Thai
1. Will this be a private airfield and listed on the charts? If so, probably will have to meet some FAA rules. Have you checked with FAA? 2. If he is just landing on his own property you may have problems? Again, ask FAA. 3. Have you set down with your neighbor and in a friendly tone tried to talk out the problem? If you haven't, do that first, as there may be a mutual solution to your problem that allows him to fly and not a big bother to you ? Point out the flight path over your house and see if he can cock his strip 'catty corner' across his (2600') land. This will take pattern away from your house and also give him a longer runway. Best of both worlds. What activity and type of A/C is planned? You may not even have a problem. Can he give you a call on phone prior to taking off so you can expect the noise? etc., etc., etc. If you follow the don't get mad, get even train of activist: 4. Lay out a landing strip on your land pointing at his house. Use a few times so he gets the idea. 5. Build a two story barn on your property at the end of his strip. 6. Put a skeet range on your property at the end of his strip ![]() 7. Put up a windmill at the end of his strip to pump water for your cattle to use. 8. Take up kite flying ![]() On prevailing wind. I sited a strip a number of years ago and went to Wx bureau and got the number of days the wind blew from 360 degrees around the clock for several years. I used the direction where the wind blew the strongest and runway was built. Now we find that 'every' day we have a cross wind as the strong winds only blow a few days in the year and we just land with the these cross winds. Get winds from Wx bureau and evaluate as possible ammo in your discussion. i.e., if strong winds are only in winter when you have 6 feet of snow, they are not a problem for private strip which will never get plowed ![]() this is to be a fair Wx summer strip, check winds for those months. From my Owners Manuals I used while active as a CFI: All figures with zero wind. Cessna 150 (at gross) `````````````````````````````````` 2500 feet elevation 5000 feet elevation Ground run = 910' Ground run = 1115' Clear 50' obs = 1660' Clear 50' obs = 1985' Cessna 172 (at gross) `````````````````````````````````` 2500 feet elevation 5000 feet elevation Ground run = 1040' Ground run = 1255' Clear 50' obs = 1910' Clear 50' obs = 2480' Cessna 182 (at gross) `````````````````````````````````` 2500 feet elevation 5000 feet elevation Ground run - 845' Ground run = 1015' Clear 50' obs = 1625' Clear 50' obs = 1990' Cessna 210 (at gross) `````````````````````````````````` 2500 feet elevation 5000 feet elevation Ground run = 1325' Ground run = 1600' Clear 50' obs = 2305' Clear 50' obs = 2855' All of these figures are for a hard surface runway so have to be adjusted (increased) for dirt R/W. Hope some of this errata helps with your problem. Keep the thread informed how you come out. Big John Sometimes you can't win for trying ![]() On Wed, 11 Feb 2004 08:21:21 -0500 (EST), "" just an average " Farlang..." wrote: Can anyone tell me what criteria, rules, regulations a person needs to be allowed to construct a private runway on his or her property. I know there are many factors that are not presently known in this scenario but I can try to input as much as I know. ----clip---- |
"Big John" wrote in message
If you follow the don't get mad, get even train of activist: snip 8. Take up kite flying ![]() Good ideas so far, but I wouldn't want to try that one. Towing banners I've had that run in before while towing banners. Unless it's a freakin huge kite with some heavy duty string, all that's likely to happen is you'll loose your kite. I did get a few little marks in the fabric where they hit, but that was about it. FWIW, the company I flew for had their own private strip, 1500' long and rough grass. It took them a few years of battleing to get it built, but they did win out in the final appeals. Even so, we still did our darndest to be good neigbors, and flew rather unorthadox patterns to keep from disturbing the neigbors. Did this increase the risk to us in the plane? Slightly, yes, but it wasn't overly so, and looked at as a necessary tradeoff for the convienience of the private strip. I'll second the suggestion to contact your neighbor and talk to him about it (did you try his doorbell?) |
![]() " just an average Farlang..." wrote: Yesterday I took a flying lesson with a chief piot and he told me a small plane can lift off after about a thousand feet of runway and then the maximum climb would be about 500 feet per minute. A Maule 235 will be off the ground in 250'. It will be about 1,000' up when it passes over your house. An Aviat Husky will be higher than that. Performance varies a lot from aircraft to aircraft. He thought for a plane to stay the necessaary elevation over my property the pilot is required a total of no less than 4000 feet. Well, there isn't any regulation specifying a "necessary elevation" when landing or taking off, so he's wrong there. The FAA *does* specify some requirements for public use fields, but not for private ones. That instructor may have been thinking of those. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
