Backup for dropping the gear
Old February 27th 04, 12:58 AM
Paul Tomblin
In a previous article, said:
On Thu, 26 Feb 2004 12:34:18 +0000 (UTC),
(Paul Tomblin) wrote:
big snip
Actually, reading that again, it's possible that what is happening isn't
that it comes on at a lower speed if you have power on, but that the
propellor slipstream holds the gear up against the springs if you have
power on.
little snip
A crude "pitot" head (located within the propeller slipstream)
Oh duh. Of course. I forgot the pitot was in the slipstream as well.
Paul Tomblin
http://xcski.com/blogs/pt/
"It is my prayer that other Americans will fully realize that to condone the
whittling away of the rights of any one minority group is to pave the way for
us all to lose the guarantees of the Constitution" - Harold L. Ickes
Old February 27th 04, 02:11 AM
Peter Duniho
Hope some of this helps
Sure, thanks. Nice to hear the full description, so we can finally stop
guessing.
Old February 27th 04, 05:59 PM
Ron Natalie
"Paul Tomblin" wrote in message ...
In a previous article, "Peter Duniho" said:
And actually, while I haven't flown the Pipers you're referring to, my
understanding is that the gear extension was based on airspeed, not engine
power. Your comment about the behavior of such systems in icing conditions
The POH for the Lance isn't 100% clear on this, but my understanding is
that with the emergency gear extension, the gear will come down if you go
below a certain manifold pressure at one speed, or will come down
regardless of the manifold pressure at a lower speed.
The Arrow auto extend is simply a mechanical belows on the second pitot (just
behind the clear prop window) that dumps hydraulic pressure when you get slow.
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
