Denver Terminal Area Chart Question - BVR vor/dme
Old February 3rd 04, 08:16 PM
Bill Denton
May I suggest you consider picking up a Jeppesen Sanderson PJ-1 Plotter.
It's truly a handy tool!
In this instance, you would just lay the plotter against your pencil line,
then slide it up or down the line until one of the lat-long lines aligns
with one of the lines on the rotating degree wheel. You could then read your
course directly off the wheel.Then you could rotate the wheel to match a
magnetic deviation scale and get your course.
And my explanation is far worse than the one that came with the plotter, but
it's really a useful unit!
"Geoffrey Barnes" wrote in message
ink.net...
The presence or absence of the compass rose on a VOR has no meaning.
It is purely at the discretion of the cartographer to omit it when he
feels it
would make the chart too cluttered.
All right, this makes sense to me. But as someone who is still a student,
I
have to ask a question here. Let's say that I'm planning to fly along a
specific VOR radial, and that this radial is not part of an airway. What
I
normally do is draw a line on the chart, and then read the radial on this
compass rose. But without the compass rose, how am I supposed to
determine
the radial that I need to follow? Most of the VORs in this area have not
been adjusted to keep pace with magnetic variation, and are therefore a
few
degrees off from both both the true course and the magnetic course.
I know that I can look up each VORs magnetic variation setting on
airnav.com, but what if that wasn't available?
Old February 3rd 04, 09:15 PM
Ron Natalie
"Bill Denton" wrote in message ...
Did you bother to read the post? The VOR declinations aren't necessarily the
magnetic variation for the area.
Old February 3rd 04, 11:18 PM
Bill Denton
Yes, I did read the post.
Actually, I said: "magnetic deviation", which is probably a meaningless term
but which was the only one that came to mind.
Jeppesen uses the term "variation", then relates it to "magnetic" in the
instructions.
Neither of which is important to the usability of the plotter.
The plotter has a rotating protractor which allows for direct reading of a
course, and it has the additional variation scale which can be used to input
course corrections and still allow direct reading of the course. You would
normally use this variation scale for magnetic variation.
But you don't have to! You could also use it to give a direct read simply if
you decided: "Hey, it's Tuesday. I think I'll fly five degrees west of the
actual course!"
Now, as I have mentioned on several occasions, I am still in the wannabe
category, anxiously awaiting the arrival of the Light Sport Pilot
certificate.
Sometimes I know or come across some information that might be useful to
some in this group. I then share that information. And if I am incorrect, I
am appreciative when someone corrects me and provides the correct
information.
You made the statement: "The VOR declinations aren't necessarily the
magnetic variation for the area." This was something I have not yet learned
about, so I didn't know it. And after your post, I still don't know it. But
that lack of knowledge doesn't change the validity or worth of the
information I posted.
So, if you feel compelled to post: "Nah, nah, nah, your wrong and I'm
right", knock yourself out. But please don't be surprised if you find your
posts treated with absolutely no respect...
"Ron Natalie" wrote in message
Old February 5th 04, 03:13 AM
Kevin Darling
"Geoffrey Barnes" wrote in message link.net...
As others have mentioned, you should always look up the VORs you're
using in the A/FD, which you should have with you as a student.
My first cross-country I planned without using the A/FD. My
instructor gently pointed out that, on the radial I had planned for,
this particular VOR was unusable. Oops!
After that, I went so far as to draw the range arcs around the VORs in
my neighborhood, using the info in the A/FD. I was shocked at how
some rather large arcs were blocked by mountains below certain flight
elevations.
Kev
Old February 5th 04, 02:03 PM
Ron Natalie
"Kevin Darling" wrote in message m...
You'll need the A/FD anyhow. Not all VOR's are usable in all directions/altitudes.
If you think just because it's on the chart that you're OK, you're going to be disappointed
sooner or later.
My first solo XC, the VOR at the destination airport for my first leg was out of service
(good thing I checked NOTAM's). This meant a dead reckoning leg for 2/3 of the
second leg (nowhere's land eastern Wyoming and Colorado, not even anything to use
for pilotage until I crossed a dry river perpendicular to my flight path that ran through
my destination). My instructor and I felt confident I could handle it.
Old February 8th 04, 12:40 AM
Geoffrey Barnes
This thread has been brutal for me, but I must confess that I'm still lost.
I sat down with a CFI and the A/FD this afternoon, and looked for the
section on VORs. I found lots of VOR check points and test facilities, but
I couldn't find anything that listed all the VORs and their declination
settings.
So fine, I stipulate that I never graduated from junior high school (let
along high school), that my parents were niether married nor (in my father's
case) mammals, that 2 or 3 degress won't make that much of a difference, and
that I am so stupid that I have no place in the vaunted intelligensia that
is the GA community in general and this newsgroup in particular. So now
that the flaming is hopefully out of the way for daring to ask the question,
where do I find these things? Surely it can't be that they list these
things in some editions of the AF/D, but not in the one that covers
Pennsylvania. Yet honestly, I couldn't find it and the CFI said that he'd
never even heard of such a thing.
By the way, I'm not training with this particular CFI, so you can't flame me
by saying that my CFI is a retard. He just happened to be around the FBO
this afternoon and I took the oppotunity to ask him about this. Informative
responses appreciated. Insulting ones anticipated.
Old February 8th 04, 01:12 AM
Bill Denton
What you need to do is jump back into the A/FD with the understanding that
there is no list, per se.
VOR's and NDB's are interspersed with the airports, in alphabetical order by
name (not ID).
For example, here in Chicago we have a "Northbrook" VOR, ID = OBK. It is
listed between Newark (airport) and Olney-Noble (airport) in the Illinois
section. Magnetic Variation is included in the listing.
As part of the ILS system at Midway Airport, there is an NDB named KEDZI, ID
= MX. It is listed between Kankakee (airport) and Kewanee Muni in the
Illinois section.
Hope this helps...
link.net...
lost.
but
settings.
father's
and
question,
me
Informative
Old February 8th 04, 02:15 AM
Gary Drescher
link.net...
lost.
but
settings.
father's
and
Geoff, don't worry--that last sentence alone establishes that you're smarter
than most of us here, as well as wittier and much more socially adept. :-)
As for your question--as Bill just replied, the A/FD intersperses navaid
listings with the airport listings. In addition, an on-field navaid appears
in the associated airport listing, rather than having its own listing.
It's a good idea to read an A/FD almost cover to cover once, to find all the
good stuff therein. (It's not necessary to read all the airport listings,
but a broad sample is helpful; of the ones you choose, read each
exhaustively.)
--Gary
Old February 3rd 04, 04:26 PM
Kevin Chandler
We have the same thing on the Cincinnati section for Wright Patterson AFB.
This is only done to relieve some conjestion on the chart.
"Robert Easton" wrote in message
Does anybody know why on the Denver Terminal Area Chart, the Byers (BVR
113.5) vor/dme facility is charted without the compass ring that are on
most
vortacs? It's the only one I've seen charted like this. Byers is located
33NM on the 090 radial of DVV (the Denver International Vortac).
Thanks, Robert
Old February 3rd 04, 08:00 PM
John Galban
"Robert Easton" wrote in message ...
113.5) vor/dme facility is charted without the compass ring that are on most
Compass rings are omitted to reduce clutter on the chart. In this
case, they probably didn't want to superimpose the ring over the big
intersection of Victor airways just to the south.
Here in the Phoenix area we have one without a ring (IWA).
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. Scott Ferrin Military Aviation 29 August 31st 04 04:20 AM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Enroute chart question.. chris priest Instrument Flight Rules 0 August 10th 04 01:05 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
