I asked a similar question once of the local ultralight trike guru. The way
the chute was mounted, it looked to me like it would be a foregone conclusion that it would get fouled in the prop after it deployed. He said "yea, so what?" The rigging was a very heavy Kevlar strap (so he said) and would simply stop the prop cold. I wonder how many times this theory has been tested... "anonymous coward" wrote in message news ![]() Would I be right in assuming that ballistic parachutes and pusher props don't go? Thanks, AC |
"Ron Webb" wrote: I asked a similar question once of the local ultralight trike guru. The way the chute was mounted, it looked to me like it would be a foregone conclusion that it would get fouled in the prop after it deployed. He said "yea, so what?" The rigging was a very heavy Kevlar strap (so he said) and would simply stop the prop cold. I wonder how many times this theory has been tested... Nobody has ever complained of this happening. ;( |
The hand thrown one that was used out here in the Australian outback about
four weeks ago (with no report) was thrown while the prop was still rotating. The steel cable was cut by the prop, but not before it damaged the wooden prop beyond repair. The parachute did not remain with the aircraft after that. The aircraft was brought to the ground still under control and the controlled crash did not injure anyone. (Apart from a serious pride injury!) I know because I was talking to him that night about buying the advertised aircraft and he had taken it up for a last spin........ and it started running rough....... He would have to be one of the luckiest blokes I have ever talked to....... Peter |
Peter
I'd say you were the lucky one. The bird broke the flight before you bought it and not the flight after. Big John On Mon, 17 May 2004 11:36:36 +1000, "Bushy" wrote: The hand thrown one that was used out here in the Australian outback about four weeks ago (with no report) was thrown while the prop was still rotating. The steel cable was cut by the prop, but not before it damaged the wooden prop beyond repair. The parachute did not remain with the aircraft after that. The aircraft was brought to the ground still under control and the controlled crash did not injure anyone. (Apart from a serious pride injury!) I know because I was talking to him that night about buying the advertised aircraft and he had taken it up for a last spin........ and it started running rough....... He would have to be one of the luckiest blokes I have ever talked to....... Peter |
How many of the installations are professionally designed/tested? If people
are just bolting these devices on with no idea what will really happen should the worst happen and they are forced to deploy, are they really offering any safety advantage? If the BRS is just going to pull free, damaging the airframe, maybe a pilot would be better off with a parachute and letting the aircraft fare for itself. I'm sure these issues have come up before, was there any resolution? |
On Tue, 18 May 2004 10:35:45 GMT, "Occom" wrote:
How many of the installations are professionally designed/tested? If people are just bolting these devices on with no idea what will really happen should the worst happen and they are forced to deploy, are they really offering any safety advantage? I think BRS has developed mounting instructions for many popular ultralights, due to exactly this reason. I'm sure the company is happy to help develop installations for new types. Ron Wanttaja |
On Tue, 18 May 2004 13:50:00 GMT, Ron Wanttaja
wrote: :On Tue, 18 May 2004 10:35:45 GMT, "Occom" wrote: : :How many of the installations are professionally designed/tested? If people :are just bolting these devices on with no idea what will really happen :should the worst happen and they are forced to deploy, are they really :offering any safety advantage? : :I think BRS has developed mounting instructions for many popular :ultralights, due to exactly this reason. I'm sure the company is happy to :help develop installations for new types. I'm doing some work on a new, one-off ultralight with a friend, we're putting a BRS on it. They are absolutely happy to help. It's actually not all that complex. Attach the bridal to something that's 1) the strongest part of the airplane and 2) will dangle the airplane in a reasonable attitude. Make sure that the pilot's seat and seatbelt are attached to the airframe via a method 10 times as strong as you think they need to be. Etc. Of course, there's no reason you can't have both a BRS AND a personal 'chute. We intend to, especially for early flights. |
Hi, I have an HP-16 in which I installed a BRS 1050hd. I can comment
on a few of the earlier comments: 1. ...substantial weight penalty. I didn't think so. Weighs 24 pounds or so, total, including installation. Backpack parachute runs at least 12-14 pounds, so really, I don't see 10 pounds as a significant issue. 2...speed issues: The 1050 is rated to deploy at 172 mph. While my HP-16 can go faster (assuming I am willing to sacrifice the wings), given that BRS claims (quietly) at least a 150% safety margin, I ought to be ok. Further the parachute is rated for 1050 pounds, and my glider and I barely make 750. All the more margin. 3...when I use it, the glider is written off. You bet. If I need to pull the handle, I will be in a situation wherein I would have chosen to leave the airplane...which would write off the airplane for sure. 4. Why not just bail out? Well, basically, looking at the data, few folks live who step out of their glider at less than around 1000 feet. Mine would be particularly hard for ME to get out of, so that margin might be cutting it close. Pull the handle, and I ought to have a canopy at around 200 feet, assuming any non-downward velocity at all. Seems safer to me. The only real issue is the landing. The Cirri have their landing gear to absorb the shock. Clearly a glider has less structure under it. I have the system rigged to lower me fairly significantly nose down, and I intend to lower the landing gear once under canopy. One hopes that the rotation of the glider from the nose to the main gear will absorb sufficient energy to protect my back. I suspect I would be better off, however, with a canopy, than I would have been without in any circumstance under which I would deploy the canopy. I've included my email, feel free to correspond. If you write me, you will have to go to the spamarrest website to get to me. It's easy, and you'll get an email response telling you what to do. Great anti-spam protection. Jim |
Bushy wrote:
The hand thrown one that was used out here in the Australian outback about four weeks ago (with no report) was thrown while the prop was still rotating. The steel cable was cut by the prop, but not before it damaged the wooden prop beyond repair. The parachute did not remain with the aircraft after that. The aircraft was brought to the ground still under control and the controlled crash did not injure anyone. (Apart from a serious pride injury!) I know because I was talking to him that night about buying the advertised aircraft and he had taken it up for a last spin........ and it started running rough....... He would have to be one of the luckiest blokes I have ever talked to....... Peter No, you were quite a bit luckier. It wasn't your aircraft yet. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Of parachutes and things | ShawnD2112 | Aerobatics | 34 | July 21st 04 06:13 PM |
Ballistic chute saves 4 souls | Bob Babcock | Home Built | 28 | April 27th 04 09:29 PM |
Parachutes for sale | Ken Ibold | Aerobatics | 0 | September 23rd 03 05:39 PM |
virgins (was: Question - Regarding Canard Pushers...) | RobertR237 | Home Built | 1 | August 10th 03 11:06 PM |
Question - Regarding Canard Pushers... | Tilt | Home Built | 33 | August 10th 03 11:07 AM |
