LED tail strobe
Old April 21st 04, 10:24 PM
anonymous coward
Something I've been pondering...
4 Luxeon star 1W emmitters in parallel will draw 1A or so. Your 555 based
timer circuit will draw large(ish) currents for short periods of time,
because of the small mark:space ratio. Might this interfere with other
systems powered by the battery?
The switching regulators for standard Xenon flash tubes draw a lower
but much more constant current (though goodness knows they can generate
radio noise if they're not shielded right).
AC
On Sat, 17 Apr 2004 23:25:24 -0700, Jay wrote:
I think someone may have already pointed this out, and maybe I didn't
make it as clear as I should have... I stacked the forward drop of
MULTIPLE LEDs up until I got somewhere near the bottom end of the
supply voltage. So for the example I gave, I got to 4 LEDS in series.
Why waste all that power as long IR (heat) off a big resistor when we
want red and green light right?
Regarding 2.8V- The forward drop of these devices now-a-days is all
over the place. The new chemistries seem to be making higher forward
drops, plus the trend is to package multiple die into one larger
device and this can effect the forward drop of the composite device.
By the way, anyone building my circuit should try one instance of it
(4 LEDS and resistor) on your bench supply before you go fly at night
cross country.
Jim Weir wrote in message . ..
Before everybody in the Western Hemisphere blows a bucket full of light emitting
diodes, would you care to calculate the resistor one more time? And perhaps
post a retraction?
(Jay)
-You can find examples on how to power the LEDs on the manufacturer web
-site.
-Having said that...
So lets say the recommended current for
-the LED is 20mA. Ohms law is R=E/I, so that gives you a resistor
-value of .3V/.02A=15 ohms.
Um, no. Suppose the diode has a forward voltage drop of 2.8 volts (that's not a
common value, but I'll give it to you for argument.
Now the power supply (battery) is a 12 volt supply, but 14.2 volts at full
charge with the alternator going, so the drop across the series resistor is
going to be
14.2 minus 2.8 equals 11.4 volts, which is the voltage across the resistor.
This current limiting resistor is going to have 20 mA flowing through it, so Ohm
tells us that resistance equals voltage divided by current. In this case, 11.4
volts divided by 20 mA gives us a resistor of 570 ohms (560 is the nearest
standard value).
You put your calculated 15 ohm resistor in series with this diode and I
guarantee you that the SNAP you hear is the gallium aluminum arsenide
semiconductor of the diode being sacrificed on Ohm's altar.
I'm serious. You owe the newsgroup a correction before somebody takes your
error and blows up a whole bunch of LEDs.
http://www.rst-engr.com
Old April 17th 04, 01:34 PM
GeorgeB
On 16 Apr 2004 22:15:44 -0700, (Jay) wrote:
What is typically done is the LEDs are just put in series with a
current limiting resistor. This forms a circuit akin to a kind of
voltage regulator called a "zener regulator". LEDs have a fixed
forward voltage for the recommended drive current, say for example its
2.8 volts for a green LED. Divide the power supply (e.g. 12V) by the
forward voltage of the LEDs and drop any fraction (12/2.8=4.3 make
that 4 even) Put those in series with a current limiting resistor that
will drop the fraction (.3V).
Your concept is reasonable, but there are some significant problems.
The forward voltage varies with temperature, and the power supply
LIKELY varies over time. As you have it, if the fwd voltage dropped
0.1v, and the supply did not change, you would have 0.7 vs 0.3 across
the resistor, for over 2x the current ... maybe a real problem.
Now, let's have the alternator charging the battery, and have it at
15.5V or so ... now I have 3.8 volts across that current determining
resistor ... 12 times the "design". OUCH.
Now let's have the alternator fail, the battery voltage drop to 10.5V.
Your series string will draw no current and give no light ... and you
are in an emerency situation that is exactly when someone needs to see
you.
What is the solution ...
There are "constant current" devices. I have used them, and they
work allowing operating this string with probably 3 LEDs over the
range at visually constant brightness.
You can put 2 in a string allowing the current determining resistor to
allow a power range varying over about 2:1, 10V to 15V.
You can put 3 in a string like above, power will vary over about 4:1.
You can design a pulse system turning the LED on for (maybe) 0.1ms
then off for maybe 5ms and PROBALBY not overdrive (into damage) the
LED and put "as many" as you want in parallel. The driver will likely
be a FET.
value of .3V/.02A=15 ohms. Check power to make sure it won't over
heat (P=IV) so thats .3V*.02A=.006W so a typicial 1/4 watt resistor is
fine. You must of course have some kind of resistor in series to limit
the current. If you math works out that you need no resistor, put one
less LED in series and then recalculate the limiting resistor. Put
the LEDs and resistor in series (in any sequence) observing the proper
polarity of the LEDS.
I was taught to allow about half the voltage for the resistor, half
for the LED string unless I had current control. In the "old days",
for current control we used an emitter resistor in a common emitter
circuit, 2 or 3 diodes to set bias (single vs darlington), and the
LEDs between collector and V+. There are other (better) ways, but
everyone understood this one.
If you hook up your entire string backwards, no
harm will be done, but if you happen to solder one LED backwards, it
will likely be toasted on power up.
I disagree that there will be damage with any in backwards. The
reverse voltage will almost certainly be higher than the forward
voltage, so there won't be any current drawn. If there is, you still
would have less than correctly wired.
Need more than 4 LEDS? Replicate this circuit in parallel as many
times as you need to get the luminous flux you need.
Of course the numbers (Vf, If) used here are for the older style
single chip LEDS. The parts that are getting everybody excited these
days are the multi-chip variety whose forward voltage and current will
vary alot from my example.