Farlang..." wrote in Message-Id: bm9yaWtv.2c49808e3f2f35f5431910160ea416b5@1076505 681.nulluser.com: Can anyone tell me what criteria, rules, regulations a person needs to be allowed to construct a private runway on his or her property. The FAA and AOPA can provide that information: www.faa.gov www.aopa.org Visit the web sites, and search for pertinent information. Contact them by phone, and ask questions. I know there are many factors that are not presently known in this scenario but I can try to input as much as I know. My neighbor owns land that is 2600 feet wide. The elevation is about 3000 feet and the hottest temperature is 91 degrees in the summer. The land is located in Idaho. The prevailing winds position the optimal take off direction to be directly over my house about 1500 feet from the property line. I LOVE airplanes! I worked for Boeing (Lazy B) for the last fifteen years. I worked at Cessna in Witchita before that. I stop to watch planes take off and land. I LOVE PLANES!!! But what I don't love is buying 500 acres to finally get some peace and quiet and then having some loud plane buzz my house at will. I can see how the threat of aircraft might be disturbing to someone seeking solitude. But if you are located near a highway, the highway traffic noise will occur NON STOP day and night continuously. Aircraft noise, on the other hand, is an infrequent, intermittent occurrence lasting significantly less than a minute in duration. It the impact won't be nearly as unpleasant as I think you might be imagining. The person wanting to put in the runway has money to build a 3 floor nice house so I expect they will want to be socialites and invite all their friends to fly in for a barbacue on the weekend. Landing aircraft are typically operating at low power in a glide, so half of the operations will be significantly quieter than you may be anticipating. Take offs are generally full-power, and can be quite noisy, but of short duration. Should your worst case scenario (weekend fly-in barbecue) occur, I think you'd be pleasantly surprised at how painless it might really be. I talked to planning and zoning and they don't even know what prospective planes will be flown there i.e. ultralites or larger planes that require longer runways. I would like to think it is being fair for me to expect no planes flying over my land below 500 feet whether taking off, landing or pattern flying. Unfortunately, Code of Federal Regulation Title 14: Aeronautics and Space, PART 91—GENERAL OPERATING AND FLIGHT RULES, § 91.119 exempts landing and departing aircraft from the 500' minimum proximity to any person, vessel, vehicle, or structure. http://ecfr.gpoaccess.gov/cgi/t/text....1.3.10.2.5.10 But I suspect that the environmental impact you are imagining/anticipating is of a vastly larger magnitude than that which may actually occur. In any given 24-hour period, given the single owner commuting to/from work or town, there would likely be a total of about one minute or two of objectionable noise; that's a very small proportion. I bought my land and paid for the use of each and every acre. If by putting in a runway on the edge of my property that means they are helping themselves to a sort of "easement" flying a hundred feet or so over my land that doesn't seem at all fair. I may wish to build a barn, corral animals (which might go crazy) penned up with planes buzzing over them. I understand. I would feel the same. But feelings are no substitute for hard facts. A thoughtful neighbor would have contacted the land owners who may be affected before planning the construction of a runway. He would then have an opportunity to mollify and assuage the fears of those who may be adversely impacted. Why not give your neighbor an opportunity to present his side before getting yourself too worked up over the rumor? Even if your new neighbor doesn't know how to be neighborly, it doesn't mean you can't enlighten him, and show him how a responsible and considerate neighbor should behave in a small community. Can I get some ideas on what is realistic? Perhaps. I don't even know what a common length of runway is but a friend of mine told me using generic table calculations that a fully loaded small plane on a hot day could very well need a long take off and after lift off .... how long a distance til that plane gets to minimal required elevation? How long is a piece of string; quantifying such parameters requires knowledge of the type of aircraft, its load, meteorologic conditions, pilot proficiency, ... Yesterday I took a flying lesson with a chief piot and he told me a small plane can lift off after about a thousand feet of runway and then the maximum climb would be about 500 feet per minute. He thought for a plane to stay the necessaary elevation over my property the pilot is required a total of no less than 4000 feet. The runway will be a dirt strip which also requires more distance. That estimate seems in the ball park. any comments would be appreciated Take courage in hand, and talk to your neighbor. Quit guessing and imagining what he has planned. Ask him about the type of aircraft he intends to operate, the frequency of operations, the time of day/night of intended operations, how he intends to mitigate the noise impact of his operations on his neighbors, etc. Tell him of your concerns regarding safety, livestock impact, noise pollution, ... If he proves unreasonable, retain an attorney; if he is willing to consider your needs and accept responsibility for minimizing the negative impact his intended activities may have, it'll probably work out fine. If you are training to become a pilot, it might make more sense to build the runway on a part of your 1.5 mile strip of land, so operational noise impacts both of you less than it might if the runway were on his parcel. And sharing the expenses involved in constructing and maintaining the runway will be half. Who knows, he might be willing to grant you use his airplane in exchange for use of your runway: win-win. |
