"Joe Morris" wrote in message
... ...and "QFE" by itself as a Google search yields 50,000+ hits, starting with "Quad Fast Ethernet". grin Adding "altimeter" to the search brings up what you need. But as a student pilot, please recall that the most stupid question is the one that you don't ask. If there's something about flying that you don't understand, it's far better to ask it while sitting in front of a monitor at home than to realize while on short final that you need the answer before landing... And while definitions of "QFE" found on Google will probably be correct, there are issues where a search on Google will return conflicting responses. (surprised?) Ask the questions here and you might also get conflicting responses, but you'll also get a discussion as other posters offer arguments for or against one of the answers, giving you some ideas about what to ask your instructor in a face-to-face discussion. And welcome to the ranks of aviation! Joe Morris Thank you Joe... Jay Beckman Student Pilot - KCHD 3.2 Hrs ... Nowhere to go but up! |
![]() Big John wrote: QFE is a Q code used by pilots and air traffic control Not in this country. |
you can't set QFE when the field elevation is that high above sea level
BT "Joe Morris" wrote in message ... "Jay Honeck" writes: The pilot survived, right? His health is fine. His career, I sadly suspect, is not. A comment from one of the ASF people at a CFIRC I was at over the past weekend was that he is now flying a desk at the Pentagon. The same man stated that the problem was that the pilot had become too comfortable with practicing the maneuver at his home base, which was about 800 (+/-; I don't recall the exact number) feet lower than the airfield at which the accident occurred. At the accident location he set up the split-S so that the top was at the proper altitude MSL -- at his home base, meaning that the entire maneuver was executed 800 feet lower than it should have been. I have *no* military jet experience, but especially for airshows I'm somewhat surprised that there isn't an altimeter set to QFE to serve as a sanity check against exactly this sort of problem. Joe Morris |
Why not
"BTIZ" wrote in message news:fg81c.12502$id3.1896@fed1read01... you can't set QFE when the field elevation is that high above sea level BT "Joe Morris" wrote in message ... "Jay Honeck" writes: The pilot survived, right? His health is fine. His career, I sadly suspect, is not. A comment from one of the ASF people at a CFIRC I was at over the past weekend was that he is now flying a desk at the Pentagon. The same man stated that the problem was that the pilot had become too comfortable with practicing the maneuver at his home base, which was about 800 (+/-; I don't recall the exact number) feet lower than the airfield at which the accident occurred. At the accident location he set up the split-S so that the top was at the proper altitude MSL -- at his home base, meaning that the entire maneuver was executed 800 feet lower than it should have been. I have *no* military jet experience, but especially for airshows I'm somewhat surprised that there isn't an altimeter set to QFE to serve as a sanity check against exactly this sort of problem. Joe Morris |
![]() S Green wrote: Why not Altimeters simply can't be set that high. The adjustment mechanism doesn't have the range. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
the adjustment range to set the altimeter to the proper pressure will not
move to adjust 2800ft of altitude. try it some time, to adjust from a "standard 29.92" at sea level. Move that altimeter to my airport at 2833MSL and it still says 29.92, now try to move it to read 0, this would require you to move the setting more than 2800 feet which exceeds the capability of a standard aviation altimeter. BT "S Green" wrote in message ... Why not "BTIZ" wrote in message news:fg81c.12502$id3.1896@fed1read01... you can't set QFE when the field elevation is that high above sea level BT "Joe Morris" wrote in message ... "Jay Honeck" writes: The pilot survived, right? His health is fine. His career, I sadly suspect, is not. A comment from one of the ASF people at a CFIRC I was at over the past weekend was that he is now flying a desk at the Pentagon. The same man stated that the problem was that the pilot had become too comfortable with practicing the maneuver at his home base, which was about 800 (+/-; I don't recall the exact number) feet lower than the airfield at which the accident occurred. At the accident location he set up the split-S so that the top was at the proper altitude MSL -- at his home base, meaning that the entire maneuver was executed 800 feet lower than it should have been. I have *no* military jet experience, but especially for airshows I'm somewhat surprised that there isn't an altimeter set to QFE to serve as a sanity check against exactly this sort of problem. Joe Morris |
"BTIZ" writes:
you can't set QFE when the field elevation is that high above sea level Perhaps not on a regular (civilian) aircraft altimeter, but given the number of toys that are part of a typical military bird it would seem that something as simple as a parachute jumper's alitmeter (which *is* designed to be set to QFE) would be a good, inexpensive way to do a sanity check on altitudes used in low-level aerobatics. Joe Morris |
Great shot of the Thunderbird F-16 Ejection | Jay Honeck | Piloting | 51 | February 3rd 04 10:31 PM |
Thunderbird pilot found at fault in Mountain Home AFB crash | Ditch | Military Aviation | 5 | January 27th 04 01:32 AM |
Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 04:34 PM |
Thunderbird crash photos | mowkie | Military Aviation | 0 | October 21st 03 04:49 PM |
Thunderbird crash today | John Doe | Military Aviation | 12 | September 16th 03 05:56 AM |
