![]() If you cause a problem, though, you'll have some explaining to do. That reminds me of what my flight instructor said on the subject of whether the FAA actually requires a certificated pilot or mechanic at the controls when you are propping a plane: "Dan, there are a whole lot of reasons why you would not want this to become an issue." all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
vincent p. norris wrote in message . ..
Again, you DO clearly need current IFR charts -- Although I can't imagine setting off on an IFR flight without a current IFR chart, it is not requried to have ANY chart on an IFR flight! If you get to your destination without a problem fine. If you cause a problem, though, you'll have some explaining to do. vince norris Maybe from a literal reading context under part 91. But the individual ops specs of FAR135 or FAR121 will specifiy what pubs crewmembers must carry. But still Vince, I just can't buy this even under part 91. The careless and reckless part of the regs will always be applicable. And the FAA may require an IFR proficiency check on your ass. If you show up without charts the check is over before it even starts. I once was jumpseating on an MD-11 from HKG to OAK. The Captain felt that way and just decided that he'd use the F/O's Jepps that trip so he left his at home(what an asshole.) Anyway the co-pilot pulls out his STAR that ATC just cleared him on and sets it on the center pedastal in front of the thrust levers so that both pilots could see the arrival. We didn't see it happen, but I've witnessed this befo It just disappeared! Suction from avionics fans probably slurpped it down the crack! I made the mistake of telling the captain about this possibility as he was blaming the F/O for losing it. The Capt then asks me to tear up the floor hatch behind him and go down in the "hell hole" and look for it. That was the end of my white shirt! About like an MIR space station EVA. Took a couple of minutes hanging upside down just to look for the damned avionics bay light switch down there. Then it was a real snake act to get my fat body through the tiny hole and traverse over up under the center cockpit. Never did find it. Moral of the story: carry your ****ing charts, dammit! pacplyer - out |
![]() Cub Driver wrote: There is no legal requirement for you to carry VFR charts period -- just a requirement that you obtain all necessary information before the flight. I've been told (never been ramp-checked myself) that the FAA guy can interpret this to mean that your chart must be current. As of 1997, this is not the case, according to inspector Ryan of the Allentown FSDO. The triggering incident was a case in which an inspector violated a pilot for having an out-of-date database in his GPS. The inspector argued that this was exactly the same as having an out-of-date chart. The FAA agreed with the logic and issued orders to all the inspectors that out-of-date charts are ok. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
"Richard Kaplan" wrote in message
Only the W&B form signed by a mechanic counts as the legally required W&B -- a GPS database does not suffice. Can you point me to an FAR that says this? Thanks, Bruce Bockius |
"dave" wrote in message
... What is "He can check the aircraft for the required anti-drug exterior data plate." ? it is the exterior data plate normally near the tail required for DEA gliders are exempt BT |
I haven't heard about this. How does a data plate help the DEA?
"BTIZ" wrote in message news:BFIdc.478$Va4.278@fed1read01... "dave" wrote in message ... What is "He can check the aircraft for the required anti-drug exterior data plate." ? it is the exterior data plate normally near the tail required for DEA gliders are exempt BT |
![]() Peter Gottlieb wrote: I haven't heard about this. How does a data plate help the DEA? The argument goes that it makes it easy for them to check the ID of the plane without having to enter the plane and it's more difficult to falsify than the painted N-numbers. And I have some ocean-front property in Valdosta I'd like to show you, too. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
![]() "G.R. Patterson III" wrote in message ... Peter Gottlieb wrote: I haven't heard about this. How does a data plate help the DEA? The argument goes that it makes it easy for them to check the ID of the plane without having to enter the plane and it's more difficult to falsify than the painted N-numbers. Aha. Pretty much as I figured. |
![]() The argument goes that it makes it easy for them to check the ID of the plane without having to enter the plane and it's more difficult to falsify than the painted N-numbers. Oh! You mean the *data plate*? But haven't they been on airplanes all along? That plate on Zero Six Hotel, starboard side, near the tail--that's discouraging me from running drugs to Wiscassett, Maine? Well, I'll be swanned. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
![]() Cub Driver wrote: The argument goes that it makes it easy for them to check the ID of the plane without having to enter the plane and it's more difficult to falsify than the painted N-numbers. Oh! You mean the *data plate*? But haven't they been on airplanes all along? Most, not all planes. Now they all have to be in the same spot. Pilots side on the fuselage just in fron of the tail. |
I'M GOING TO DIE TODAY. | ArtKramr | Military Aviation | 0 | February 4th 04 09:44 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In | Zeno | Aerobatics | 0 | August 2nd 03 07:31 PM |
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In | zeno | Military Aviation | 0 | July 14th 03 07:31 PM |
The Yankee Lady Flew Today | Tom Huxton | Piloting | 0 | July 11th 03 11:57 PM |
