Crosswind components
Old February 26th 04, 02:43 AM
Teacherjh
Same as a sailboat.
Can go much faster than the wind.
Actually, sailing is different because of the interaction of the keel and the
water. You can't go faster than hull speed, but ignoring that you could
theoretically go faster than the wind, if you were going at 90 degrees to it.
You can even sail INTO the wind.
You can't, however, run before the wind faster than the wind (unless you have
one humongus current)
Jose
Old February 26th 04, 11:54 PM
David CL Francis
On Thu, 26 Feb 2004 at 02:43:58 in message
, Teacherjh
Yes you can. The ability to do so depends on the relative forces between
the water and the second medium. Sand and Ice yachts can readily
demonstrate a course speed downwind faster that the wind. In effect they
are tacking downwind. If you are being very precise then you cannot run
before the wind faster than the wind because running before the wind
depends only on drag and not on lift.
David CL Francis
Old February 27th 04, 01:26 PM
Teacherjh
Straight downwind? So they would be overtaking the wind? Howdeydodat?
In effect they
Oh, then they are not "running" before the wind, they are sidestepping to some
degree.
Jose
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
FS: Slick ignition components (O-540) David Campbell Aviation Marketplace 0 December 24th 03 02:56 AM
