![]() "Travis Marlatte" wrote in message ink.net... Steven, just as you said that the previous instructions would not be explicitly cancelled, so too is the "remain clear." Using the tail number - especially with the phrase "radar contact" - definitely makes it for me. I would enter the Class C. Then you would be operating an aircraft contrary to an ATC instruction in an area in which air traffic control is exercised and thus be in violation of FAR 91.123(b). An instruction to "remain clear" is implicitly overridden by an instruction that requires or permits entry of the Class C airspace. "Fly heading 110, vector for traffic" would do it, so would "proceed on course" or "enter a right base for runway 32", but "radar contact" would not. |
"Steven P. McNicoll" wrote in message
ink.net... "Travis Marlatte" wrote in message ink.net... Steven, just as you said that the previous instructions would not be explicitly cancelled, so too is the "remain clear." Using the tail number - especially with the phrase "radar contact" - definitely makes it for me. I would enter the Class C. Then you would be operating an aircraft contrary to an ATC instruction in an area in which air traffic control is exercised and thus be in violation of FAR 91.123(b). An instruction to "remain clear" is implicitly overridden by an instruction that requires or permits entry of the Class C airspace. "Fly heading 110, vector for traffic" would do it, so would "proceed on course" or "enter a right base for runway 32", but "radar contact" would not. I don't think so. From the AIM 3-2-4, 3. Arrival or Through Flight Entry Requirements. ... NOTE- 1. If the controller responds to a radio call with, "(aircraft callsign) standby," radio communications have been established and the pilot can enter the Class C airspace. 2. If workload or traffic conditions prevent immediate provision of Class C services, the controller will inform the pilot to remain outside the Class C airspace until conditions permit the services to be provided. 3. It is important to understand that if the controller responds to the initial radio call without using the aircraft identification, radio communications have not been established and the pilot may not enter the Class C airspace. EXAMPLE- 1. [Aircraft callsign] "remain outside the Class Charlie airspace and standby." 2. "Aircraft calling Dulles approach control, standby." I think that this makes it pretty clear that any acknowledgement of a specific aircraft without a specific caution to remain clear is sufficient radio contact to allow clearance into a Class C. Using your example of a subsequent instruction implicitly canceling a previous instruction applies here as well. ------------------------------- Travis |
![]() "Travis Marlatte" wrote in message ink.net... I don't think so. From the AIM 3-2-4, 3. Arrival or Through Flight Entry Requirements. ... NOTE- 1. If the controller responds to a radio call with, "(aircraft callsign) standby," radio communications have been established and the pilot can enter the Class C airspace. 2. If workload or traffic conditions prevent immediate provision of Class C services, the controller will inform the pilot to remain outside the Class C airspace until conditions permit the services to be provided. 3. It is important to understand that if the controller responds to the initial radio call without using the aircraft identification, radio communications have not been established and the pilot may not enter the Class C airspace. EXAMPLE- 1. [Aircraft callsign] "remain outside the Class Charlie airspace and standby." 2. "Aircraft calling Dulles approach control, standby." The material you quoted does not support your position. I think that this makes it pretty clear that any acknowledgement of a specific aircraft without a specific caution to remain clear is sufficient radio contact to allow clearance into a Class C. Yes, but that's not the case here. In this case there was acknowledgement of a specific aircraft with a specific instruction to remain clear of the Class C airspace. Using your example of a subsequent instruction implicitly canceling a previous instruction applies here as well. It doesn't apply in this case because the instruction to remain clear of the Class C airspace was the only instruction issued. |
ink.net... "Travis Marlatte" wrote in message ink.net... I don't think so. From the AIM 3-2-4, 3. Arrival or Through Flight Entry Requirements. ... NOTE- 1. If the controller responds to a radio call with, "(aircraft callsign) standby," radio communications have been established and the pilot can enter the Class C airspace. 2. If workload or traffic conditions prevent immediate provision of Class C services, the controller will inform the pilot to remain outside the Class C airspace until conditions permit the services to be provided. 3. It is important to understand that if the controller responds to the initial radio call without using the aircraft identification, radio communications have not been established and the pilot may not enter the Class C airspace. EXAMPLE- 1. [Aircraft callsign] "remain outside the Class Charlie airspace and standby." 2. "Aircraft calling Dulles approach control, standby." The material you quoted does not support your position. Sure it does. My position is that radio contact where the controller uses your tail number and lacking an explicit "remain clear" grants permission to enter the class C. Note 1 above says this. You seem to be saying that once a "remain clear" has been issued that the only way to reverse that is with an explicit "cleared to enter the class C." The AIM doesn't really address this sequence of events but does not refer to a specific clearance to enter the class C either. I think that this makes it pretty clear that any acknowledgement of a specific aircraft without a specific caution to remain clear is sufficient radio contact to allow clearance into a Class C. Yes, but that's not the case here. In this case there was acknowledgement of a specific aircraft with a specific instruction to remain clear of the Class C airspace. I think it is the case as presented by the original poster. He had received a "remain clear" prior to take off. After departure, he had a radio exchange that included his tail number and took that as permission to enter the class C. Using your example of a subsequent instruction implicitly canceling a previous instruction applies here as well. It doesn't apply in this case because the instruction to remain clear of the Class C airspace was the only instruction issued. Again, after departure, the pilot had a radio exchange where the controller used his tail number. That grants permission to enter the class C. I am based at a class C airport. I have heard "remain clear" many times. I have never heard "cleared to enter." Subsequent radio contact that uses my tail number is enough to rescind the "remain clear" instruction. ------------------------------- Travis |
