jls wrote:
"Barnyard BOb -" wrote in message ... Both these guys are classic extremes of how dumb luck can rule! Blanton survived in spite of himself while Wittman died because of himself. - Barnyard BOb - Not so fast, BoOb. Wittman was around 90 when he died. At the time he covered his aircraft with polyester fabric and used dope to glue and finish it, it was a popular thing to do. - jls +++++++++++++++++++++++++++++++++++++++++ GEEZUS!!!! Perhaps you did not see Dave Hyde's post regarding Wittman.... "AILERON-WING FLUTTER INDUCED BY SEPARATION AT THE TRAILING EDGE OF AN UNBONDED PORTION OF WING FABRIC AT AN AILERON WING STATION. THE DEBONDING OF THE WING FABRIC WAS A RESULT OF IMPROPER INSTALLATION." Also... Steve Wittman Accident http://www.beginat.com/EAA724/newsltrs/96-02.htm The February Sport Aviation has a summary of the findings of the NTSB on the cause of the crash of Steve Wittman's O&O Special last April. To condense and simplify the article greatly, it appeared that Steve painted the Poly-Fiber covering to the plywood wing with the nitrate dope he had used for years with natural fiber wing coverings, instead of with the approved Poly-Brush. Poly-Tak is the glue; poly-brush is a weave filler. You're not all that good with facts, are you? Neither are you, for that matter. Go back to the Polyfiber manual... |
![]() "Richard Lamb" wrote in message ... jls wrote: "Barnyard BOb -" wrote in message ... Both these guys are classic extremes of how dumb luck can rule! Blanton survived in spite of himself while Wittman died because of himself. - Barnyard BOb - Not so fast, BoOb. Wittman was around 90 when he died. At the time he covered his aircraft with polyester fabric and used dope to glue and finish it, it was a popular thing to do. - jls +++++++++++++++++++++++++++++++++++++++++ GEEZUS!!!! Perhaps you did not see Dave Hyde's post regarding Wittman.... "AILERON-WING FLUTTER INDUCED BY SEPARATION AT THE TRAILING EDGE OF AN UNBONDED PORTION OF WING FABRIC AT AN AILERON WING STATION. THE DEBONDING OF THE WING FABRIC WAS A RESULT OF IMPROPER INSTALLATION." Also... Steve Wittman Accident http://www.beginat.com/EAA724/newsltrs/96-02.htm The February Sport Aviation has a summary of the findings of the NTSB on the cause of the crash of Steve Wittman's O&O Special last April. To condense and simplify the article greatly, it appeared that Steve painted the Poly-Fiber covering to the plywood wing with the nitrate dope he had used for years with natural fiber wing coverings, instead of with the approved Poly-Brush. Poly-Tak is the glue; poly-brush is a weave filler. You're not all that good with facts, are you? Neither are you, for that matter. Go back to the Polyfiber manual... Today I used some Poly-Tak, an aircraft fabric cement, as a structural adhesive. I don't use Poly-Brush as a structural adhesive, but you're welcome to for those little flitting 50 mph things you build. |
![]() "Richard Lamb" wrote in message ... jls wrote: "Barnyard BOb -" wrote in message ... Both these guys are classic extremes of how dumb luck can rule! Blanton survived in spite of himself while Wittman died because of himself. - Barnyard BOb - Not so fast, BoOb. Wittman was around 90 when he died. At the time he covered his aircraft with polyester fabric and used dope to glue and finish it, it was a popular thing to do. - jls +++++++++++++++++++++++++++++++++++++++++ GEEZUS!!!! Perhaps you did not see Dave Hyde's post regarding Wittman.... "AILERON-WING FLUTTER INDUCED BY SEPARATION AT THE TRAILING EDGE OF AN UNBONDED PORTION OF WING FABRIC AT AN AILERON WING STATION. THE DEBONDING OF THE WING FABRIC WAS A RESULT OF IMPROPER INSTALLATION." Also... Steve Wittman Accident http://www.beginat.com/EAA724/newsltrs/96-02.htm The February Sport Aviation has a summary of the findings of the NTSB on the cause of the crash of Steve Wittman's O&O Special last April. To condense and simplify the article greatly, it appeared that Steve painted the Poly-Fiber covering to the plywood wing with the nitrate dope he had used for years with natural fiber wing coverings, instead of with the approved Poly-Brush. Poly-Tak is the glue; poly-brush is a weave filler. You're not all that good with facts, are you? Neither are you, for that matter. Go back to the Polyfiber manual... Lest others are misled by you and the BOob: http://www.polyfiber.com/techquestions/attachingfabric/ |
" jls" wrote in message ...
