"Sims" wrote in
: "red rover" wrote in message .. . "Dale DePriest" wrote in message You mean your magnetic heading. You have your actual heading. You need a table of magnetic variations and interprolate from the table based on your location as there is no mathmatical model that will provide this information reliably. (Sorry to reply here your post was cancelled). Yes i do mean the magnetic heading. Sorry I was not clear. Where can i get a table to compute my magnetic heading? You might take a look at the Canadian Geological Survey Geomagnetism website: http://www.geolab.nrcan.gc.ca/geomag/home_e.shtml After all, the North magnetic pole is in Canada ;-) -- Dave Patton Canadian Coordinator, the Degree Confluence Project http://www.confluence.org dpatton at confluence dot org My website: http://members.shaw.ca/davepatton/ Vancouver/Whistler - host of the 2010 Winter Olympics |
![]() Sims wrote: flight headings. If i use 2 lat/lon i can get a "true course" but due to magnetic variations ... actual heading varies a lot depending on my position along the course. ...formula to calculate my actual heading at a certain point along the course? As Steve has noted there are two things happening: (1) The bearing to point B along a great circle/ellipsoid path from Point A to B varies along the path. (A computer/autopilot can be set to follow the ever varying bearing.) (2) The Earth's magnetic variation (a.k.a. declination) that affects a magnetic compass heading varies with latitude and longitude and also with time. This magnetic field offsets the true great circle bearing at a given point along the path. If one follows a rhumb line course instead of a great circle path, the rhumb line bearing is constant. This is easier for a human to follow at the expense of having a longer path. One can find this on a Mercator projection map. Again the magnetic variation offsets the rhumb line bearing at a given point. As Dave notes, Ed Williams' site discusses these issues. http://williams.best.vwh.net/avform.htm The World Magnetic Model (WMM) maintained by the U.S. DoD and others http://www.ngdc.noaa.gov/seg/WMM/DoDWMM.shtml predicts the components of the Earth's steady state magnetic field for a given latitude and longitude for a given date. The horizontal component direction corresponds to the magnetic variation. The target accuracy is one degree over a 5-year period. My freeware DOS command line program GCGC* calculates the great circle bearings between two points (WGS-84 default) and then uses the WMM to also calculate the magnetic bearings at the end points. If one needs the true and magnetic bearings along the flight path (certainly a reasonable thing to need in flying), one would recalculate the great circle path to point B from the position at the moment. One can use the included Direct function (Lat1/Long1, Bearing 1-2, and distance 1-2 to get Lat2/Long2) to calculate positions along the great circle path by splitting it into pieces. I also have a program (gcb12) that does rhumb lines at my web site, but I haven't gotten around to adding the magnetic bearings. Cheers, 73, Ron McConnell w2iol N 40º 46' 57.9" W 74º 41' 21.9" Magnetic Variation = 13.0º W in October 2003 FN20ps77GU46 [FN20ps77GV75] * GCGC executable and source at http://home.earthlink.net/~rcmcc |
![]() As Steve has noted there are two things happening: (1) The bearing to point B along a great circle/ellipsoid path from Point A to B varies along the path. (A computer/autopilot can be set to follow the ever varying bearing.) Thanks I was looking for a formula that does the same, so that i can tell my heading at a certain point on the course. I will look at the links given. Again many thanks all for the help. Sims |
Sims wrote: As Steve has noted there are two things happening: (1) The bearing to point B along a great circle/ellipsoid path from Point A to B varies along the path. (A computer/autopilot can be set to follow the ever varying bearing.) Thanks I was looking for a formula that does the same, so that i can tell my heading at a certain point on the course. I will look at the links given. Again many thanks all for the help. Sims Here is a program that does that: http://www.freewarepalm.com/astronomy/navigate.shtml The idea is to compute the great circle heading and distance, divide the great circle distance by as many legs as desired, project the initial heading the divided distance, repeat the process from there for one less leg until no legs remain. E.g.: from Washington DC to Moskva, RF: 38o 51'N 77o 1' 48"W to 55o 58' 48"N 37o 30'E in 8 legs: each leg is 607.77 miles: bearing start 32o 46' 3.86" 38o 51'N 77o 1' 48.00"W 37o 23' 29.85" 46o 3' 58.96"N 70o 11' 54.04"W 44o 5' 15.66" 52o 44' 48.60"N 61o 24' 8.89"W 53o 47' 18.95" 58o 32' 41.37"N 49o 40' 47.65"W 67o 28' 0.55" 62o 53' 15.70"N 34o 1' 55.31"W 84o 58' 38.88" 65o 0' 21.16"N 14o 34' 48.87"W 103o 33' 33.09" 64o 20' 34.61"N 5o 56' 13.18"E 119o 26' 55.57" 61o 5' 21.89"N 23o 46' 41.62"E 55o 58' 48.00"N 37o 30' 0.00"E Now, try to navigate that accurately. It is hard to do manually. Randolph J. Herber, , +1 630 840 2966, CD/CDFTF PK-149F, Mail Stop 318, Fermilab, Kirk & Pine Rds., PO Box 500, Batavia, IL 60510-0500, USA. (Speaking for myself and not for US, US DOE, FNAL nor URA.) (Product, trade, or service marks herein belong to their respective owners.) |
"Sims" wrote in message ...
As Steve has noted there are two things happening: (1) The bearing to point B along a great circle/ellipsoid path from Point A to B varies along the path. (A computer/autopilot can be set to follow the ever varying bearing.) Thanks I was looking for a formula that does the same, so that i can tell my heading at a certain point on the course. I will look at the links given. Again many thanks all for the help. Sims As others have pointed out, it's all there on my web-site, but you have to piece it together. http://williams.best.vwh.net/avform.htm To get the magnetic heading at each point: (1) determine the great circle true course, TC, at each point on the path. It varies as you progress. (2) Correcting for magnetic variation (aka declination), you can determine the magnetic course, MC by MC = TC +- VAR. You can get VAR from a fit. It varies with time. If you want something quick and dirty, use the polynomial fit. If you want to use an official model, such as WMM2000 or IGRF2000, there's source code on my site that will compute it. (3) Lastly, to get magnetic *heading* from magnetic course, you need to solve the standard flight planning wind triangle to find the wind correction angle, WCA, using the known or forecast wind at that point on your flight. Coding for this is also on my site. MH = MC +- WCA (4) Even then you are not strictly finished. You need to correct the magnetic heading to get a compass heading, CH using the listed deviation, DEV, on the specific airplane's compass correction card. CH = MH +- DEV |
![]() As others have pointed out, it's all there on my web-site, but you have to piece it together. http://williams.best.vwh.net/avform.htm Many thanks for a great page. Truly a great piece of work. I have looked at it and found the mag var code. I am just surprised that they vary so much depending what model is been used. What model is the best? And also it seems that by the poles the calculation are somewhat wrong, is it just my imagination? Sims |
Ed,
I second the compliment on your site. I have found it useful several times. John Bell www.cockpitgps.com |
