![]() "John Galban" wrote in message om... (Rick Durden) wrote in message om... John, Specifically, you should not be leaning if your engine in making 75% power or better. Not necessarily so. It is perfectly okay to lean at 75% power, the manual for your airplane has a fuel burn for 75% with lean mixture. In fact, if you don't lean when operating at 75% with that Lycoming, you will significantly reduce your range and endurance and possibly foul the plugs. www.gami.com has a good discussion of leaning and what's going on during combustion. It may be perfectly okay to lean at power settings above 75%. OK, perhaps I didn't include enough information. For the Lycoming engines found in most common Cessnas & Pipers, Lycoming manuals usually have caution against leaning above 75% power. Perhaps I should have reworded my comment above to read "76%" or "75.5%". http://www.avweb.com/news/columns/186015-1.html November 9, 2003 Pelican's Perch #75: Those Dreadful POHs (Part 1) Everything your POH says is correct, and anything it doesn't say you can do, you can't, right? Did you really think John Deakin -- AVweb's favorite contrarian -- could let that kind of gross generality continue unquestioned? I've seen exhaust valves from engines that were run at high power settings while leaned to just below peak. They were not pretty (and would not hold compression). http://www.avweb.com/news/columns/183094-1.html March 2, 2003 Pelican's Perch #66 Where Should I Run My Engine? (Part 4 -- Descent) After a short discussion about whether running engines the factory way or the skydiving way will hurt or help engines, AVweb's John Deakin settles in for the descent. And, yes, there are more old wives tales to be debunked, and better control settings to use. ----------------------------------------- http://www.avweb.com/news/columns/182583-1.html February 2, 2003 Pelican's Perch #65 Where Should I Run My Engine? (Part 3 -- Cruise) Cruise -- Time to sit back and enjoy the flight. But wait ... did you leave the mixture set where it was during the climb? Or do you just set it where it ------------------------------------------------ Picture, charts, loads of data... Deakin makes some very strong points that much of what has been presented in POH's over the last several (read: 30 or more) years has been downright BOGUS. Tom -- "What's our vector, Victor?" |
David Megginson wrote in message ...
(John Galban) writes: I've seen exhaust valves from engines that were run at high power settings while leaned to just below peak. They were not pretty (and would not hold compression). Was it heat damage? I'd imagine that they'd be even worse if they were leaned to just above peak. Yes, it was heat damage. The plane in routinely ran leaned at about 85% power for about 150 hrs. Two of the 4 exhaust valves were toasted. On a well instrumented engine you could probably get away with leaning at higher power settings. I think the reason Lyc. puts the limit at 75% is that the average spam can does not have enough instrumentation to keep all cylinders in the green during all types of operation. John Galban=====N4BQ (PA28-180) |
Just above peak?
Paul "David Megginson" wrote in message ... Was it heat damage? I'd imagine that they'd be even worse if they were leaned to just above peak. |
true
"Thomas Borchert" wrote in message ... Btiz, Some will argue it is not needed to lean below 3000MSL.. Uh, only those clinging to one of the more stupid OWTs (Old Wive's Tale). -- Thomas Borchert (EDDH) |
So I invested my US$6°°.....GUESS WHAT!!!... less than ten days later, I received money | [email protected] | Owning | 1 | January 16th 05 06:48 AM |
Glue for wing step grippy thingies | Steven Barnes | Owning | 6 | November 28th 04 09:56 PM |
Re; What do you think? | Kelsibutt | Naval Aviation | 0 | September 29th 03 06:55 AM |
STEP program helps advance hundreds of hand-picked airmen | Otis Willie | Military Aviation | 0 | September 19th 03 09:15 PM |
