DC-10s as Water Bombers?
Old November 10th 03, 09:30 PM
G.R. Patterson III
Peter Duniho wrote:
Maybe you should share your
expertise with those operating such airplanes as the Martin Mars (originally
designed as a military troop transport, now used *only* for fire fighting)
The Mars was originally designed as a reconnaissance bomber, filling the role
of the Catalina. It semms, however, that none of the original bomber versions
were ever built. Martin then designed a transport version of the plane, but
orders for it were reduced with the end of WW II, and only five transport
versions were built. Four of them served well as transports during Korea. So,
while it's true that the existing aircraft were based on a bomber design, it is
equally true that all Mars aircraft produced were designed originally as
transports.
Source: "Wings Over Water", David Oliver.
George Patterson
If you're not part of the solution, you can make a lot of money prolonging
the problem.
Old November 11th 03, 11:04 PM
Big John
Pete (I think it's your post?)
Need to add a few pennies.
On Sun, 9 Nov 2003 11:53:52 -0800, "Peter Duniho"
"R. Hubbell" wrote in message
news:gUsrb.10899$7B2.8992@fed1read04...
I don't know anything about that plane but I do know that any plane that
was designed for passenger carrying doesn't make a great platform for
delivering fire retardants.
You "know" that? How do you "know" that? Maybe you should share your
and the C-130 (commonly used to carry passengers). Against all odds
(apparently) those airplanes have seen great success as water bombers, as
have other "passenger" aircraft (the DC-6 comes to mind).
C-130 is a cargo plane and so structurally designed by Lockheed. To
haul passengers they have canvas seats that fold down from walls of
cargo area. The floor is strong enough (they carry fighting vehicles
in the cargo area) they can just build a tank and tie in the cargo
area with the ramp open and nozzles on the tank(s) they can air drop
the 'water'. Easy, cheap conversion. Think I have also seen some
commercial conversions with the nozzles built into the fuselage and
they can drop with the ramp closed.
There are some ANG and AFR C-130's that have the ability to fight
fires. There are six MAFFS (Modular Airborne Fire Fighting System)
systems (in the whole US) that can be used to configure birds in two
Squadrons (one ANG and one AFR) for fire fighting. System holds 3000
gallons and dumps over the open ramp. They are not used very often
(for political reasons) as the laws say that Fire Fighting Companies
must be hired first before any Military birds are used. That's so the
Military don't take any jobs away from civilians.
Since you didn't know this from your post apparently, you now do. All
can be validated on the Internet with a little searching.
Regarding the Mars, read the following extracted from Mars history.
Quote
Martin continued test flights on the aircraft until November 1942,
when the Old Lady was passed on to the Navy. By this time the Navy had
decided that big lumbering easy-target patrol bombers were not such a
good idea after all, and the flying boat was converted to a cargo
aircraft before it was handed over. All the turrets and guns, bomb
bays, and armor plate were removed, cargo-loading hatches and
cargo-loading equipment were installed, and the DECKING WAS
REINFORCED. The modified aircraft was designated XPB2M-1R.
Unquote
You can see that these aircraft were converted to a cargo
configuration by Martin before delivering to the Navy. Further
conversion to a fire fighting airplane would be easy (cheap) since
they are structurally cargo aircraft.
Passenger aircraft can be converted to haul 'water' but doing so is
not very cost effective due to the major remanufacturing required.
Ask Fedex what it costs them to convert a passenger aircraft taken out
of service by the airlines to a cargo configuration so they can load
the pallets to haul their packages. Have seen some figures in AW & ST
of several million dollars per airframe to remanufacture..
Maybe this info will stop the finger pointing and cat and dog fight
on this thread?
Bottom line is to work to get equipment to drop water/retardent to
control/ put out forest fires. Dirty, dangerous work.
Local well know duster was killed working on a fire out west a couple
of years ago when he hit a wire in a canyon. Looked back in the smoke
to check his drop and zap. His partner (friend of mine) quit dusting
and shut down their operation here. He died less that a year later of
cancer ( Guess when your times up it's up.
Big John
Don't have all the specifics but apparently it's the
differences in the "cargo" that makes them poor for fire duty.
