"Peter Duniho" writes:
TCP uses sliding windows to allow constant streaming of data to occur as long as the latency in the connection is "reasonable". That is, it will send many packets before needing to receive any acknowledgement even for the first packet. As long as the acknowledgements start coming in time, the latency of the connection will NOT affect throughput AT ALL. A latency of 500ms is MORE than reasonable in this context. Everything you're saying makes sense to me, but you might want to hang around on news:comp.protocols.tcp-ip for awhile. I regularly notice people trying to debug satellite TCP issues there. It's quite possible that it's just a matter of getting all of the settings tweaked everywhere, but it seems to cause a lot of grief. --kyler |
![]() "Scott Lowrey" wrote in message om... Pete Zaitcev wrote in message ... "Lag" in the original poster's case, is actually referred to as "latency" in the world of computer networking. Latency is defined as the time it takes to set up and send a message, Well, it's the overall transmission time from source to destination. The overhead to set up and send a satellite packet isn't really any worse than anything else, it just takes a long time to deliever. Since all data is transported in TCP packets (in the case of Web traffic), there is continual send AND receive on BOTH sides since TCP requires acknowledgement of every packet on the part the of the receiver (remember, TCP is a *reliable* protocol). Actually, it's acknowledgement of the position in the byte stream. Granted, the ACK packets are much smaller than the data packets There's no such thing as an ACK packet. A TCP packet can have data as well as the ack for data received. |
"Ron Natalie" wrote:
There's no such thing as an ACK packet. A TCP packet can have data as well as the ack for data received. I wouldn't say there's "no such thing". The people I work with generally call a packet with the ACK bit set an "ACK". :-). And if you examine the packets flying in and out during a web surfing session, they usually don't contain any data. The latency in the network is going to affect the retransmission timer on the sending end. Delay is delay. It's not constant, but it is cumulative. I'll concede, though, that as long as the acknowledgement timing is not highly variable, the window will stabilize and you'll get your nominal throughput *for that particular HTTP request*. Another click or a redirect and, presto, another delay. It all adds up. Sorry to flog the dead horse... I'll shut up. -Scott |
"Pete Zaitcev" wrote in message
news ![]() [...] Solstices only knock communication off for several minutes a day, when the Sun is directly behind the satellite. It is a well known effect. By the way, surely you and the others mean equinoxes, not solstices? During a solstice, the sun is at its greatest deflection from the equator (and thus a geostationary satellite), while during an equinox, the sun is directly over the equator. Not that it matters in the context of this discussion, since the downtime still is present, regardless of what time during the year it happens. Pete |
"Darrel Toepfer" wrote in message ... 500ms ping time minimum... So count on lots of lag... Unless you are playing online computer games, you would never notice the lag. Interactive logins (telnet, etc) would suck with such a lag. -jav |
![]() "Peter Duniho" wrote in message ... I have no idea why the solstices would have any effect on data transmission. Perhaps you could explain that one. During solstices, or even within a few days, the elevation to the sun and the satelite is nearly the same. As the sun transits across the sky, for a period of time, your reciever, the satelite, and the sun are all nearly in line. The sun; since it appears directly on the other side of the transmitter, overcomes the transmitter signal with white noise (radiation) -- Jim in NC-- |
![]() Morgans wrote: During solstices, or even within a few days, the elevation to the sun and the satelite is nearly the same. As the sun transits across the sky, for a period of time, your reciever, the satelite, and the sun are all nearly in line. The sun; since it appears directly on the other side of the transmitter, overcomes the transmitter signal with white noise (radiation) Directv is unaffected. I have had my system for 7 years now. Not so much as a hiccup excpet when there is a heavy wet snow. The snow sticks to the feedhorn. Brush it off and the picture is back. I have turned the TV on in a heavy downpour and checked signal strength, no change. Always in the high 80's here. |
Newps writes:
Morgans wrote: During solstices, or even within a few days, the elevation to the sun and the satelite is nearly the same. As the sun transits across the sky, for a period of time, your reciever, the satelite, and the sun are all nearly in line. The sun; since it appears directly on the other side of the transmitter, overcomes the transmitter signal with white noise (radiation) Directv is unaffected. I have had my system for 7 years now. Not so much as a hiccup excpet when there is a heavy wet snow. The snow sticks to the feedhorn. Brush it off and the picture is back. I have turned the TV on in a heavy downpour and checked signal strength, no change. Always in the high 80's here. DirecTV and Dishnetwork are indeed affected. The affection lasts just a few minutes twice a year. Check it at the next equinox, you will see. The exact time varies with your location, I'm sure there's a web page somewhere that will calculate the service-out time for your lat/lon. -jav |
"Darrel Toepfer" wrote in message . .. 500ms ping time minimum... So count on lots of lag... Unless you are playing online computer games, you would never notice the lag. Call me on my Asterisk VoIP phone and let's talk about that. Some don't network very well... Not sure what that means. Consumer satellite network systems have traditionally been closed. I recall one (StarBand, I think) that had a USB interface but someone figured out that it just went to a USB Ethernet adapter which would be easily bypassed to get plain old Ethernet. Still, MS Windows is often an official requirement and setting up a NATed network is not always straightforward (because of special caching clients?). None will work when it rains hard or the sun is in transit (summer / winter soltice)... Why would you say that? The satellite data systems I've seen are based on similar technology to that used for my digital broadcast satellite system. At worst, data throughput drops *some*, and that's in the very worst downpours. The downlink is not as much of a problem as the uplink. I have no idea why the solstices would have any effect on data transmission. Perhaps you could explain that one. Probably has something to do with naked people dancing in front of the dish. All end up with more customers than they can actually support (whether it be on the transponders, gateways or internet bandwidth)... That may well be true. Though, of course, it happens with DSL and cable as well. Sure, but DSL and cable have comparatively huge data capacities. It takes a tiny amount of usage to swamp a satellite uplink. Make sure to check out some reviews of satellite services before jumping in. Lots of people have gotten burned when they planned on using them just like other high-speed services. (I'd still like to get one with a folding antenna for plane camping someday.) --kyler |
On Tue, 19 Aug 2003 18:52:58 -0500, Montblack wrote:
http://www.orderdsl.net/satellite.htm How well do these systems work? 2-way satellite "high speed" internet access. Anyone with experience with these systems? Hidden costs? Looks like a good $99 month solution - if it works. Less than that, actually. Around here, lots of gas stations use it to connect to their HQ. Perhaps they get discounts. I do not have experience, but there are some obvious gotchas. First, you must have USB, and you must have Windows (2K or XP). Second, interactive traffic is a pain in the ass because of the delay, so gaming is out. Neither are fatal for FBO or a gas station, I suppose. -- Pete |
FBO's and WiFi | Javier Henderson | General Aviation | 43 | August 30th 03 08:22 AM |
