Tiedown Stakes (Article in SportAv.)
Old April 21st 04, 10:44 AM
Scott
The "corkscrew" type of tiedown appear to be the most worthless type of
tiedowns. I use the tiedown set from Sporty's pilot shop. It comes
with 3 tiedown rods. They have an auger at the lower end that is about
3 or 4 inches in diameter. It is a miniature version of what is
commonly used as anchors for guy wires in tower construction. I keep
the box in the baggage compartment at all times. I also have a piece of
old ground rod about 12 to 14 inches long (so it also fits into the
box). It is a steel ground rod coated with copper. I use this to twist
the tiedowns into the ground. Works good at Oshkosh, where the ground
is usually pretty hard with a rock or two as well.
Scott, N0EDV
http://corbenflyer.tripod.com/
Building RV-4
Gotta Fly or Gonna Die
Jim Weir wrote:
(Ben Jackson)
-It mentions in one sentence near the end (last column) that he threaded
-it, and warns to get the bolts tight before you start whacking them with
-a hammer and ruining the threads.
Got it. Completely missed that sentence. Am I reading that right? That he
actually EXPECTS the exposed rod threads to peen over against the top nut? I
sort of would like to be able to disassemble it because I'm sure that the
flatwasher (or is that a lockwasher?) is going to bend and break after a couple
of dozen uses. Or, I could simply hacksaw the threaded part off and rethread
it. I doubt 18" is going to hold much tighter than 17".
http://www.rst-engr.com
Pat Tillman got what he deserved! (good article) Stephen Harding Military Aviation 6 May 5th 04 01:45 AM
Tiedown Stakes (Article in SportAv.) Jim Weir Home Built 34 April 24th 04 01:21 AM
Article: GPS Vehicle Tracking System Issues for the Buyer Johann Blake Military Aviation 0 January 16th 04 11:26 AM
Re; What do you think? Kelsibutt Naval Aviation 0 September 29th 03 06:55 AM
