While I generally agree with your statements about old instruments,
presumably the instruments in a Cirrus SR22 are not very old. Mike MU-2 "Michael" wrote in message om... Peter R. wrote An interview with the pilot suggests that poor avionics maintenance may have been the cause. I wonder how many of those "Loss of control in IMC" accidents, generally attributed to pilot error, are really the result of multiple failures. Face it, guys - we're flying old obsolete junk. I know lots of pilots who tell stories of multiple failures on a single flight. It happens. However, flying into low IMC immediately after the aircraft returned from maintenance may have been a bad decision. In my opinion, it's an absolutely unacceptable decision. Test flights are day-VFR events. I've had things go wrong on test flights before, and they didn't always have an obvious connection to the maintenance being performed. However, since I always landed the plane, I was always able to do a detailed examination of the intact systems afterwards - and in the end, it always turned out that the failures were related to the maintenance, though in non-obvious ways that generally pointed out previous marginal maintenance and/or very poor design that clearly did not include a complete analysis of the failure modes. But of course he had a parachute. Would he have launched into low IMC without a parachute immediately following maintenance? Michael |
"Mike Rapoport" wrote
While I generally agree with your statements about old instruments, presumably the instruments in a Cirrus SR22 are not very old. There's a difference between a new instrument, and an instrument that was recently manufactured to an obsolete design. I've spent years designing instruments (not for aviation - no money there) and learned something interesting. No design is static - it either evolves or rots. When an instrument is first designed, there are inevitable growing pains in manufacturing. This is expected, and it's fairly typical for a design engineer to spend a fair amount of time in manufacturing to bring the production people up to speed. But that's not the end. In a normal environment, there are continuous changes. Upgrades are made. Production processes are streamlined. Lower cost vendors are found, and engineering asessments/changes are made to accomodate the lower cost parts. Subassemblies are outsourced, and invariably the outsourcing process turns up problems in the documentation. But even if you don't plan any changes, they happen anyway. Vendors change their products subtly, or discontinue them completely, or just go out of business. Design and production changes are made to accomodate this. Eventually the design ages to the point where too many parts are unavailable, better methods exists, and it's time to redesign from scratch. That's a normal product life cycle. In GA, the process is perverted. Any change triggers a paperwork avalanche, so changes are avoided at all costs. Engineering involvement with a product post-release is dramatically reduced. Life cycles are very long. As a result, when an unplanned change occurs, the product often gets worse. This is a well-documented phenomenon in aviation engines (when was the last time a large Continental jug made TBO?) but it's even more true for smaller products. This was a steam gauge Cirrus. The gauges in it were more than likely of relatively recent manufacture - and obsolete design. Michael |
![]() "Michael" wrote in message om... Peter R. wrote An interview with the pilot suggests that poor avionics maintenance may have been the cause. I wonder how many of those "Loss of control in IMC" accidents, generally attributed to pilot error, are really the result of multiple failures. Face it, guys - we're flying old obsolete junk. I know lots of pilots who tell stories of multiple failures on a single flight. It happens. Well, maybe *you* are flying old obsolete junk, but a Cirrus hardly qualifies. In fact, even the old obsolete junk tends to have fairly new equipment in it. I know lots of pilots, too. Some of them have even more experience than what you claim to have. And they tell a lot of stories. I don't think that necessarily means that the stories are accurate depictions of events or that the pilots interpreted those events correctly. Even so, I will allow that multiple failures in different systems happen and I never said that they didn't. I have lost the radar, the oil pressure in one engine, and had a life raft deploy and wrap itself around the tail simultaneously while IMC and in thunderstorms. What are the odds? My point is that Occam's razor usually works -- the simplest explanation is generally the most probable. The most probable explanation here is that the pilot became disoriented and only thought all his instruments were failing when none of them or perhaps only one or two of them were actually failing. That does not mean that I don't think what the pilot says happened is impossible. It is just a less likely scenario. I think you are the only pilot I know who claims to have your kind of experience who disagrees with that. |
C J Campbell ) wrote:
snip My point is that Occam's razor usually works -- the simplest explanation is generally the most probable. The most probable explanation here is that the pilot became disoriented and only thought all his instruments were failing when none of them or perhaps only one or two of them were actually failing. That does not mean that I don't think what the pilot says happened is impossible. Your explanation certainly seems plausible to me. -- Peter |
No, the pilot was IFR rated and on an instrument flight plan. He had over 600
hours in his Cirrus which probably makes him one of the higher-time pilots in type. Dave Reinhart C J Campbell wrote: "Marco Leon" mleon(at)optonline.net wrote in message ... Sure the chute worked as advertised. Great. What irks me is how and why the aircraft experienced all these instrument failures one right after another. The man flew into IMC at 400 feet (I believe he was VFR and had no instrument rating) and probably became disoriented. His instruments did not fail. He did. |
![]() "David Reinhart" wrote in message ... No, the pilot was IFR rated and on an instrument flight plan. He had over 600 hours in his Cirrus which probably makes him one of the higher-time pilots in type. Hmmm. Even though he was instrument rated and on an IFR flight plan, I still think it is far more likely that he was disoriented than that 'multiple instruments on different systems' failed. I am not saying that it is impossible for everything to go wrong, just that it is far more likely for just one thing to go wrong. In this case, I would suspect the pilot, though the instruments will certainly need to be checked out in the investigation. A lot of IFR pilots get into real trouble with the loss of the vacuum system, even though we supposedly train them to recognize such errors. There is a lot of difference between a genuine instrument failure and covering up the instrument with a sticky. I think more training time in the simulator would be valuable. |
What irks me is how and why the aircraft experienced all these instrument failures one right after another. If any of our Pipers/Cessnas/Beechcrafts had a propensity to experience near simultaneous failures of supposedly separate systems there would be an uproar. Fresh off a maintenance visit or not Is this the airplane that was flown in low IMC on the first flight after maintenance? If that's the case, then as far as I'm concerned we're looking at a case of gross pilot error. Test flights after maintenance should never be in anything other than good day-VFR. Michael |
ArtP wrote
Test flights after maintenance should never be in anything other than good day-VFR. Just about every flight I made in my SR20 was after maintenance. But you do understand that this is not normal, right? My airplane is almost 40 years old, it's more comples (2 engines instead of one, retractable gear instead of fixed) and when my plane got into that mode (it seemed that for a few weeks things were constantly breaking) I brought it down for 3 months to do an extensive annual and fix/replace all the problem items. Sometimes I had to have maintenance performed at my local FBO just so I could fly the plane to the Cirrus service center. If I couldn't make that flight the plane would be grounded for another 2 to 3 weeks while I waited for the next available appointment. Then you have a lemon. Fix it or get rid of it. Michael |
Michael ) wrote:
Then you have a lemon. Fix it or get rid of it. Apparently, you don't recall Art's post history sharing his various SR-20 lemon stories. He's been pretty active in this group about that subject. Knowing about his history, I took his post to be sarcastic humor. -- Peter |
Cirrus SR22 Purchase advice needed. | Dennis | Owning | 170 | May 19th 04 04:44 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