How can you "know" what you claim to know, and yet not have the specifics?
You seem to have a pretty low threshold for "knowing" something.
There has been some debate recently on this topic and in a perfect world the planes
should be designed as retardant delivery platforms from the ground up.
Sure, in a perfect world EVERY airplane would be designed from the ground up
for the specific purpose for which it will eventually be used. That goes
without saying.
But we don't live in a perfect world. It turns out that passenger aircraft
ARE quite capable of being converted to water bombers, they perform just
fine as such, and it's often more economical to operate such an airplane
rather than a purpose-built water bomber (I can only think of two
purpose-built water bombers off the top of my head, and you can bet they are
expensive).
(no pun intended)
I didn't see anything even resembling a pun. I guess you're off the hook on
that one.
Pete
Old November 10th 03, 04:26 AM
G.R. Patterson III
"R. Hubbell" wrote:
I don't know anything about that plane but I do know that any plane that was
designed for passenger carrying doesn't make a great platform for delivering
fire retardants.
You know this how? The miltary has been using that plane as a tanker for
decades. It should make a fine fire bomber.
George Patterson
the problem.
Old November 10th 03, 06:56 AM
Peter Duniho
"G.R. Patterson III" wrote in message
was
delivering
fire retardants.
Obviously, he doesn't actually know.
Pete
Old November 12th 03, 08:47 AM
Chuck Forsberg WA7KGX
A widebody jet converted to fire bomber would involve
different tradeoffs and tactics. It would be a whole
new ball game.
Last time I flew over Victorville there were many airframes
waiting for something to do.
Chuck Forsberg www.omen.com 503-614-0430
Developer of Industrial ZMODEM(Tm) for Embedded Applications
Omen Technology Inc "The High Reliability Software"
10255 NW Old Cornelius Pass Portland OR 97231 FAX 629-0665
Old November 16th 03, 05:28 AM
R. Hubbell
On Wed, 12 Nov 2003 00:47:15 -0800
new ball game.
Chuck Forsberg of ZMODEM fame, this is a blast from the past. I remember
buying a license for ZMODEM back in the day. I guess ZMODEM has done you
well. Congrats.
R. Hubbell
Old November 12th 03, 01:13 AM
Big John
G.R.
What kind of a Military tanker???
Who refueled?
It's so slow I don't think the early jets, when they started being
eqipped with refueling probes, could slow down enought to refuel from
the Mars.
Don't know of any prop Fighters that ever had air refueling
capability.
Know the B-47 and B-52 could not refuel from the Mars. Nor did they
ever try to.
Big John
On Sun, 09 Nov 2003 23:26:12 -0500, "G.R. Patterson III"
fire retardants.
George Patterson
the problem.
Old November 12th 03, 03:24 AM
G.R. Patterson III
From the tone of your post, it seems you think I claimed the Mars was used as
a tanker. I was talking about the DC-10.
The DC-10 was and is used as a tanker. I do not remember the military
designation, but our flying club was granted a tour of one at McGuire AFB two
years ago. You can also see one in the Harrison Ford movie where the pres gets
hijacked ("Air Force One??).
George Patterson
the problem.
Old November 12th 03, 05:28 AM
Big John
G.R.
My pardon. Talk was about the Mars and I just followed my nose and
missed the 'Y' in the road and conintued on the Mars thread.
USAF bought 60 'Extenders" but I've never seen one refueling as they
came into service after I retired.
Also don't have any feed back from the jocks who flew them.
They are not being mentioned in the cat and dog fight over the 767.
Only the old 135 (E's).
Big John
On Tue, 11 Nov 2003 22:24:21 -0500, "G.R. Patterson III"
George Patterson
the problem.
Old November 12th 03, 03:56 PM
Ron Natalie
"G.R. Patterson III" wrote in message ...
designation
KC-10
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Night of the bombers - the most daring special mission of Finnishbombers in WW2 Jukka O. Kauppinen Military Aviation 4 March 22nd 04 11:19 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
water bombers Stew Hicks Home Built 2 September 8th 03 11:55 PM
water bombers Stew Hicks Home Built 0 September 7th 03 04:27 PM
