Corky Scott wrote:
Ah, sorry, I did not describe the face shield properly: It's a full plexiglass shield, not a face shield with a little window in it. Yes, had it been the face shield with the window in it, I could have replaced that window with the tinted glass from Tinman. But I would have experienced the same problematic cutting off of the lower field of view that I need for proper focusing. Using the plexiglass face shield, you don't have to worry about cutting off your field of vision, the entire shield is see through tinted plastic. Does that explain things better? Yes, much. So theoretically you could cut a rectangular window in the plexiglass shield (positioned appropriately for your vision issues) and insert the tinted glass rectangle from Tinman. That way your primary field of vision is properly protected, yet you still have some secondary field vision, too. I have no idea if this is workable, however. Russell Kent |
![]() "Corky Scott" wrote in message ... On Tue, 23 Mar 2004 09:55:04 -0600, Russell Kent wrote: Corky, At the risk of sounding completely naive (I know nothing of welding) couldn't you replace the lens/filter in the full face shield you were using with a TM2000 lens/filter? Russell Kent Ah, sorry, I did not describe the face shield properly: It's a full plexiglass shield, not a face shield with a little window in it. Yes, had it been the face shield with the window in it, I could have replaced that window with the tinted glass from Tinman. But I would have experienced the same problematic cutting off of the lower field of view that I need for proper focusing. Using the plexiglass face shield, you don't have to worry about cutting off your field of vision, the entire shield is see through tinted plastic. Does that explain things better? Corky Scott Why don't you get a pair of custom bifocals? You can get them with the bottom 2/3rds of the lens the strong part, with just a bit over the top for distance vision. I have a pair like that, and the difference is remarkable. No more stiff neck. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.629 / Virus Database: 403 - Release Date: 3/17/2004 |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
