(Rick Durden) wrote
In Alaska, Part 135 operators can get the max gross raised by up to 15%, depending on the airplane. Do you have a reference for this? You bet. 14CFR91.323 I've chased it a couple of times but can't find it (I'm assuming I'm looking in the wrong places); all I've found is for an increase for a few very old Dept of Commerce or CAA certified airplanes such as Stinson Trimotors and so forth, nothing modern. Really modern airplanes are not eligible for this, but a lot of stuff a whole lot newer than Trimotors is. If you've got a reference, I'd appreciate it. Here you go. A great web site for this stuff is http://www.access.gpo.gov/nara/cfr/c.../14tab_00.html 14CFR91.323 Increased maximum certificated weights for certain airplanes operated in Alaska. (a) Notwithstanding any other provision of the Federal Aviation Regulations, the Administrator will approve, as provided in this section, an increase in the maximum certificated weight of an airplane type certificated under Aeronautics Bulletin No. 7-A of the U.S. Department of Commerce dated January 1, 1931, as amended, or under the normal category of part 4a of the former Civil Air Regulations (14 CFR part 4a, 1964 ed.) if that airplane is operated in the State of Alaska by -- (1) A certificate holder conducting operations under part 121 or part 135 of this chapter; or (2) The U.S. Department of Interior in conducting its game and fish law enforcement activities or its management, fire detection, and fire suppression activities concerning public lands. (b) The maximum certificated weight approved under this section may not exceed -- (1) 12,500 pounds; (2) 115 percent of the maximum weight listed in the FAA aircraft specifications; (3) The weight at which the airplane meets the positive maneuvering load factor requirement for the normal category specified in §23.337 of this chapter; or (4) The weight at which the airplane meets the climb performance requirements under which it was type certificated. (c) In determining the maximum certificated weight, the Administrator considers the structural soundness of the airplane and the terrain to be traversed. (d) The maximum certificated weight determined under this section is added to the airplane's operation limitations and is identified as the maximum weight authorized for operations within the State of Alaska. [Doc. No. 18334, 54 FR 34308, Aug. 18, 1989; Amdt. 91-211, 54 FR 41211, Oct. 5, 1989, as amended by Amdt. 91-253, 62 FR 13253, Mar. 19, 1997] |
I began wondering
about the effects of an overweight takeoff within C.G. limits. This is impossible. As soon as you go over gross you are out of CofG by definition. Paul |
"Paul Cook" wrote in message
... I began wondering about the effects of an overweight takeoff within C.G. limits. This is impossible. As soon as you go over gross you are out of CofG by definition. I guess that depends on how you define "out of CofG". I define it as not within the fore and aft limits for the position of the center of gravity. Under that definition, you certainly can still be within those limits while being above the maximum gross weight. I prefer to use the term "out of weight & balance limits" as the general term for being overweight or out of the CG limits or both. Though, if only overweight or out of CG limits, I'd actually prefer to just use the term that actually describes the condition. Pete |
"Paul Cook" wrote:
This is impossible. As soon as you go over gross you are out of CofG by definition. Paul Actually not by definition. CofG (Centre of Gravity) is the balance part of weight and balance. It is measured in distance from a datum. There are no weight units in CG. |
"Koopas Ly" wrote in message
om... Climbout: same angle of climb for obstacle clearance at higher Vx speed. Almost. It should be the same *angle of attack* (and higher speed) for best angle of climb. But the angle of climb itself (and the pitch angle) will be less than when within max gross weight. Consider the limiting case where the aircraft is so heavy it can barely climb; the best angle of climb will then be just slightly above zero. Similarly, pilots who are not accustomed to high-altitude takeoffs can get in trouble if they try to set up the same pitch attitudes they're used to at lower altitudes for best-rate or best-angle climb. Due to the lower angle of climb at higher density altitudes, commanding the usual pitch altitude implies a higher angle of attack than usual, and hence a danger of stalling. --Gary |
Gary,
Thank you for the correction. Everything you wrote makes sense. Could you please take a peak at my most recent thread entitled "Angle of climb at Vx and glide angle when "overweight": five questions". I added a clarification post in response to Mr. Gerry Caron's reply, within that thread, so I'd appreciate if you could tackle some of my questions. Thanks, Alex "Gary L. Drescher" wrote in message news:YBnxb.238322$ao4.855590@attbi_s51... "Koopas Ly" wrote in message om... Climbout: same angle of climb for obstacle clearance at higher Vx speed. Almost. It should be the same *angle of attack* (and higher speed) for best angle of climb. But the angle of climb itself (and the pitch angle) will be less than when within max gross weight. Consider the limiting case where the aircraft is so heavy it can barely climb; the best angle of climb will then be just slightly above zero. Similarly, pilots who are not accustomed to high-altitude takeoffs can get in trouble if they try to set up the same pitch attitudes they're used to at lower altitudes for best-rate or best-angle climb. Due to the lower angle of climb at higher density altitudes, commanding the usual pitch altitude implies a higher angle of attack than usual, and hence a danger of stalling. --Gary |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
