A Bush C150? With Leading Edge Slats?
Old May 23rd 04, 03:38 AM
Default A Bush C150? With Leading Edge Slats?
Hello, I have a long term goal of making a small bush plane: 450lbs
useful load, 35mph clean stall, 600 ft clear 50ft. I know there are
quite a few designs out there, PA-11 Cub, Bushcaddy, Zenith CH701 to
name a few that I'm kind of familiar. But here, I'm looking into the
possiblity of working it out on a c150.
First of all, I want to say that this C150 will have a much lower
gross when used for bush flying, I know it'll be 1400# with no mods
but I like to see if I could push it down to 1300#. And now I want to
tackle on one aspect this time, how to improve the wings to
significantly reduce the stall speed.
First a question, anyone knows how far away the C150 wings is from an
ideal high lift design, i.e., if you would design it again (keep the
area and weigh the same and also conventional shape etc) how much can
you lower the stall speed?
I'm guessing for a certain design the stall speed is proportional to
the square root of the wingloading. The stock C150 is 10lb/ft^2 and
stalls at 48mph, while, for example, it is 8.9 and 30mph for the
Bushcaddy R120. So if I trust the number, the wings for the Bushcaddy
must be way more more efficient than that of the C150. What's the deal
here?
Now the CH701 is interesting that it has a leading edge slats. I'm
wondering how much improvement you can make if you put one set on the
C150 wings? As far as I know, there is noboby working on that. (I'm
aware of the Dakota slotted wing for the Cubs.) But it does not look
like too difficult. Any slats expert here?
Oh, let's not worry about the FAA part for now.
Thanks,
Jizhong
Old May 23rd 04, 04:01 AM
Kevin Horton
On Sat, 22 May 2004 19:38:56 -0700, jizhonghe wrote:
I'm guessing for a certain design the stall speed is proportional to the
square root of the wingloading. The stock C150 is 10lb/ft^2 and stalls at
48mph, while, for example, it is 8.9 and 30mph for the Bushcaddy R120. So
if I trust the number, the wings for the Bushcaddy must be way more more
efficient than that of the C150. What's the deal here?
The airspeed of interest for this calculation is equivalent airspeed,
although that is almost exactly the same as calibrated airspeed at low
speeds and altitudes. But the BushCaddy stall speeds are almost certainly
indicated airspeeds, as kit aircraft companies rarely have the resources
to determine the airspeed position error. Indicated stall speeds are
almost always lower than calibrated stall speeds, so they like to quote
the lower number.
Bottomline - the BushCaddy might very well have an indicated stall speed
near 30 mph (there web site claims 32 mph, but it isn't clear whether this
is power off or power on), but the calibrated stall speed would almost
certainly be higher than that.
For example, the C182Q POH that I am looking at shows a full flap, power
off stall speeds of 38 kt IAS which equals 50 kt CAS. With flaps up, the
error is even larger - 41 kt IAS = 56 kt CAS.
Don't pay too much attention to quoted stall speeds unless you have
proof that they are calibrated airspeeds.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
e-mail: khorton02(_at_)rogers(_dot_)com
Old May 23rd 04, 05:04 AM
Great. Thanks for the clarificaiton. I always thought they just give
you a low number. Now I know at least they are honest albeit
misleading. So I looked up the C152 POH and the CAS stall clean is
actually 47kts (54mph). I should re-adjust my goal. I think a CAS of
40mph should be quite respectable for a little bush plane. And the
square of (54/40)^2=1.83 with the light weight should be able to
reduce the T/O run by half.
Anyone know what's the calibrated clean stall for a PA-11 Cub?
Jizhong
the lower number.
Old May 23rd 04, 05:45 AM
Bushy
Go and get a "Texas Taildragger" C 150 conversion. Maybe even an aerobatic
one.....
You don't really want a C150 nosewheel to hit a rabbit hole.....
Hope this helps,
Peter
Old May 23rd 04, 06:16 AM
Oh yes that's for sure (and big fat tires). Like I said, for now, I
just want to focus on the wing. Do you know if I'm going to save some
weight with the conversion?
Jizhong
On Sun, 23 May 2004 13:45:19 +1000, "Bushy"
one.....
Hope this helps,
Peter
Old May 23rd 04, 05:55 PM
On Sun, 23 May 2004 15:07:11 GMT, Richard Lamb
Jizhong
A better starting question might be "do you know what you are doing"?
I know what I'm asking. It's a difference between starting doing
something and discussing something.
"W" is JFK's son and Bush revenge killed Kennedy in 1963 Ross C. Bubba Nicholson Aerobatics 0 August 28th 04 12:28 PM
-7 wing leading edge 'glitch' ? Charlie England Home Built 0 March 7th 04 01:27 AM
Bush/Hitler creates another phony "terrorist" incident to suppress us... John Ousterhout Home Built 60 January 6th 04 11:49 PM
tail buffeting and leading edge fillets, strakes Wallace Berry Home Built 1 September 26th 03 11:48 PM
Slats and Fowler Flaps On Light Plane Brock Home Built 28 July 31st 03 11:12 PM
