I don't know where you live (my guess is Germany) but the technique you
describe works fine in the Southwest desert of the United States. I used to be able to get 500 fpm up in a 172 from the thermals around my old home patch in the Mojave desert. Dave Reinhart Kees Mies wrote: Hi All, I need some advise. The summer is starting and my plane is a rotten climber, certainly on hot days at MTOW. The best it can do in these conditions is about 300fpm. My idea is to use thermals to climb (much)faster like gliders do. Is this a stupid idea? If my idea is not that stupid how do I find thermals and how to use them properly? Maybe I should have asked this on a soaring site but I think there are a lot of pilots flying both kinds of planes. BTW, my plane is a MS880 Rallye. Thanks, Kees. D-EDMB. |
I use thermals to climb all the time.. that or ridge lift.. but then again
I'm a glider pilot and glider tow pilot. When towing,.. I use the thermals to help the climb.. with a standard VSI they are easy to locate.. not only seat of the pants lifting sensation.. but also an increase in the VSI from 500fpm to 1000fpm or better.. depending on thermal strength.. With a good glider pilot behind me, we'll turn in the thermal at up to 45 degrees of bank to help the climb.. and if the thermal is that good the glider pilot will release and I'll head back down for another glider. With a student or novice pilot.. I'll go straight through the thermal, then mild circle out away from the thermal and then back through it wings level.. marking the thermal for the glider pilot.. normally after about the 3rd pass through a thermal and at least 2000ft AGL. The glider pilot will get off to test his mettle with mother nature. BT "Kees Mies" wrote in message om... Hi All, I need some advise. The summer is starting and my plane is a rotten climber, certainly on hot days at MTOW. The best it can do in these conditions is about 300fpm. My idea is to use thermals to climb (much)faster like gliders do. Is this a stupid idea? If my idea is not that stupid how do I find thermals and how to use them properly? Maybe I should have asked this on a soaring site but I think there are a lot of pilots flying both kinds of planes. BTW, my plane is a MS880 Rallye. Thanks, Kees. D-EDMB. |
I should add.. that correct.. where there is lift.. there has to be an equal
amount of sink somewhere... I've also been towing through 400fpm sink... neither I nor the glider could climb.. we were actually loosing altitude.. if I'd drop the glider, full power would have barely maintained altitude. And no.. not rotor.. not wave.. but a down draft.. or sink.. near a thermal we had just gone through at 1200fpm up.. was working to get back to that thermal.. and the shear between the up and down was extreme.. As soon as we were firmly established in the lift again.. the glider released.. and I went back to the sink to help my descent back to the field.. did not see the glider again for about 3 hours.. he was up and gone.. BT "BTIZ" wrote in message news:4Jkhc.17907$432.9533@fed1read01... I use thermals to climb all the time.. that or ridge lift.. but then again I'm a glider pilot and glider tow pilot. When towing,.. I use the thermals to help the climb.. with a standard VSI they are easy to locate.. not only seat of the pants lifting sensation.. but also an increase in the VSI from 500fpm to 1000fpm or better.. depending on thermal strength.. With a good glider pilot behind me, we'll turn in the thermal at up to 45 degrees of bank to help the climb.. and if the thermal is that good the glider pilot will release and I'll head back down for another glider. With a student or novice pilot.. I'll go straight through the thermal, then mild circle out away from the thermal and then back through it wings level.. marking the thermal for the glider pilot.. normally after about the 3rd pass through a thermal and at least 2000ft AGL. The glider pilot will get off to test his mettle with mother nature. BT "Kees Mies" wrote in message om... Hi All, I need some advise. The summer is starting and my plane is a rotten climber, certainly on hot days at MTOW. The best it can do in these conditions is about 300fpm. My idea is to use thermals to climb (much)faster like gliders do. Is this a stupid idea? If my idea is not that stupid how do I find thermals and how to use them properly? Maybe I should have asked this on a soaring site but I think there are a lot of pilots flying both kinds of planes. BTW, my plane is a MS880 Rallye. Thanks, Kees. D-EDMB. |
Im surprised Dylan hasnt weighed in yet... He used to talk about doing
it (somewhat) in the Cessna 140 he used to be part owner in. He was a member at a local soaring club as well as the flying club that I had met him in His page, which is not very up to date, is http://www.alioth.net/flying/soaring/index.html and may have some information with regards to thermalling. The main concern as I've had related to me is that to stay in the thermal you need to fly tight and slow. Remember your stall speeds in steep banks/high G turns go UP. My best guess would be to try a best angle of climb tactic, with short field flap settings and give it a go. As for doing this on a XC trip, I dont see a whole lot of point to it.. unless you are in SLC and need to climb up out of the bowl there. Dave Kees Mies wrote: Hi All, I need some advise. The summer is starting and my plane is a rotten climber, certainly on hot days at MTOW. The best it can do in these conditions is about 300fpm. My idea is to use thermals to climb (much)faster like gliders do. Is this a stupid idea? If my idea is not that stupid how do I find thermals and how to use them properly? Maybe I should have asked this on a soaring site but I think there are a lot of pilots flying both kinds of planes. BTW, my plane is a MS880 Rallye. Thanks, Kees. D-EDMB. |
In article , Kees Mies wrote:
Hi All, I need some advise. The summer is starting and my plane is a rotten climber, certainly on hot days at MTOW. The best it can do in these conditions is about 300fpm. My idea is to use thermals to climb (much)faster like gliders do. Is this a stupid idea? No, not at all. Get some experience in a glider so you know and have felt the various sources of lift that are available. I used to own a half share in a Cessna 140. It had an 85hp engine and a cruise prop. Even at sea level, getting much more than 300fpm climb was asking a lot in that plane. I flew that plane coast to coast in the United States. That meant doing things like crossing the Sierra Nevadas, and taking off from airfields at nearly 6000' MSL. Knowing what sources of lift were avalable (and as a corollary, where the sink was likely to be) really helped climb. For example, coming out of SLC and needing to be above the mountains by Provo, I used upslope lift to help the climb rate. Doing a photo shoot over the Wasatch range was a much quicker job because there were some good thermals, and the C140 can be flown slow enough to take good advantage of them. If you are flying a plane without much power, glider experience can come in very handy indeed especially at high altitude. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Yes. But if climbing while making cross country speed and distance is the
objective, the best climb is accomplished with wings level. A powered glider of *any* sort is capable of exploiting this when going cross country. Just as any cross country glider pilot strives to 'climb straight ahead' as much as possible, it is an optimal technique for a powered a/c in cc flight. In point-to-point flight in a field of thermals, the fastest or most efficient path is *not* a straight line or is it in level flight. Go glider pilots!! "Shirley" wrote in message ... wrote: 1. As Kees noted in his last post here, efficient thermalling requires steep banking near stall. Almost all replies to this topic have given the impression that the steeper the better -- that's not *always* true. Depending on the size and strength of the thermal, sometimes banked a little less makes more effective use of the lift, exposing more of the surface of the aircraft to the rising air. --Shirley Glider Pilot |
Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 03:48 PM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
Second Stage Climb Gradient? | Bill | Instrument Flight Rules | 10 | September 15th 03 06:41 PM |
Second Stage Climb Gradient? | Bill | Piloting | 10 | September 15th 03 06:41 PM |
172 N Climb Performance | Roger Long | Piloting | 6 | September 10th 03 11:18 PM |
