![]() "Peter Duniho" wrote in message I'm not sure there's enough standardization in gear retraction/extension systems to say what's "normal". However, certainly the lack of redundancy is common enough on light planes. In fact, not only is the gear on my airplane designed similarly, the flaps and elevator trim use the same hydraulic system. A failure in the hydraulic system that takes out certain lines, and/or results in a loss of fluid would affect all three systems simultaneously. I suppose you could also run the brakes off the same hydraulic system as the gear, too. After all, if the gear fails you won't be needing any brakes. :-) |
"C J Campbell" wrote: I suppose you could also run the brakes off the same hydraulic system as the gear, too. After all, if the gear fails you won't be needing any brakes. :-) The B-24 I used to fly is like that. Brakes, flaps, landing gear and bombbay doors all on the same system. There is one engine driven pump (#3 engine), an electric pump and a hand-pump. There are also 2 accumulators. If you have pressure in the accumulators you will have one shot at the brakes...release the brakes and you release the pressure. The copilot will be pumping like crazy on the handpump about then. G The gear will freefall into position (the nose gear has to be manually thrown out), and the flaps can be pumped down using the handpump. I only had one problem with the hydraulics. The main feed line from the engine driven pump cracked at an elbow filling the bombbay with hydraulic fluid...took less than a minute to pump all the fluid out rendering us helpless. Luckily we had just landed and were taxiing to parking when it failed. Mixtures to "cutoff" and coasted to a stop. Had just enough time to say "WHEW!" before the airplane started rolling backward due to a very slight grade on the taxiway. NOT a good feeling. G The crewchief was scrambling trying to get out to throw himself under the wheel as a chock when we came to a stop. If the crack had opened just a minute or two before I probablyl would've parked the airplane in the same gas station Southwest did a few years back. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
... I suppose you could also run the brakes off the same hydraulic system as the gear, too. After all, if the gear fails you won't be needing any brakes. :-) Well, actually...the brakes do use the same reservoir for their hydraulic fluid. But all pressure for the brakes comes from the master brake cylinders, not the hydraulic pump used for the other three systems. Only a leak in the hydraulic line between the master and slave cylinders for the brakes would cause any trouble with the brakes (by emptying out the brake lines, along with the rest of the hydraulic system). Again speaking only of light planes, I doubt there are any that use a hydraulic pump to operate the brakes. As for whether you'd need the brakes, I guess that depends on whether the gear fails in the up position, or down. Pete |
![]() "Andrew Gideon" wrote in message online.com... -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 I've been reading the POH for my club's 182RG, and I find myself surprised. The manual gear extension replies upon the same hydrolic pressure system as the powered mechanism. Isn't that insufficiently redundant? I'm not sure what I expected - perhaps something purely mechanical. But I didn't expect a lone pressure system to be a single point of failure. Is this normal? The Cessna 172RG is similar. Hydraulic pressure is used to hold the gear up. The pump runs every few minutes to maintain hydraulic pressure. Unfortunately, if the pump or another part of the hydraulic system fails, the gear will come down only part way, streaming behind the airplane like a duck with broken legs. The manual system is just another pump, only it is only capable of lowering the gear. If you lose hydraulic pressure the manual system will provide enough pressure to lower the gear and lock it in place if there is any fluid in the system at all. You would have to spring a leak at the bottom of the sump to lose all your hydraulic fluid. If someone absolutely cannot get the gear down and locked it is nearly always because of some fracture at the pivot point. No backup system would salvage that -- the landing gear is physically broken. I personally have seen the gear system work with no hydraulic fluid left in the reservoir -- just a little bit left in the lines. The emergency extension lever was not even needed. The landing gear system is not all that critical anyway. If more redundancy is required, the weight penalty is better applied to other systems. |
