In misc.metric-system Jukka K. Korpela wrote:
"Julian Scarfe" wrote: How can you possibly suggest that it would be more "practical" to use kPa? Because one digit less is needed, and conversions are easier when powers of 1,000 are used as normally. No, you need the same number of digits, and a decimal point in addition. A pressure difference of 1 hPa corresponds to an altitude difference of 8 m at sea level. That is just enough precision, but 80 m (corresponding to 1 kPa) would be intolerable. Pilots are usually required to keep an assigned altitude to within +- 15 m (50 feet). -- Klaus Wacker Experimentelle Physik V http://www.physik.uni-dortmund.de/~wacker Universitaet Dortmund Tel.: +49 231 755 3587 D-44221 Dortmund Fax: +49 231 755 4547 |
How can you possibly suggest that it would be more "practical" to use kPa? "Jukka K. Korpela" wrote in message . .. Because one digit less is needed, and conversions are easier when powers of 1,000 are used as normally. I forgot to mention in my response, BTW, that the same number of digits *is* required. Aviation applications require a precision of 100 Pa in measured pressures. Your choice is between 1013 hPa or 101.3 kPa. By adding the "daycimal", you simply make it more difficult for pilots to say. Julian Scarfe |
I forgot to mention in my response, BTW, that the same number of digits *is* required. It depends on the quantities. I was referring to the most common quantities that people see expressed. When tagging isobars in weather maps, the trailing zero is just a nuisance. And when more accuracy is needed, it is natural to accept that fractions might be needed. Your choice is between 1013 hPa or 101.3 kPa. You just gave one more reason to favor kPa. The numeric value 1013 is not in the recommended range, and it raises the question of a thousands separator, which is language dependent, so that some cultures would use 1 013 (and would need a no-break space to prevent undesired line breaks, and an en space to avoid too wide a gap, and cannot get both) while some would use 1'013 or 1.013 or 1,013. Situations where the quantity will be taken as a thousand times too small would be quite rare, but the damage could be serious, so why take the risk. -- Yucca, http://www.cs.tut.fi/~jkorpela/ |
On Sun, 7 Mar 2004 17:42:25 -0000, "Julian Scarfe"
wrote: "Jukka K. Korpela" wrote in message ... In practice, using hPa means being just _nominally_ metric, i.e. using actually millibars but under a different name. The odd thing is that the correct kPa would be more practical. How can you possibly suggest that it would be more "practical" to use kPa? There is an installed base of tens of thousands of altimeters in aircraft out there that are calibrated in mbar. Describing them as hPa makes it clear what the unit is for someone familiar with the SI, without risking accidents through unit confusion. The preference to use powers of 1000 is just a preference because practicality and pragmatism is sometimes more important than an arbitrary recommendation. This is a perfect example of where pragmatism should (and does) win. Oh, good grief. Does anybody use feet for altitude? Do all of the analog instruments show all the digits in those feet? Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ |
"Gene Nygaard" wrote in message ... On Sun, 7 Mar 2004 17:42:25 -0000, "Julian Scarfe" wrote: "Jukka K. Korpela" wrote in message ... In practice, using hPa means being just _nominally_ metric, i.e. using actually millibars but under a different name. The odd thing is that the correct kPa would be more practical. How can you possibly suggest that it would be more "practical" to use kPa? There is an installed base of tens of thousands of altimeters in aircraft out there that are calibrated in mbar. Describing them as hPa makes it clear what the unit is for someone familiar with the SI, without risking accidents through unit confusion. The preference to use powers of 1000 is just a preference because practicality and pragmatism is sometimes more important than an arbitrary recommendation. This is a perfect example of where pragmatism should (and does) win. Oh, good grief. Does anybody use feet for altitude? Do all of the analog instruments show all the digits in those feet? An just to add to the confusion our aircraft uses pieze for manifold pressure |
Does anybody use feet for altitude? Everyone except the Former USSR and China, as near as I can figure. all the best -- Dan Ford email: (requires authentication) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
On Sun, 07 Mar 2004 17:33:47 -0500, Cub Driver
wrote: Does anybody use feet for altitude? Everyone except the Former USSR and China, as near as I can figure. bravo--you were able to answer the rhetorical question part. What about the rest of it? Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ |
... The preference to use powers of 1000 is just a preference because practicality and pragmatism is sometimes more important than an arbitrary recommendation. This is a perfect example of where pragmatism should (and does) win. Oh, good grief. Does anybody use feet for altitude? Do all of the analog instruments show all the digits in those feet? Pilots have become accustomed to using feet for altitude. Can you imagine the confusion that would arise if the unit suddenly shifted by a factor of 10? "Descend and maintain 300 decafeet" Any room for confusion there? We already have trouble enough with pilots screwing up inHg to mbar conversions. What does an altimeter setting of "nine ninety two" mean? As a physicist and a pilot, I'd rather live with the inconvenience of using a hecto prefix for stuff that comes across my desk than risking confusion in the cockpit. So would ICAO. Julian Scarfe |
We already have trouble enough with pilots screwing up inHg to mbar conversions. So while you take the trouble, wouldn't it be best to move to something that lasts, due to being part of a system that is meant to be applied in all areas of life when expressing physical quantities? It's better to move directly to the SI system as recommended in general, rather than first moving, say, to a partly decimal-based variant of the Anglo- Saxon system, or - to take an example about different quantities - first move from the use of different gallons to a Unified Gallon, then to hectoliters, later to what the SI system really recommends. -- Yucca, http://www.cs.tut.fi/~jkorpela/ |
In misc.metric-system Julian Scarfe wrote:
Pilots have become accustomed to using feet for altitude. Can you imagine As a european pilot I would prefer meters. But how to rearrange separation standards, any ideas? -- --Peter Hermann(49)0711-685-3611 fax3758 --Pfaffenwaldring 27 Raum 114, D-70569 Stuttgart Uni Computeranwendungen --http://www.csv.ica.uni-stuttgart.de/homes/ph/ --Team Ada: "C'mon people let the world begin" (Paul McCartney) |
| Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 06:09 AM |
| GWB and the Air Guard | JD | Military Aviation | 77 | March 17th 04 11:52 AM |
| Crosswind components | James L. Freeman | Piloting | 25 | February 29th 04 02:21 AM |
| RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 05:08 AM |
| A-4 / A-7 Question | Tank Fixer | Military Aviation | 135 | October 25th 03 04:59 AM |
