Diesel engine
Old April 27th 04, 01:24 PM
On Mon, 26 Apr 2004 20:06:46 -0400, "George A. Graham"
Mounting on a trailer or truck lets you move around the countryside,
so you don't make everyone angry. (Even the airport managers would shoo
me off after a few hours of prop/engine noise).
I think it actually will fit in the back of my pickup (haven't taken
the time to measure yet), and as you know, we live right next to some
pretty dense woods. I could trundle it up to the logging landing
above us and run it all day without bothering anyone.
My worry is to tie it down REALLY well because I will be using the IVO
prop to generate the load and I'll have to pitch the prop to allow the
engine to make 4,800 rpm, after it's run in a bit. At that rpm, there
will be lots of thrust, don't want that engine and stand leaping off
the truck and wailing into the woods. ;-)
I feel I need to have a hobbs meter and carefully thought out
documentation of the engine runs so that the DAR can see that the
engine has been thoroughly tested. So all the instrumentation that
the engine would normally have in the cockpit, should be there on the
little instrument panel I've attached to the test stand. That means
the EGT guage so I can adjust the mixture and test to see if it will
run smoothly lean of peak. I need to be standing there in the howling
wind taking down readings at regular intervals throughout the testing.
Corky Scott
Old April 27th 04, 04:57 PM
Del Rawlins
In charles.k.scott@
If it were me, I would try to pick up a used trailer and turn that into
my test stand. Then you won't be risking damage to your engine from
repeated loading/unloading operations every time you want to do some
testing. This assumes that you will want to use your pickup truck for
things other than a test stand.
You could get one of those surveillance camera setups that are
advertised in various places and mount it to read your instruments. You
would then be able to monitor them from the relative comfort of your
pickup cab.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old April 28th 04, 11:23 PM
Fred the Red Shirt
Del Rawlins wrote in message ...
In charles.k.scott@
my test stand.
Uh, what about putting a muffler on it? Won't it be flying with
some kind of muffler or tuned exhaust system or something that
cuts the noise?
Hey, I'm just asking.
FF
Old April 27th 04, 11:21 PM
David Munday
On Mon, 26 Apr 2004 wrote:
Hi Corky. You don't really believe that now, do you?
Those motors burn 8 to 10 gph near the ground - that ain't .38.
Hey George, what's your firewall forward ... err, aft weight with the
mazda transmission? Any adea how it compares to, say an o-320 all up?
David Munday -
Webpage:
http://www.ase.uc.edu/~munday
"Adopt, Adapt, and Improve" -- Motto of the Round Table
Old April 27th 04, 11:29 PM
George A. Graham
On Tue, 27 Apr 2004, it was written:
Hi Dave, It must be very close to the Lycoming, as my airplane weighs
940 lbs empty, same as most O-320 powered canards. But no, I have not
yet weighed the motor separately. I might do so in the future, as I'd
like to repaint my motor mount with epoxy paint.
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
Old April 28th 04, 03:53 AM
Richard Lamb
George Graham
George, reliable information like that is exceptionally hard to come by.
If you go the trouble to weigh everything, please share it with us?
Richard
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