![]() I would find this one confusing "Cessna 1234, where did you say you wanted to go?" It uses the tail number which is enough but indicates that the controller is still trying to figure out what to do with me. I would question whether that establishes radio contact to enter the Class C. Radio contact has been established. You have pemission to enter. It is not an entry requirment that the controller know where you are or where you want to go. See and avoid is not superceded. While it is sorted out, you may proceed in. Jose -- (for Email, make the obvious changes in my address) |
![]() "Teacherjh" wrote in message ... Radio contact has been established. You have pemission to enter. No. Radio contact has been established and the pilot has been instructed to remain clear of the Class C airspace. You do not have permission to enter. It is not an entry requirment that the controller know where you are or where you want to go. See and avoid is not superceded. While it is sorted out, you may proceed in. True dat. |
On Sun, 15 Feb 2004 13:40:37 GMT, "Steven P. McNicoll"
wrote in Message-Id: . net: So, I asked both, wouldn't you tell the pilot that he is now 'cleared to enter the C', to avoid confusion.. They both replied that there is no confusion... The clearance to enter a Class C airspace is establishing radio contact using the tail number exactly as spelled out in the AIM.. Yes, if nothing else is said that is correct. But in this case the aircraft was instructed to remain clear of Class C airspace and that instruction remains in effect until some instruction is issued that permits entry. If the controller who issued the "remain clear of Class C" instruction was not the controller responsible for operations inside of the Class C airspace, it would seem that radio contact with the controller who is would grant permission to enter. In any event, to bring the issue to the fore, I would have said, "facility name approach, Cessna 1234 location altitude _restricted_outside_Class_C, request..." |
![]() "Larry Dighera" wrote in message ... If the controller who issued the "remain clear of Class C" instruction was not the controller responsible for operations inside of the Class C airspace, it would seem that radio contact with the controller who is would grant permission to enter. Entry is based on establishing two-way radio communications with the ATC facility, not with a specific controller. |
Howdy!
In article . net, Steven P. McNicoll wrote: "Dennis O'Connor" wrote in message ... [snip] But I could still be wrong, so I just polled both the Supervisor of a Class C airspace, and I polled the supervisor of the Michigan FSDO... Both agree that the AIM is correct... A pilot is cleared into the class C when the controller establishes radio contact using the tail number; and does not instruct him to remain clear... Nothing more is required... That's true, but that's not what happened in this case. In this case the pilot was instructed to remain clear of the Class C airspace. So, on the first call the pilot was told, "Aircraft calling remain clear of Charlie?, or "November 1234 remain clear of Class Charlie.", or words to that effect... Fine, we all agree he is to remain clear... Now the controller calls a bit later and says something to the effect, "November 1234, radar contact 8 miles east of xyz, altimeter 30 point 00", or some variation and shuts up - because he has established radio contact which is 'the clearance to enter'... Wrong. Radio contact was established when the controller said, "November 1234 remain clear of Class Charlie." ....and once again with "November 1234, radar contact..." Where, in that "radar contact" communication, does the controller say "remain clear..."? If N1234 was to remain clear, the controller needed to say so. If the "remain clear" instruction was to remain in place, what approved phraseology would the controller then use to remove the restriction? You keep insinuating that there must be some magic phrase, but you don't tell us what it is. So, I asked both, wouldn't you tell the pilot that he is now 'cleared to enter the C', to avoid confusion.. They both replied that there is no confusion... The clearance to enter a Class C airspace is establishing radio contact using the tail number exactly as spelled out in the AIM.. Yes, if nothing else is said that is correct. But in this case the aircraft was instructed to remain clear of Class C airspace and that instruction remains in effect until some instruction is issued that permits entry. And what would that instruction be, if "November 1234, radar contact..." were not sufficient (as clearly laid out in the AIM)? Pray enlighten us. yours, Michael -- Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly | White Wolf and the Phoenix Bowie, MD, USA | Tablet and Inkle bands, and other stuff | http://www.radix.net/~herveus/ |
![]() "Michael Houghton" wrote in message ... ...and once again with "November 1234, radar contact..." Where, in that "radar contact" communication, does the controller say "remain clear..."? Nowhere. Where in that "radar contact" communication does the controller say anything that overrides the instruction to "remain clear of Class Charlie"? If N1234 was to remain clear, the controller needed to say so. The controller DID say so, what do you think "November 1234 remain clear of Class Charlie" means? If the "remain clear" instruction was to remain in place, what approved phraseology would the controller then use to remove the restriction? Where do you people get this idea that ATC instructions last only until the next exchange of communications, whatever that exchange may be? For the third or fourth time now, the controller would have to issue an instruction that permitted or required entry into Class C airspace. Examples are, "proceed on course", "fly heading XXX, vector for sequencing", enter right base for runway XX", etc. You keep insinuating that there must be some magic phrase, but you don't tell us what it is. I never said or implied that there was any specific "magic phrase". And what would that instruction be, if "November 1234, radar contact..." were not sufficient (as clearly laid out in the AIM)? Pray enlighten us. Where does the AIM say that "radar contact" allows an aircraft to enter Class C airspace that had established radio communications and been instructed to remain outside of it? Pray, enlighten me. |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
Windshields - tint or clear? | Roger Long | Piloting | 7 | February 10th 04 02:41 AM |
Is a BFR instruction? | Roger Long | Piloting | 11 | December 11th 03 09:58 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