"Barnyard BOb -" wrote in message ... Both these guys are classic extremes of how dumb luck can rule! Blanton survived in spite of himself while Wittman died because of himself. - Barnyard BOb - Not so fast, BoOb. Wittman was around 90 when he died. At the time he covered his aircraft with polyester fabric and used dope to glue and finish it, it was a popular thing to do. - jls +++++++++++++++++++++++++++++++++++++++++ GEEZUS!!!! Perhaps you did not see Dave Hyde's post regarding Wittman.... "AILERON-WING FLUTTER INDUCED BY SEPARATION AT THE TRAILING EDGE OF AN UNBONDED PORTION OF WING FABRIC AT AN AILERON WING STATION. THE DEBONDING OF THE WING FABRIC WAS A RESULT OF IMPROPER INSTALLATION." Also... Steve Wittman Accident http://www.beginat.com/EAA724/newsltrs/96-02.htm The February Sport Aviation has a summary of the findings of the NTSB on the cause of the crash of Steve Wittman's O&O Special last April. To condense and simplify the article greatly, it appeared that Steve painted the Poly-Fiber covering to the plywood wing with the nitrate dope he had used for years with natural fiber wing coverings, instead of with the approved Poly-Brush. Poly-Tak is the glue; poly-brush is a weave filler. You're not all that good with facts, are you? Kinda makes one wonder whether he even built that Fly Baby,,doesn't it ??? |
![]() "Ben Haas" wrote in message om... " jls" wrote in message ... "Barnyard BOb -" wrote in message ... Both these guys are classic extremes of how dumb luck can rule! Blanton survived in spite of himself while Wittman died because of himself. - Barnyard BOb - Not so fast, BoOb. Wittman was around 90 when he died. At the time he covered his aircraft with polyester fabric and used dope to glue and finish it, it was a popular thing to do. - jls +++++++++++++++++++++++++++++++++++++++++ GEEZUS!!!! Perhaps you did not see Dave Hyde's post regarding Wittman.... "AILERON-WING FLUTTER INDUCED BY SEPARATION AT THE TRAILING EDGE OF AN UNBONDED PORTION OF WING FABRIC AT AN AILERON WING STATION. THE DEBONDING OF THE WING FABRIC WAS A RESULT OF IMPROPER INSTALLATION." Also... Steve Wittman Accident http://www.beginat.com/EAA724/newsltrs/96-02.htm The February Sport Aviation has a summary of the findings of the NTSB on the cause of the crash of Steve Wittman's O&O Special last April. To condense and simplify the article greatly, it appeared that Steve painted the Poly-Fiber covering to the plywood wing with the nitrate dope he had used for years with natural fiber wing coverings, instead of with the approved Poly-Brush. Poly-Tak is the glue; poly-brush is a weave filler. You're not all that good with facts, are you? Kinda makes one wonder whether he even built that Fly Baby,,doesn't it ??? You can safely assume he didn't, unless there are pictures and supporting affidavits. An authentic builder, not BB, built the single-place RV-3 he flies. |
Barnyard BOb - wrote in
: Both these guys are classic extremes of how dumb luck can rule! Blanton survived in spite of himself while Wittman died because of himself. - Barnyard BOb - Not so fast, BoOb. Wittman was around 90 when he died. At the time he covered his aircraft with polyester fabric and used dope to glue and finish it, it was a popular thing to do. - jls +++++++++++++++++++++++++++++++++++++++++ GEEZUS!!!! Perhaps you did not see Dave Hyde's post regarding Wittman.... "AILERON-WING FLUTTER INDUCED BY SEPARATION AT THE TRAILING EDGE OF AN UNBONDED PORTION OF WING FABRIC AT AN AILERON WING STATION. THE DEBONDING OF THE WING FABRIC WAS A RESULT OF IMPROPER INSTALLATION." Also... Steve Wittman Accident http://www.beginat.com/EAA724/newsltrs/96-02.htm The February Sport Aviation has a summary of the findings of the NTSB on the cause of the crash of Steve