In article l6Tkb.837378$uu5.148065@sccrnsc04,
Bob Gardner wrote: When you get your twin rating, Ben, and I know that you will, remember this: Below 200 feet with an engine out, put it down somewhere...anywhere...do not even think of going around. One key thing I've learned about flying it's that there are plenty of things that sound easy on the ground but are much harder in practice. For example, it's better to run off the end of the runway at 20kts than to hit the tops of the trees at 60kts. But when actually confronted with landing long on a runway with trees obstructing the go-around it's a lot harder to commit to landing and overrunning than it is to try the go-around. When I read about an accident like this one I try to take away not only the obvious lesson but also put myself in the position of the pilot and think about why he didn't make the right decision. A decision he probably could have made and argued for in an FBO lounge the day before but was unable to make in flight. -- Ben Jackson http://www.ben.com/ |
On Mon, 20 Oct 2003 05:39:55 GMT, "Chris Hoffmann"
wrote: A guy's got an engine out, and he has to go around? Is this normal, or was there some ball-dropping involved? Scappoose is uncontrolled and *busy*. Not as busy as Aurora State a bit further south, but still, I haven't been in there at any time in the last year when there wasn't at least one other aircraft in the pattern. Folks are right, tho. You can put a light single down on the taxiway, there's flat grass on the field, and there shouldn't have been a go around. I haven't seen more than a blurb on the radio news and a three paragraph thing on oregonlive.com. Any better place to go for a report on the Scappoose accident? Rob -- [You] don't make your kids P.C.-proof by keeping them ignorant, you do it by helping them learn how to educate themselves. -- Orson Scott Card |
http://www.kgw.com/news-local/storie...ash.17360595.h
tml This from KGW, the site requires registration. SCAPPOOSE, Ore. -- A preliminary report from the National Transportation Safety Board says investigators don't know why a small plane crashed in Scappoose last weekend, killing everyone on board. The Cessna 340 crashed near the Scappoose Airport late Saturday afternoon and burst into flames. Columbia County authorities Monday identified the victims as James Gillespie, 72, and Jessie Gillespie, 73, of the Steilacom, Wash. area. The relationship of the victims was not immediately clear. Federal aviation records indicate that James Gillespie, an accomplished pilot registered as a flight instructor, owned the plane. NTSB investigators spent much of Sunday sifting through the plane's charred wreckage. They said witnesses are providing clues to what may have happened. Witnesses said that as the Cessna was about to land, another plane took off from the same runway. The Cessna's pilot then decided to go back around to again attempt landing. The plane crashed in a field near the intersection of Moore and Ring-a-ring Road, northeast of the airport. NTSB investigator Debra Eckrote said everything appeared normal until the Cessna's pilot turned back toward the airport. "It then started to lose altitude as it completed not quite a 180-degree turn and then the witness saw that the nose dropped, the left wing dropped.it started an inverted altitude," said Eckrote. It is not known whether the two pilots were communicating. Scappoose Airport is uncontrolled, meaning pilots are not required to communicate with one another in the airfield. -- Chris Hoffmann Student Pilot @ UES 40 hours |
On Tue, 21 Oct 2003 16:45:57 GMT, "Chris Hoffmann"
wrote: (from the KGW report) It is not known whether the two pilots were communicating. Scappoose Airport is uncontrolled, meaning pilots are not required to communicate with one another in the airfield. News to me. I thought the regs stated that if you had a radio, you had to use it. The KEX radio report I heard the following Monday reported "The pilot was under 'visual flight rules' which means he was flying by reference to what he could see, rather than using the onboard instruments." (And to think, I spend time in every pattern looking at that altimeter...) Clearly most reporters need to get the *&^&*%^%^& out of aviation reporting. Rob -- [You] don't make your kids P.C.-proof by keeping them ignorant, you do it by helping them learn how to educate themselves. -- Orson Scott Card |
![]() Robert Perkins wrote: News to me. I thought the regs stated that if you had a radio, you had to use it. No, the radio is optional. The KEX radio report I heard the following Monday reported "The pilot was under 'visual flight rules' which means he was flying by reference to what he could see, rather than using the onboard instruments." That's accurate. |
On Wed, 22 Oct 2003 04:03:07 GMT, Newps wrote:
The KEX radio report I heard the following Monday reported "The pilot was under 'visual flight rules' which means he was flying by reference to what he could see, rather than using the onboard instruments." That's accurate. It's difficult, in a written medium, to convey the level of confidence the reporter has in saying that, that flying VFR was more risky than flying by reference to the instruments. Rob -- [You] don't make your kids P.C.-proof by keeping them ignorant, you do it by helping them learn how to educate themselves. -- Orson Scott Card |
Robert Perkins wrote in message . ..
News to me. I thought the regs stated that if you had a radio, you had to use it. Would you mind sharing with us what regulation says this? Thanks, Sydney |
On Tue, 21 Oct 2003 16:45:57 GMT, "Chris Hoffmann" wrote: (from the KGW report) It is not known whether the two pilots were communicating. Scappoose Airport is uncontrolled, meaning pilots are not required to communicate with one another in the airfield. News to me. I thought the regs stated that if you had a radio, you had to use it. Nope. It's pretty dumb NOT to use the radio you have (especially at a field like Scappoose that's often pretty busy), but it's not reequired by the regs. David H Boeing Field (BFI), Seattle, WA - - - - - - - - - - - - - - - - - - - - - - - - - - Visit the Pacific Northwest Flying forum: http://www.smartgroups.com/groups/pnwflying |
"David H" wrote in message
... Nope. It's pretty dumb NOT to use the radio you have (especially at a field like Scappoose that's often pretty busy), but it's not reequired by the regs. Surely, being dumb is a violation of 91.13? -- David Brooks (not sure whether to add the smiley or not :-) ) |
Homebuilt Airplane Crash | Harry O | Home Built | 1 | November 15th 04 03:40 AM |
Bizzare findings of Flight 93 crash in PA on 9-11 | Laura Bush murdered her boy friend | Military Aviation | 38 | April 12th 04 08:10 PM |
AF investigators cite pilot error in fighter crash | Otis Willie | Military Aviation | 0 | January 9th 04 09:55 PM |
Homemade plane crash | Big John | Home Built | 9 | October 17th 03 06:45 PM |
1956 Valiant crash at Southwick, UK | Nick Pedley | Military Aviation | 3 | July 21st 03 08:05 PM |
