when does a "remain clear" instruction end?
Old February 20th 04, 11:39 PM
Michael Houghton
Howdy!
In article .net,
Steven P. McNicoll wrote:
"Michael Houghton" wrote in message
...and once again with "November 1234, radar contact..." Where, in that
"radar contact" communication, does the controller say "remain clear..."?
Nowhere. Where in that "radar contact" communication does the controller
say anything that overrides the instruction to "remain clear of Class
Charlie"?
Where in that "radar contact" communication is an instruction to "remain clear"?
No instruction means authorization to enter.
If N1234 was to remain clear, the controller needed to say so.
The controller DID say so, what do you think "November 1234 remain clear of
Class Charlie" means?
The pilot in question did remain clear until authorized by a subsequent
communication that did not instruct him to remain clear.
If the "remain clear" instruction was to remain in place, what
approved phraseology would the controller then use to remove
the restriction?
Where do you people get this idea that ATC instructions last only until the
next exchange of communications, whatever that exchange may be?
Because, in the case of entering Class C or Class D airspace, the "remain
clear" instruction is not very durable in the face of continuing two-way
radio communication. If ATC wants the airplane to stay out, they can either
refuse to communicate or issue the instruction to "remain clear". Failing
that, they authorize entry. Where do you get the idea that "remain clear"
persists so?
For the third or fourth time now, the controller would have to issue an
instruction that permitted or required entry into Class C airspace.
Examples are, "proceed on course", "fly heading XXX, vector for sequencing",
enter right base for runway XX", etc.
"November 1234, radar contact" also suffices.
You keep insinuating that there must be some magic phrase, but
you don't tell us what it is.
I never said or implied that there was any specific "magic phrase".
You keep insting that "remain clear" continues in force despite subsequent
two-way radio communication, yet you offer no documentary support for
that claim.
Consider the following scenario.
You take off outside the Class C and would like to transit it. You are
instructed to remain clear. You circumnavigate it, reach your destination,
and return without landing. You again approach the Class C with the
desire to transit rather than go around. You call up ATC again and they
reply with your tail number but no instructions. Can you go in or not?
I'm positing on the order of an hour or more elapsing between the two
attempts to transit.
And what would that instruction be, if "November 1234, radar contact..."
were not sufficient (as clearly laid out in the AIM)? Pray enlighten us.
Where does the AIM say that "radar contact" allows an aircraft to enter
Class C airspace that had established radio communications and been
instructed to remain outside of it? Pray, enlighten me.
It's not the "radar contact" part, it's the "November 1234" part, in the
absence of specific instructions in the communication.
yours,
Michael
Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly
| White Wolf and the Phoenix
Bowie, MD, USA | Tablet and Inkle bands, and other stuff
http://www.radix.net/~herveus/
Old February 21st 04, 03:33 AM
Steven P. McNicoll
"remain clear"? No instruction means authorization to enter.
The instruction to remain clear was in the first communications exchange,
the one that established two-way radio communications. That instruction
remains in effect until overridden by an instruction that permits entry. It
did not need to be restated when the aircraft was told "radar contact".
There was no subsequent communication that overrode the instruction to
remain clear.
either refuse to communicate or issue the instruction to "remain clear".
Failing that, they authorize entry.
But the controller did issue the instruction to remain clear and you claim
that entry is authorized regardless. Apparently the "remain clear"
instruction is not very durable only because Michael Houghton says so. Can
you cite ANYTHING that supports your position?
Where do you get the idea that "remain clear" persists so?
You're being absurd. The guy was instructed to remain clear. An ATC
instruction is not affected by subsequent communications that are unrelated
to it. If they were ATC would have to reissue full IFR clearances every
time they issued a traffic advisory or altimeter setting.
Because the phrase "radar contact" means "proceed on course"?
that claim.
I offered the AIM, the FARs, FAA Order 7110.65, and simple logic. It's time
for you provide some documentary support for your position that the
instruction to remain clear is cancelled by subsequent unrelated
communications.
You can go in.
Right. It's a different flight, unrelated to the first.
How so? "November 1234" doesn't override the instruction to remain clear
any more than "radar contact" does.
Old February 21st 04, 03:56 AM
Peter
You can go in.
What makes it a "different flight"? He didn't land in between, just flew
around for about an hour and came back. Would flying around for half an
hour and then returning be sufficient to make it a "different flight" and
thereby cancel the effects of the 'remain clear' instruction? How about 15
minutes? Doing a 360?
Old February 24th 04, 03:50 AM
Arden Prinz
Hi Steven,
You've indicated that a "remain clear" stays in effect until ATC
issues a subsequent communication that permits or requires entry into
the class C airspace. This sounds reasonable. The real question is
knowing what communications permit or require entry into the class C
airspace and which ones do not so that when I'm in the air and hear a
communication I can know whether that communication suffices.
I'm not sure where you got this list.
Does "proceed on course" always permit entry, or does it depend upon
the relative positions of the airplane, class C airspace, and route of
flight? For example, if I'm headed away from the class C airspace
toward an intermediate waypoint and I hear the "proceed on course",
can I then go through the class C?
Thank-you!
Arden
Mountain flying instruction: McCall, Idaho, Colorado too! [email protected] General Aviation 0 March 26th 04 11:24 PM
Windshields - tint or clear? Roger Long Piloting 7 February 10th 04 02:41 AM
Is a BFR instruction? Roger Long Piloting 11 December 11th 03 09:58 PM
