Rolling a 172 - or not
Old November 8th 03, 03:07 AM
Orval Fairbairn
vincent p. norris wrote:
Not if you maintain positive G all the way around (as in aileron roll).
You don't have positive G all the way around in an aileron roll.
To maintain positive G, you need a barrel roll.
vince norris
You are thinking slow roll -- you DO maintain positive G in an aileron
roll.
Old November 8th 03, 08:12 PM
Hamish Reid
In a properly done aileron roll you certainly do...
Or an aileron roll. Were you thinking of a slow roll?
Hamish
Old November 9th 03, 02:26 AM
Big John
Lets kill this thread right now.
1. A 'barrel roll' is a roll where (if done properly) you as a
passenger, with your eyes closed, can not tell you did a roll. The
ball stays centered and if one 'G' is maintained, it feels like
straight and level flight. Starting nose position and of course air
speed varies between underpoweed GA aircraft and super sonic Fghters.
2. A 'slow roll' (point roll) is done with the nose pointing at a
single point (normally picked out o horizon) all the way around. In
Fighters, can be done from straigaht and level flight. Most GA
aircraft require a little airspeed above cruise. To do you raise the
nose above the point on the horizion and start a roll with aileron. As
you continue the roll you feed in top rudder to hold nose up and
adjust the elevator to keep nose on the point. As roll continues you
feed in down elevator (here's your negative G's) to hold the nose up
and on the point while relaxing the top rudder input. As roll
continues you again feed in top rudder (opposite rudder) to hold nose
up on point and take off down elevator holding nose on point. After
passing the 270 degree position, you start removing top rudder and
adjust the elevator to keep nose on point. As you come back out
straight and level all controls are again in neutral. Negatiave "G's"
are of course pulled when on your back. Roll can be relatitivly slow
or rapid as long as nose can be held on a point going around.
3. An aileron roll is just laying the aileron over (normally full
aileron) and letting bird roll. Depending on type of aircraft (fighter
or GA) the nose makes a circle around a point. Fighters can do at
cruise with little or no nose above the horizon. GA requires a start
with the nose above the horizon due to slower rate of roll and bird
ending up nose low because no other control input to hold nose up
while inverted is used
There are also a few fine points the experts use that I have not
covered but above are the basics.
Been there done that for longer (65 years) than BOb has been flying.
Big John.
On 4 Nov 2003 12:06:03 -0800, (Scott Lowrey)
If I'm crusing along at 100 KIAS in a 172 in clear air and I roll left
while maintaining neutral rudder, what will happen if I don't
neutralize the ailerons?
I'm picturing the plane rolling on to its back while losing altitude
and either completing the roll (doubtful) or stalling into a dive and
recovering in the other direction , right side up. (BTW, that's a
split-S, isn't it?)
----clip----
Old November 9th 03, 03:55 AM
Robert Moore
The ball stays centered and if one 'G' is maintained, it feels
like straight and level flight. Starting nose position and of
course air speed varies between underpoweed GA aircraft and
Hey John, I didn't make-up that post, it came straight from:
http://acro.harvard.edu
The Barrel Roll is a not competition maneuver. The barrel roll is a
combination between
a loop and a roll. You complete one loop while completing one roll at
the same time.
The flight path during a barrel roll has the shape of a horizontal
cork screw. Imagine a big
barrel, with the airplanes wheels rolling along the inside of the
barrel in a cork screw path.
During a barrel roll, the pilot experiences always positive G's. The
maximum is about 2.5 to
3 G, the minimum about 0.5 G.
Care to give us a reference for your definition?
Bob
Old November 9th 03, 09:40 PM
Big John
Robert
You talk about doing a LOOP in association with a roll. A LOOP has no
roll in it.The ailerons are only used to keep the wings 90 degrees to
the plane of the loop. A IMMELMAN or CUBAN EIGHT has a roll
associated with part of a loop.
The description of making a corkscrew inside a tube is another way of
defining the flight of the airplane when it does a BARREL ROLL.
In my prior post I said to pull one 'G' when I should have said two
'G'. Same 'G' as pulled in a one 'G' turn (one gravity 'G' and one
acceleration 'G').
Not sure you would or would not call a barrel roll a compition
maneuver. Never flew in compiton. In the airshows we used to put on
didn't do BARREL ROLLS becaue they were not very spectular from the
ground nor percicsion manuevers..
In airshows many times we would do a 8 point SLOW ROLL stoppmg
momentarily every 45 degrees of roll. This is a precison maneuver and
takes a lot of practice with elevator, rudder and aileron in
coordination to do correctly and with precision so looks good from
ground. Seen in compition today.
My reference is years and years of doing acrobatics and teaching same
in both conventional aircraft and jets.