![]() I would like to think it is being fair for me to expect no planes flying over my land below 500 feet The reg is 500 feet from persons and property, when not taking off or landing. If an airplane is just flying by there is no minimum altitude required over the surface. |
![]() "just an average Farlang..." wrote in message news:bm9yaWtv.2c49808e3f2f35f5431910160ea416b5@107 6505681.nulluser.com... Can anyone tell me what criteria, rules, regulations a person needs to be allowed to construct a private runway on his or her property. The FAA just requires 90 day notice of intent to construct an air strip. There are no rules or permission required from them. Just notification. The bigger issue is always the local land use people. |
What about a land swap? You buy him land that would offer him a better
runway, away from your house and he gives you his land that joins yours. It also has certain tax benefits. -- Jim Burns III Remove "nospam" to reply |
In article bm9yaWtv.2c49808e3f2f35f5431910160ea416b5@1076505 681.nulluser.com,
" just an average " Farlang... wrote: Can anyone tell me what criteria, rules, regulations a person needs to [...] An odd question to ask on a pilot newsgroup. A troll? My neighbor owns land that is 2600 feet wide. [...] The prevailing winds position the optimal take off direction to be directly over my house about 1500 feet from the property line. That pretty much describes the airport I fly out of. It's 2450 feet long, with a river on one end and a road on the other. For a long time it was one way, with takeoffs to the south. There is a noise sensitive house straight off the end of the runway. Local procedures call for an immediate left turnout of about 30 degrees. With those dimensions there's no reason that any informed pilot (which should be all of them, at a private airport) would ever be directly over your house on takeoff. They may land over your house but you won't even hear them. -- Ben Jackson http://www.ben.com/ |
After reading all the posts on this thread, I've almost come to the
conclusion we have a troll here? 1. He won't take advice. 2. Argues with everyone who posts in reply to his initial and subsequent posts. 3. Hasn't/didn't do his home work if he HAS a problem. Big John On Wed, 11 Feb 2004 08:21:21 -0500 (EST), "" just an average " Farlang..." wrote: Can anyone tell me what criteria, rules, regulations a person needs to be allowed to construct a private runway on his or her property. I know there are many factors that are not presently known in this scenario but I can try to input as much as I know. My neighbor owns land that is 2600 feet wide. The elevation is about 3000 feet and the hottest temperature is 91 degrees in the summer. The land is located in Idaho. The prevailing winds position the optimal take off direction to be directly over my house about 1500 feet from the property line. I LOVE airplanes! I worked for Boeing (Lazy B) for the last fifteen years. I worked at Cessna in Witchita before that. I stop to watch planes take off and land. I LOVE PLANES!!! But what I don't love is buying 500 acres to finally get some peace and quiet and then having some loud plane buzz my house at will. The person wanting to put in the runway has money to build a 3 floor nice house so I expect they will want to be socialites and invite all their friends to fly in for a barbacue on the weekend. I talked to planning and zoning and they don't even know what prospective planes will be flown there i.e. ultralites or larger planes that require longer runways. I would like to think it is being fair for me to expect no planes flying over my land below 500 feet whether taking off, landing or pattern flying. I bought my land and paid for the use of each and every acre. If by putting in a runway on the edge of my property that means they are helping themselves to a sort of "easement" flying a hundred feet or so over my land that doesn't seem at all fair. I may wish to build a barn, corral animals (which might go crazy) penned up with planes buzzing over them. Can I get some ideas on what is realistic? I don't even know what a common length of runway is but a friend of mine told me using generic table calculations that a fully loaded small plane on a hot day could very well need a long take off and after lift off .... how long a distance til that plane gets to minimal required elevation? Yesterday I took a flying lesson with a chief piot and he told me a small plane can lift off after about a thousand feet of runway and then the maximum climb would be about 500 feet per minute. He thought for a plane to stay the necessaary elevation over my property the pilot is required a total of no less than 4000 feet. The runway will be a dirt strip which also requires more distance. any comments would be appreciated |
![]() I would like to think it is being fair for me to expect no planes flying over my land below 500 feet whether taking off, landing or pattern flying. The applicable federal regulations don't support that expectation. They permit the pilot to come closer when landing or taking off. A It's even worse than that, from the neighbor's point of view. The neighbor can't build a structure or allow a tree to grow to a height that obstructs the takeoff. At Plum Island airport in Newburyport MA, the previous operator owned the east end of the runway. When a new operator was hired, he (the eastie) built a raggedy pile on his own bit of runway. I thought it was rather funny, but the courts didn't, and he had to remove the pile. all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 12:50 AM |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Military Aviation | 3 | August 21st 04 12:40 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