... Hydraulic pressure is used to hold the gear up. The pump runs every few minutes to maintain hydraulic pressure. Assuming the 172RG gear system is similar to the 182RG and 177RG systems, if the pump is running on a regular basis, you have a leak somewhere. Not necessarily one venting fluid, but one allowing fluid from the pressurized side of the system to the non-pressurized side. (The pressurized side changes, of course, depending on whether you're raising or lowering the gear) The manual system is just another pump, only it is only capable of lowering the gear. If you lose hydraulic pressure the manual system will provide enough pressure to lower the gear and lock it in place if there is any fluid in the system at all. You would have to spring a leak at the bottom of the sump to lose all your hydraulic fluid. A leak on the pressurized side of the system would allow the hand-pump (or the electric pump) to pump all the fluid out of the system. You don't need to spring a leak at the bottom of the sump to lose all your fluid. [...] The landing gear system is not all that critical anyway. If more redundancy is required, the weight penalty is better applied to other systems. True without a doubt! Pete |
![]() "Peter Duniho" wrote in message ... A leak on the pressurized side of the system would allow the hand-pump (or the electric pump) to pump all the fluid out of the system. You don't need to spring a leak at the bottom of the sump to lose all your fluid. It actually does not pump it all out, as the intake for the pump is high enough to leave a small reservoir to be used by the emergency extension lever. |
... It actually does not pump it all out, as the intake for the pump is high enough to leave a small reservoir to be used by the emergency extension lever. Fine. However, as soon as you start using the manual pump, you will still wind up pumping the fluid out. My main point is that it is not necessary to have a leak at the bottom of the sump in order to lose all the hydraulic fluid. Pete |
The Cessna 172RG is similar. All the Cessna retract singles have the same basic gear design. Only difference is some of the earlier 210's had an engine driven hydraulic pump. Hydraulic pressure is used to hold the gear up. The pump runs every few minutes to maintain hydraulic pressure. If the pump is running every few minutes, there's a leak somewhere. You would have to spring a leak at the bottom of the sump to lose all your hydraulic fluid. That's absolutely not correct. All you have to do is blow a high pressure hose and you will pump all the hydraulic fluid overboard, and completely lose any ability to lower the gear. Know more than one person who has had it happen. Michael |
Not sure what you mean by "normal"...? It certainly is for
all the Cessna retractable singles - yours hasn't been singled out for special treatment. As to whether it's a good idea, well no, it sure doesn't seem so. But that's the way it is. I've had to hand-pump mine once, when a switch in the pump circuit failed. It's a nasty moment when the gear doesn't go down, and a very pleasant feeling when that green light comes on. Failure of a seal anywhere in the hydraulics means you'll be using a lot of power to taxi off the runway. According to Aviation Consumer it's rare (amongst failures) but not unknown. John "Andrew Gideon" wrote in message online.com... -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 I've been reading the POH for my club's 182RG, and I find myself surprised. The manual gear extension replies upon the same hydrolic pressure system as the powered mechanism. Isn't that insufficiently redundant? I'm not sure what I expected - perhaps something purely mechanical. But I didn't expect a lone pressure system to be a single point of failure. Is this normal? - Andrew -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.2.4 (GNU/Linux) iD8DBQFAO/97sJzG+JC8BsgRAsBuAJ4icGbpAvUC4EW/rL/ILCagYfyhaACfTe+T 51+A7xKPIVfPn7+lWCWoHgg= =Mbq0 -----END PGP SIGNATURE----- |
If by "normal" you mean "does everyone else do it this way", then no it's
not normal. Piper arrows have an override which releases hydraulic pressure so that the gear can free fall into position. Older moonies have a "johnson bar" which is a purely manual system. Yet other planes have an emergency tank for blowing the gear down (beech maybe?). For the 182RG, I believe the hydraulic system provides for "up pressure" meaning that if you spring a leak the gear should drop. So if only the pump fails, out comes the handle, otherwise the gear are coming down anyway. And now for the bad news: because the main gear fold backward into the fuselage, they likely won't drop all the way on a hydraulic failure. There are various anecdotes about pilots reaching out the door with the towbar to pull the gear all the way down. Folding legs on the high-wing Cessnas have always been a bit of a black eye, usually due to maintenance issues. cheers, mark "Andrew Gideon" wrote in message online.com... -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 I've been reading the POH for my club's 182RG, and I find myself surprised. The manual gear extension replies upon the same hydrolic pressure system as the powered mechanism. Isn't that insufficiently redundant? I'm not sure what I expected - perhaps something purely mechanical. But I didn't expect a lone pressure system to be a single point of failure. Is this normal? - Andrew -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.2.4 (GNU/Linux) iD8DBQFAO/97sJzG+JC8BsgRAsBuAJ4icGbpAvUC4EW/rL/ILCagYfyhaACfTe+T 51+A7xKPIVfPn7+lWCWoHgg= =Mbq0 -----END PGP SIGNATURE----- |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