As a matter of interest, most of the victory rolls you see of Fighters
returning from a combat mission with kills are aileron rolls. You
could see some (rare) put a little forward stick in when inverted but
had to look close.
Some birds didn't do good aileron rolls (P-51 for instanace) If you
did an aileron roll on the deck you normally bumped the stick upside
down to keep the nose up. The P-40 however aileron rolled like a spool
on a thread.
Big John
On Sun, 09 Nov 2003 03:55:51 GMT, Robert Moore
combination between
the same time.
Bob
Old November 9th 03, 11:02 PM
Robert Moore
No John, I didn't talk or write about...... I just quoted from the
acro.harvard.edu web site and William Kershner's fine book.
You may not have seen the picture from the Kershner book when you
wrote this, but write back when you have seen the barrel roll as
described by someone who is considered an authority in the field.
same in both conventional aircraft and jets.
Still waiting for reference documentation. :-)
Bob
Old November 10th 03, 12:17 AM
Dale
I've been shown two different ways to do a barrel roll.
The first was to pick a reference off one wingtip. Start pulling and
rolling toward the reference point. Once inverted you would be 90
degrees off original heading (pointed at the ref point). You continue
to roll and pull returning to the original heading.
The second way was to pick a reference point over the nose. Put the
nose slightly to one side of that point then roll and pull keeping the
nose the same distance from the reference point.
The first is the big loopy typy barrel roll - and a lot of fun to do.
The second is a much tighter roll without any loop.
Dale L. Falk
Old November 9th 03, 11:12 PM
Robert Moore
Check-out Mr. William Kershner at:
http://www.kershnerflightmanuals.com/
Bob
Old November 10th 03, 05:19 AM
Big John
Bob
Read Kershner's life story. Note that he left Moffett and crapped out
of the Navy the year I arrived at Moffett to fly All Weather Jet
Fighters (VF-23).
The Navy was just transitioning from Prop Fighters (F4U like he flew
in West Pac, etc) and one of my tasks was to give them the experience
of Air Force Jet Fighter operations including energy management which
was very important in those first generation jet fighters..
Reading his description of life events it seems he pushes the envelope
some like Zzzzom.
I see nothing he has done to warrant your placing so high on a
pedestal. He gives credit to only one document where he lifted some
data/technique. I also detect the wording of other manuals I have seen
through the years that he didn't give credit to.
Of course it may be just how many ways you can say loop?
He says he flies one or two students a month.That's not enough to
maintain proficiency or write from a current background.
You keep asking for my credentials. What do you want, my Military Form
5 where every flight I make in 28+ years is listed. There is at least
one or more pages per month depending on activity and totals well over
350 pages and about 2 1/2 - 3 inches thick weighing 3-4 pounds.
Or my formal education of BS with work on a MS.
Or the Patent number of my patents?
I'm married and have four grown daughters with three grand children
and three great grand children.
I'm over 21 and legal to buy 'booze' so drink Vodka on the rocks.
My GA Flight Logs are pretty thin as I didn't log a lot of the time
because I wasn't trying to build to any number of hours since I had
over 6500 in heavy iron.
It looks like there are several different ideas about acrobatic flyng
on this thread. I've expounded on mine so others can list their way
and I'll set back and might learn somethng??? One is never too old to
learn it is said.
I don't suffer fools but can be moved by facts.
Fly safe and keep the ball in the center unless you are slipping the
excess altitude off on final or landing in a cross wind.
Big John
On Sun, 09 Nov 2003 23:12:40 GMT, Robert Moore
Bob
Old November 10th 03, 07:06 AM
Peter
Big John wrote:
Robert
As a lurker here who has never and will never do a single loop or roll, it
seems to me you two are both describing exactly the same maneuver but using
slightly different words.
Both you and Bob agree that the barrel roll consists of having the airplane
follow a corkscrew path as if it were following the inside wall of an
imaginary barrel, or tube, in the sky.
If the plane were to roll while going straight down the long axis of the
tube it would be an ordinary "slow" roll. OTOH, if the plane were flying
along the inside circumference (i.e. at 90 degrees to the long axis) of the
tube it would be doing loops. The corkscrew path of a barrel roll is
halfway between these two situations (i.e. at about a 45 degree angle to
the long axis of the tube), so it doesn't seem unreasonable to describe it
as the combination of a loop and a roll.
??Build rolling tool chest? Michael Horowitz Owning 15 January 27th 05 04:56 AM
Rolling Thunder Mortimer Schnerd, RN Military Aviation 10 June 14th 04 12:49 AM
B-52 crew blamed for friendly fire death Paul Hirose Military Aviation 0 March 16th 04 12:49 AM
Defensive circle Dave Eadsforth Military Aviation 23 October 9th 03 06:13 PM
Talk about runway incursions... Dave Russell Piloting 7 August 13th 03 02:09 AM
