"dave" wrote in message
... W&B plugged into my GPS. Does that count if I didn't, although I do, have a paper copy of the W&B? Only the W&B form signed by a mechanic counts as the legally required W&B -- a GPS database does not suffice. Does a fresh printout from aeroplanner count as a current chart? There is no legal requirement for you to carry VFR charts period -- just a requirement that you obtain all necessary information before the flight. For IFR you would be unable to accept airways clearances or deal with lost communication procedures without charts, so charts are required there as part of the requirement for appropriate navigation equipment. -------------------- Richard Kaplan, CFII www.flyimc.com |
![]() There is no legal requirement for you to carry VFR charts period -- just a requirement that you obtain all necessary information before the flight. I've been told (never been ramp-checked myself) that the FAA guy can interpret this to mean that your chart must be current. (That is, you don't have to carry a chart, but you may not carry a chart that is out of date.) And it would seem that, if you irritated the inspector by say refusing to let go of your pilot certificate, he could declare on the spot that, obviously, "all necessary information" includes a chart! Personally, I would rather not take the chance. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
![]() "Cub Driver" wrote in message ... I've been told (never been ramp-checked myself) that the FAA guy can interpret this to mean that your chart must be current. I know this is a prevalent story, but I have never read of any enforcement action on this. It is very clear that the FAA's standard does not require any sectional chart at all for flight in your traffic pattern or the immediate vicinity of your airport. Is having an old chart onboard worse than no chart? No. I always do have current charts onboard for wherever I plan to fly, and when I fly cross-country I often carry with me expired charts for areas quite a bit off course but where theoretically I might divert in a doomsday situation. Does having those just-in-case expired charts make me less safe? No, of course not. Again, I do not believe there has ever been an enforcement action on this issue, nor could/should there be one. Again, you DO clearly need current IFR charts -- but even there, what's wrong with carrying expired charts for places you don't plan to go unless some one-in-a-million weather or mechanical event occurs? -------------------- Richard Kaplan, CFII www.flyimc.com |
![]() Cub Driver wrote: There is no legal requirement for you to carry VFR charts period -- just a requirement that you obtain all necessary information before the flight. I've been told (never been ramp-checked myself) that the FAA guy can interpret this to mean that your chart must be current. As of 1997, this is not the case, according to inspector Ryan of the Allentown FSDO. The triggering incident was a case in which an inspector violated a pilot for having an out-of-date database in his GPS. The inspector argued that this was exactly the same as having an out-of-date chart. The FAA agreed with the logic and issued orders to all the inspectors that out-of-date charts are ok. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
"Richard Kaplan" wrote in message
Only the W&B form signed by a mechanic counts as the legally required W&B -- a GPS database does not suffice. Can you point me to an FAR that says this? Thanks, Bruce Bockius |
... What is "He can check the aircraft for the required anti-drug exterior data plate." ? it is the exterior data plate normally near the tail required for DEA gliders are exempt BT |
I haven't heard about this. How does a data plate help the DEA?
"BTIZ" wrote in message news:BFIdc.478$Va4.278@fed1read01... "dave" wrote in message ... What is "He can check the aircraft for the required anti-drug exterior data plate." ? it is the exterior data plate normally near the tail required for DEA gliders are exempt BT |
![]() Peter Gottlieb wrote: I haven't heard about this. How does a data plate help the DEA? The argument goes that it makes it easy for them to check the ID of the plane without having to enter the plane and it's more difficult to falsify than the painted N-numbers. And I have some ocean-front property in Valdosta I'd like to show you, too. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
What about this?
You hand an inspector your papers during a ramp check.... He stupidly takes or keeps something he has no legal right to....that you cant replace on the spot... You are stuck in Middle of Nowhere, Crappy State USA....you and the plane NEED to get somewhere NOW.... You continue on your flight path to your destination.... Now youve shown up somewhere else WITHOUT a critical piece of paper.... WHO gets in trouble for not having the correct papers at the second ramp check? I no nutin about piloting....and an inspector would have to be real jerk before I'd be anything but polite, helpful, and respectable.... but I'm not sure I'd physically let go of any critical piece of paperwork I needed either... As they say...."possesion is 9/10ths of the law" take care Blll |
![]() "BTIZ" wrote in message news:Pvmdc.364$Va4.47@fed1read01... He can check the aircraft for the required anti-drug exterior data plate. The reason for the data plate is much the same as the VIN on your car, with the additional purpose of ensuring that someone just doesn't go building a Cessna 172 out of spare parts. Drugs has nothing to do with it. A friend of mine just bought a Beaver in Canada. The plane had a long history in both the US and Canada, having been owned at various times by different owners on both sides of the border. Anyway, when he went to register the plane he found that it was listed as destroyed. The data plate was an illegal duplicate. There were actually two Beavers flying around with the same data plate for awhile. My friend wanted to use the Beaver for charter, but now the FAA says that because of the incomplete records and questionable past the plane can never be certified as anything but experimental. Apparently several former owners on both sides of the border knew all this and just turned a blind eye toward it; now they are all pointing fingers at each other. Dehavilland is threatening to get into the act, tracking down and suing whoever built an illegal copy of its plane. It is a huge mess and everyone is starting to file lawsuits against everybody else. Nevertheless, there are apparently a lot of Beavers out there that have the same problem. Air America ran into some of the same problem. A lot of those Pilatus Porters came back badly shot up and Air America started cobbling together whole new planes out of salvaged parts. They eventually went to manufacturing planes from spare parts, including special modifications that little resembled the original Porters. They made up new data plates and even had multiple airplanes flying around with the same tail numbers and duplicate data plates. Pilatus eventually sued for infringement, and won. The illegal aircraft were ordered destroyed. It was a factor in Congress' decision to shut Air America down (one of many, including complaints from other airlines that the government should not be competing directly with them, the discovery that some pilots were conducting illegal activities, the airline's cover had been completely blown, and -- most importantly -- the CIA's determination that they no longer needed the airline). |
I'M GOING TO DIE TODAY. | ArtKramr | Military Aviation | 0 | February 4th 04 09:44 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In | Zeno | Aerobatics | 0 | August 2nd 03 07:31 PM |
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In | zeno | Military Aviation | 0 | July 14th 03 07:31 PM |
The Yankee Lady Flew Today | Tom Huxton | Piloting | 0 | July 11th 03 11:57 PM |