"Dean Head" wrote in message .. .
Jeff,
Would you consider sharing your design for the driver electonics?
Dean
Cozy MK4
BKV FL
"Jeff Peterson" wrote in message
om...
I am building an LED tail light for my Lancair 360. It uses 6 ea 5
watt luxeon LEDs. I can strobe 1 amp through each of these which
should give enough light to satisfy the FAA regs. Runs surprisingly
cool. I have posted photos he
http://w1.lancair.net/pix/album01\
Its not quite finished, but I thought you might like to see my
progress.
cheers,
Jeff
N273CK stilll building.
ps thanks to Eric Jones for his posts on the Lancair Mail List, his
web pages on the subject and many emails and phone calls.
Old April 18th 04, 07:15 AM
Jay
Read comments below...
GeorgeB wrote in message
Indeed it does, diodes are often used as the sense element for
temperature sensing, but it's a very small change, and you need to
amplify it when you do. Also, the self heating of the device will
swamp ambient temp effects I should guess.
Thats what makes it a self regulating circuit, as the current comes
up, the foward drop of the diodes go up as well, thus reducing the
drop across the resistor.
Same thing as before...
you.
You can handle this case by dropping one diode off the string and
recalculating the resistor as before. Cuts your efficiency a little
but hey, some poeple drop over half the power delivered as heat into
their "current limiting device" for 28V applications.
You can do that, but for driving LEDs, since they form a nice self
regulating circuit with a single resistor I didn't feel it was
neccesary. Please share with the group which part you've had success
with as a "constant current" device.
be a FET.
You could do this also but each LED would need its own current
limiting resistor in series because the forward drop of the LEDs vary
from part to part and with temperature as you've mentioned and the one
with the lowest drop would eat the most power without those resistors.
But again, with a pulse width modulation circuit, why so complex?
So you're building a constant current supply from each group of 2 or 3
LEDS, thats pretty complex if a single resistor will work. What
you're suggesting is too complex for the average guy and I see no
practical benefit. Don't light bulbs vary in brightness with supply
voltage? Sure they do, and they vary more than the single resistor
method I've sketched out.
The reverse drop on the LEDS will be the supply divided by the number
of diodes. 12/4=3V. Last data sheet I looked at said the reverse
voltage limit was 5V. Thats why I also said that if you put one
backwards it will cook. It will see the full 12V.
What I've outlined is a simple method to build LEDs lights. Yes, you
could build a constant current supply, and the LEDS would see the
exact same current from 10V to 15V but your light bulbs will vary in
brightness (acnd color) over that range anyway more that my suggest
circuit due to the self limiting nature of a diode(s) in series with a
resistor.
Old April 19th 04, 03:24 AM
TaxSrv
"GeorgeB" wrote in message
15.5V is not a normal charging voltage, and if sustained will ruin the
battery. It would only be a fault condition with a regulator gone
bad. I think you can safely calculate dropping resistors based on
14.5V max.
Fred F.
Old April 20th 04, 10:08 PM
Blueskies
That is a good point...bad regulator putting out high voltage. How high can the alternator go with a runaway regulator?
Dan D.
http://www.ameritech.net/users/ddevillers/start.html
"TaxSrv" wrote in message ...
14.5V max.
Fred F.
Old May 11th 04, 09:27 PM
Jeff Peterson
I posted new photos of the LED tail strobe, now with the circuit
completed, at
http://w1.lancair.net/pix/led-strobe
i also posted the schematic.
the particular component choices give a 1 second period and
50% duty cycle. tinker with values to get your favorite flash pattern
i used monolithic ceramic capacitors because they are small, but
they do have a bit of variattion of C with temp. might be
better to use something more stable. as the circuit warms it flashes
faster.
The circuit works quite well, but after some soul-searching I have
tenatively decided NOT to put the system on the LNC 360.
reasons:
-its heavy...235 grams. Installing the strobe will require more than 3
times its mass added to the rudder counterweight. perhaps a kilogram
total. all this at the maximum rearward moment arm. yuck.
-it gets quite warm. after a minute or two the temp is maybe 40C at
base of the LEDs and thats with a fan pushing air past at about 10
MPH. in still air it overheats. if i forget to turn it off on
landing,
I could possibly slag my rudder.
-the system satisfys the FAA Regs, but with no margin...I prefer a
safety factor 2.
-its a complicated system. lots of machining. tight fits. odd angles.
no finesse.
it just doesnt seem like a bulletproof system to me, so i may just
chalk
this one up to experience and develop plan B.
Plan B: get a bunch of 5 mm diameter superbright white leds and
mill the hemispherical ends off the plastic cases. this will give
them a
lambertian pattern. no need to polish the ends, might even sandblast
them
to make the pattern even broader.
glue these into holes drilled in the curved trailing
edge of the lancair wingtip. i will need many more of these LEDS than
with
luxeons, but that will help distribute the thermal dissipation.
the weight might actually be lower this way than with luxeons since
aluminum heat sink will no longer be needed. and the weight will be
near the center of lift, and will not require a counterweight.
or maybe i will come up with plan C...
-Jeff
FS: RV-8 Tail Kit Mike Woodall Home Built 0 January 4th 04 02:38 AM
twin tail questions Kevin Horton Home Built 12 January 2nd 04 03:21 PM
tail buffeting and leading edge fillets, strakes Wallace Berry Home Built 1 September 26th 03 10:48 PM
LEDs with Strobe lights pekka1510 Home Built 11 August 31st 03 11:36 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Home Built 4 July 26th 03 11:34 AM
