30th 03, 06:07 AM
Ditch
Pretty neat dead sticking that thing.
The coolest dead stick landing (IMHO) occured on April 4, 1963 when Stu
Harrison dead-sticked an F-8 Crusader on to a carrier.
-John
American*
Should Memorial Day and America's War Dead be commercialized? Otis Willie Naval Aviation 0 May 24th 04 02:29 AM
Should Memorial Day and America's War Dead be commercialized? Otis Willie Military Aviation 0 May 24th 04 02:29 AM