Wittman’s O&O Special last April. To condense and simplify the article greatly, it appeared that Steve painted the Poly-Fiber covering to the plywood wing with the nitrate dope he had used for years with natural fiber wing coverings, instead of with the approved Poly-Brush. The O&O Special flew for 10 years. The NTSB believes that on the April trip back to Oshkosh, the fabric in front of the right aileron finally debonded and ballooned up, which caused the aileron and then both wings to flutter. The wings separated from the aircraft. The article stresses the importance of using components approved by the manufacturer when covering an aircraft. MY POINT for you guys too dense to understand -- One is never too young, too old or too famous to *NOT* 'screw the pooch'. --- correction screw+the+pooch... buy the farm...not just a screw up... the most major screw up... like auger in... ask a pilot JFK JR, screwed the pooch! screw+the+pooch.... to **** up Barnyard BOb -- WOW bet he wished he had a BRS system heh??? -- ET ![]() "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
On Thu, 20 May 2004 18:19:23 GMT, ET wrote:
MY POINT for you guys too dense to understand -- One is never too young, too old or too famous to *NOT* 'screw the pooch'. --- correction screw+the+pooch... buy the farm...not just a screw up... the most major screw up... like auger in... ask a pilot JFK JR, screwed the pooch! screw+the+pooch.... to **** up Barnyard BOb -- WOW bet he wished he had a BRS system heh??? ++++++++++++++++++++++++++++++++++ You can't believe the 'lively' exchange this subject generated on the RV List when a BRS engineer 'axed' for comments concerning equipping RV's with the BRS system. Barnyard BOb -- |
WOW bet he wished he had a BRS system heh??? I doubt he'd have had time to deploy it. Destructive flutter can be blindingly quick and violent, especially flutter that rips wings off. I'm guessing they would have felt a violent shaking as their initial "warning", a split second later the wings depart and the fuselage gyrates to the ground pinning them inside due to the G forces. Corky Scott |
![]() "ET" wrote in message ... Barnyard BOb - wrote in : Barnyard BOb blahblahblahblahblah -- WOW bet he [Steve Wittman] wished he had a BRS system heh??? -- ET ![]() Funny you should bring that up. This evening on the 6:30 ABC news, Peter Jennings' last item was devoted to the ballistic chute. The Cirrus owner who lost a wing and deployed his chute over Dallas was interviewed, and his plane shown, "intact" the owner said, in the bushes near a golf course. Also interviewed was one of the Klapmeiers, a Cirrus designer/engineer. A high-wing Cessna was shown deploying its chute, as well as a downward-spiraling ultralight with its wings folded up. Whoever was in the ultralight would have surely screwed the pooch had the ballistic chute not opened. I have a lot of respect for Steve Wittman and feel a little disdain for someone like the BOob making light of his sad demise. As between Wittman, for whom the airport, Wittman Field, at Oshkosh is named, and BOob, the latter will never have poetry written to honor him or go down in history as a great flier, aircraft innovator. and air racer. |
.. . I have a lot of respect for Steve Wittman and feel a little disdain for someone like the BOob making light of his sad demise. As between Wittman, for whom the airport, Wittman Field, at Oshkosh is named, and BOob, the latter will never have poetry written to honor him or go down in history as a great flier, aircraft innovator. and air racer. Plonk! |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
harley engine | Air Methods Corporation | Home Built | 1 | September 21st 03 08:13 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
