I don't like situational instruction, where one action is required under one
set of circumstances and a different action is required under a different set of circumstances. Teach one procedure that works all the time. Bob Gardner "BoDEAN" wrote in message ... How many people do / teach doing a full before landing checklist when doing pattern work? I do with my students, but other cfi's I work with use a quick / abbreviated one for our Cessna 172/152 |
In article F9vqb.94384$ao4.279861@attbi_s51,
"Bob Gardner" wrote: I don't like situational instruction, where one action is required under one set of circumstances and a different action is required under a different set of circumstances. Teach one procedure that works all the time. There AIN'T no such thing! If you have an emergency, you're screwed with that policy! "BoDEAN" wrote in message ... How many people do / teach doing a full before landing checklist when doing pattern work? I do with my students, but other cfi's I work with use a quick / abbreviated one for our Cessna 172/152 |
I've had my share of emergencies, Orval, in singles and twins, and I stand
by my comments. Bob Gardner "Orval Fairbairn" wrote in message news ![]() In article F9vqb.94384$ao4.279861@attbi_s51, "Bob Gardner" wrote: I don't like situational instruction, where one action is required under one set of circumstances and a different action is required under a different set of circumstances. Teach one procedure that works all the time. There AIN'T no such thing! If you have an emergency, you're screwed with that policy! "BoDEAN" wrote in message ... How many people do / teach doing a full before landing checklist when doing pattern work? I do with my students, but other cfi's I work with use a quick / abbreviated one for our Cessna 172/152 |
one set of circumstances and a different action is required under a different set of circumstances. Teach one procedure that works all the time. There AIN'T no such thing! If you have an emergency, you're screwed with that policy! No! You're screwed when you DON'T follow pre-planned / pre-trained procedures during an emergency. |
"Kiwi Jet Jock" wrote: I don't like situational instruction, where one action is required under one set of circumstances and a different action is required under a different set of circumstances. Teach one procedure that works all the time. There AIN'T no such thing! If you have an emergency, you're screwed with that policy! No! You're screwed when you DON'T follow pre-planned / pre-trained procedures during an emergency. You're screwed if the emergency lies outside your preplanned actions! If you depend on rote learning while flying, you have no business in the cockpit! Checklists are fine, but are NOT the answer to everything! As I pointed out earlier, having your nose buried in a checlist while in the traffic pattern is not the smartest or safest use of your attention and eyesight. |
out earlier, having your nose buried in a checlist while in the traffic pattern is not the smartest or safest use of your attention and eyesight. The 'answer to everything' is training, and then following those learned procedures - that's why we spend hundreds of hours in simulators before being let loose on heavy metal. Checklists are an essential part of that cockpit discipline - as is 'Aviate - Navigate - Communicate'. What drops so many pilots in the proverbial brown stuff is the lack of cockpit discipline - a belief that it "won't happen to them" and if it does then "I'll sort it out at the time". As an example, a trained, professional pilot (flying heavy metal) - following training & procedures - would not attempt to abort a takeoff after V1 if, for example, they get an engine fire indication - The initial actions of those NOT following procedures is to let all of their attention focus on the 'problem' - panic - and take a psudo-random course of action (eg trying to abort - or shutting down the wrong engine) that gets everyone killed. At an elementary level pilots often "get away" with not following formalised procedures in light single-engine GA aircraft (although it still kills far to many people each and every year) - but the lack of discipline sets you up to fail as you progress to higher performance aircraft - too many GA pilots cut too many corners (starting with a lack of cockpit discipline) - these bad habits stay with them as they accumulate more and more hours in bigger and faster aircraft - until one day a few peripheral circumstances change and they get caught with their "proverbial pants down." As humans we all make mistakes and we forget things - especially when the pressure is on - by using checklists in many areas of aviation we ensure that we DON'T forget things - things like lowering the gear in a retractable - things like terminating flightplans - Things like feathering a prop on a dead engine. When was the last time someone who flies using a checklist landed a retractable with the gear up? This 'nose buried in a checklist / lack of attention' argument is a crock - as pilots being able to effectively task-switch is a requirement that comes with being PIC. I can complete a 9 point pre-landing checklist in a high performance light twin in under 12 seconds @ 140 knots downwind - whilst keeping an effective lookout - and occasionally talking to the tower in the middle of it. Once the item is read, most of the items are carried out with eyes looking outside the cockpit - you shouldn't have to look to identify parking brake - mixtures - pitch - aux pumps - autopilot disconnect etc. If you can't perform comfortably at this level whilst maintaining your lookout and situational awareness then you shouldn't be in the left hand seat. There is no emergency that can't be made worse by not following procedures. Get used to using checklists. Everytime. |
BoDEAN wrote: How many people do / teach doing a full before landing checklist when doing pattern work? I do with my students, but other cfi's I work with use a quick / abbreviated one for our Cessna 172/152 Define 'full'? I mostly fly C152 and GUMP pretty much covers everything. I do speed/flaps as I fly the pattern. |
David Megginson wrote: ('Vejita' S. Cousin) writes: Define 'full'? I mostly fly C152 and GUMP pretty much covers everything. I do speed/flaps as I fly the pattern. What do you do for the "U" and "P" in a 152? Check gear is down and welded. Check prop pitch is fixed. Actually when I was a student I did ![]() checklist is: 1. Seatbelts secure 2. Fuel both (not really necessary as I check this prior to takeoff too) 3. Mixture (as needed, normally full rich) |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
