Corky,
At the risk of sounding completely naive (I know nothing of welding) couldn't you replace the lens/filter in the full face shield you were using with a TM2000 lens/filter? Russell Kent |
Looks like you have gotten some good advise from others in the group.
I'll back up some of that. MIG would be great for assembling a swing set, but it is not a good choice for assembling a 4130 tube fuselage. It is not just about control of the weld on thin tube but also about final strength and durability of the welds. The skill you develop with the oxy/acet torch will serve you well if you ever wish to convert to TIG. A TIG unit would be a possible choice, requiring only a bit more skill that the oxy/acet torch. Its primary drawback is the cost. There are some very good deals out there these days on units like the Lincoln 175 or 185 Pro series of TIG welders....but you can buy 3 or 4 of the best acet. outfits available for that kind of money. And in the end the welds will not likely be superior to the oxy/acet welds. As for tools: A good hacksaw and/or a tubing cutter; a bench grinder with at least an 8" wheel; I really like a 4.5" angle grinder to help with coping the fit up; a few clamps and a magnetic positioner is a good investment. A 6" bench vise. I would also suggest a good quality dressing tool for the bench grinder. Dress the grinding wheel so it has a radiused face rather than the normal square face. This will really help shape the fish mouth weld joints. As for the grinder itself, someone suggested, I think it was Orval, getting a good bench grinder. I used to agree with that idea, but twenty five years ago I bought the least expensive Taiwan bench grinder I could find. I have used it in two metal fabrication businesses and years more in my garage shop. I have replaced the electrical push/pull switch once with a toggle. The unit still runs strong. I have been lucky but the cheapest bench grinders will probably out last 5 or 10 projects. Ed wrote: Eventually I plan to build a tube-n-fabric aircraft, but now isn't the time. However, I would like to start developing the skills that I will need. I've been looking at kids playsets for our yard. Most of them are made from redwood, and are quite expensive. Several thousand dollars for the more complex ones. Pressure treated lumber is much cheaper, but I don't want my kids crawling on it. Today I got an idea. I could build a frame out of steel tubing, get it powdercoated, and then deck it with the composite synthetic decking that is becoming popular for backyard decks. Such a structure would be strong, durable, impervious to the elements, and would give me an excuse to learn to weld. What are the minimum set of tools I'd need to buy to complete the project? I know I'd need an OA torch. What tools would I need for the cutting, shaping, and prepping of the steel tubing? Any other suggestions on construction and materials, especially steel type? -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding While trying to find the time to finish mine. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
