link.net... What is used for IFR clearances? "Paul Sengupta" wrote in message .. . "Your clearance is...x to y to z via w (or whatever)" I think that's likely to confuse the issue, Paul. Here's the example from CAP 413 the Radiotelephony Manual, which is typical of IFR clearances in my experience. "Fastair 345 is cleared to Kennington via A1 at FL 60, request level change enroute, squawk 5501" There's no significant difference in phraseology. Julian Scarfe |
"John Harper" wrote in message
news:1069786900.839440@sj-nntpcache-3... Actually there are some changes as a result of Tenerife. For example in the UK the word "cleared" is used only in "cleared for takeoff". Other uses (e.g. for taxi) use some other word, "permission" iirc. That's not quite the case, though you're on the right lines. In the UK (and in other states that adhere to ICAO phraseology) the words *"take-off"* are only used as part of a clearance to take off. Prior to that the word "departure" is used: ATC: "G-ABCD after departure turn left heading ya de ya de ya... " (might include an IFR clearance) Aircraft:"After departure turn left heading ya de ya de ya... G-ABCD" .... Aircraft: "G-ABCD ready for departure" ATC: "G-ABCD cleared for take-off" Aircraft: "Cleared for take-off, G-ABCD" You're correct that there's no "clearance" to taxi but I think that's the same everywhere. So there's no problem with reading an IFR clearance, since there's no taboo on "clearance" or "cleared". The issue identified at Tenerife was, to borrow Ron's transcript, not the CLEARED, but the TAKE-OFF KLM: KLM 4805 is now ready for takeoff, and we're waiting for our ATC clearance. TWR: KLM 8705 you are cleared to the papa beacon climb to and maintain flight level 290 right turn after TAKE-OFF proceed with heading 040 until intercepting the 305 radial from Las Palmas VOR. KLM: Roger sir, we're cleared to the Papa Beacon flight level 90, right turn out 050 until intercepting the 305 and we're now at TAKE-OFF . TWR: OK. Stand by for take-off, I will call you. PAN: We're still taxiing down the runway, Clipper 1736 As well as the potential confusion over the tower's use of "take-off" in the clearance (which was at the time perfectly acceptable practice, BTW), the second use of the words by the crew would or should ring alarm bells in a UK ATCO's mind as to whether the aircraft had properly understood that they were to hold. Evidently if raised some doubt in the tower controller's mind, but not enough for him to demand an acknowledgement. Julian Scarfe |
DeltaDeltaDelta wrote:
Recently I dug up an article from some magazine concerning the Tenerife accident when two 747s collided due to language miscomprehension by one of the pilots. I thought the Tenerife accident happened because the KLM captain suffered from excessive self-esteem. Dave Remove SHIRT to reply directly. |
This may have been after they started rolling and the 1st officer tried
to question whether they had actually been cleared for take-off. The big thing is that the words "take-off" can now not be used other than "cleared for take-off". It may be the case that the Dutch captain heard the words "cleared" and "take-off" and thought that was his cue to go. Paul "Dave Butler" wrote in message ... I thought the Tenerife accident happened because the KLM captain suffered from excessive self-esteem. |
![]() "Paul Sengupta" wrote in message ... This may have been after they started rolling and the 1st officer tried to question whether they had actually been cleared for take-off. The big thing is that the words "take-off" can now not be used other than "cleared for take-off". It may be the case that the Dutch captain heard the words "cleared" and "take-off" and thought that was his cue to go. ATC never used the C-word. While PanAm was still taxiing on the runway KLM was told, "OK. Standby for takeoff. I will call you." KLM then began takeoff roll, ATC's next transmission was to PanAm: ATC: "Roger. Pan Am 1736, report the runway clear." Pan Am: "OK. Will report when we are clear." ATC: "Thank you." The KLM CVR recorded the copilot saying to the captain, "Did he not clear the runway then?" "Oh yes" was the captain's reply as he continued his takeoff. |
![]() "Steven P. McNicoll" wrote in message hlink.net... ATC never used the C-word. While PanAm was still taxiing on the runway KLM was told, "OK. Standby for takeoff. I will call you." KLM then began takeoff roll, ATC's next transmission was to PanAm: KLM: KLM 4805 is now ready for takeoff, and we're waiting for our ATC clearance. TWR: KLM 8705 you are CLEARED to the papa beacon climb to and maintain flight level 290 right turn after take-off proceed with heading 040 until intercepting the 305 radial from Las Palmas VOR. KLM: Roger sir, we're cleared to the Papa Beacon flight level 90, right turn out 050 until intercepting the 305 and we're now at take-off. TWR: OK. Stand by for take-off, I will call you. PAN: We're still taxiing down the runway, Clipper 1736 They did use the C word in delivering the IFR clearance. The CVR out of the KLM shows the captain saying (in Dutch) "we're going" between the OK and the Stand By instruction. |
Ron Natalie wrote: TWR: OK. Stand by for take-off, I will call you. PAN: We're still taxiing down the runway, Clipper 1736 They did use the C word in delivering the IFR clearance. The CVR out of the KLM shows the captain saying (in Dutch) "we're going" between the OK and the Stand By instruction. And the transmission from PAN was stepped on. -- Ben Jackson http://www.ben.com/ |
![]() "Ron Natalie" wrote in message . .. KLM: KLM 4805 is now ready for takeoff, and we're waiting for our ATC clearance. TWR: KLM 8705 you are CLEARED to the papa beacon climb to and maintain flight level 290 right turn after take-off proceed with heading 040 until intercepting the 305 radial from Las Palmas VOR. KLM: Roger sir, we're cleared to the Papa Beacon flight level 90, right turn out 050 until intercepting the 305 and we're now at take-off. TWR: OK. Stand by for take-off, I will call you. PAN: We're still taxiing down the runway, Clipper 1736 They did use the C word in delivering the IFR clearance. The CVR out of the KLM shows the captain saying (in Dutch) "we're going" between the OK and the Stand By instruction. Yes, they used the C-word in delivering the IFR clearance. How would they issue an IFR clearance without using it? But Paul Sengupta wrote, "It may be the case that the Dutch captain heard the words "cleared" and "take-off" and thought that was his cue to go." ATC said "OK. Stand by for take-off, I will call you." No C-word. |
Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | Aviation Marketplace | 1 | January 13th 04 08:26 PM |
Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | General Aviation | 1 | January 13th 04 08:26 PM |
MSNBC Reporting on GA Security Threat | Scott Schluer | Piloting | 44 | November 23rd 03 02:50 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
