"Martin" wrote in message
om... Saw just a real short clip of something on the Disc channel tonight about how methane clouds affect aircraft. Lower pressure causes the plane to drop because of reduced lift, and the altimeter to read a climb because of the pressure change. I think this show may have been in the context of bermuda triangle stuff. Maybe Im just out of the loop but I had never heard of this happening (flying into a cloud of methane I mean). They seemed to have some pretty reputable people talking about it. Anyone experience this or hear of it? I watched that Discovery episode last week and they went into detail about the theory that methane gas bubbles could sink ships and tested the theory in a lab with model ships and air bubbles. There was also a theory that flying through a methane gas cloud would effect flight; one that a piston engine would quit if there was 1% methane in the air and another that a simulator flight into such a cloud would cause reduced lift because of less dense air and the altimeter would climb rapidly even though the aircraft was dropping. http://media.dsc.discovery.com/news/...0/methane.html |
I have a lot of trouble imagining that a 1% methane concentration will stop
an engine. I use a propane torch (unlit) to start balky engines. If you direct a stream of propane into the carburetor of an engine, it will run fine. Running an engine 1% richer doesn't seem like a big deal. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "G. Burkhart" wrote in message news:w%Cnc.59722$0H1.5953725@attbi_s54... "Martin" wrote in message om... Saw just a real short clip of something on the Disc channel tonight about how methane clouds affect aircraft. Lower pressure causes the plane to drop because of reduced lift, and the altimeter to read a climb because of the pressure change. I think this show may have been in the context of bermuda triangle stuff. Maybe Im just out of the loop but I had never heard of this happening (flying into a cloud of methane I mean). They seemed to have some pretty reputable people talking about it. Anyone experience this or hear of it? I watched that Discovery episode last week and they went into detail about the theory that methane gas bubbles could sink ships and tested the theory in a lab with model ships and air bubbles. There was also a theory that flying through a methane gas cloud would effect flight; one that a piston engine would quit if there was 1% methane in the air and another that a simulator flight into such a cloud would cause reduced lift because of less dense air and the altimeter would climb rapidly even though the aircraft was dropping. http://media.dsc.discovery.com/news/...0/methane.html |
On Mon, 10 May 2004 10:31:15 -0400, Bob Chilcoat wrote:
I have a lot of trouble imagining that a 1% methane concentration will stop an engine. I use a propane torch (unlit) to start balky engines. If you direct a stream of propane into the carburetor of an engine, it will run fine. Running an engine 1% richer doesn't seem like a big deal. This was proven by repeated experiement whereby, they directly injected methane into the intake and calcualted the ratio. The radial engine reproducably died at 1%. While probably not 100% scientific (as only one radial engine was used and not independently reproduced), it certainly makes for a powerful argument. |
The theory does not pan out because it is based on a false premise: that the
Bermuda triangle exists. There is nothing supporting the idea that flying or sailing through there is any more dangerous than anywhere else. Since the Bermuda triangle is a myth, any explanation of why it exists is going to have more holes in it than the sea has bubbles. Simply put, the Bermuda triangle is a high traffic area and thus gets more accidents. Adjusting the accident rate for the amount of traffic going through there shows the Bermuda triangle to be no more dangerous than anywhere else. There are methane fields in other parts of the world, too, and volcanic vents of all types that release large volumes of all kinds of obnoxious gases. Whether these events are dangerous to ships or aircraft is one thing. They might be and it should be investigated. But they are not the cause of the "Bermuda triangle." There is nothing mysterious about any of the wrecks found in the area so far. The Discovery Channel has a distressing amount of crap on it that is not science. It seems obsessed with paranormal phenomena, spiritualism, and UFOs. |
On Mon, 10 May 2004 07:28:01 -0700, C J Campbell wrote:
The theory does not pan out because it is based on a false premise: that the Bermuda triangle exists. There is nothing supporting the idea that flying or Or you can accept the fact that the triangle is a simple area marked on a map, which has three sides where a great number of missing ships and planes go unexplained. It's not the fact that the accident rate is greater or less than other areas, it's the fact that so many go missing unexplained. As such, myth a lore grows. Thusly, scientific theories pop up from time to time in an attempt to explain the unexplained. As such, it's easy to discount the myth and legend but foolish to discount valid research, as you're willing to do. The fact that you insist on calling it a myth is completely orthogonal to any of the research and facts to date. It's fairly easy to dismiss your comments outright on this topic as they don't appear to be reflective in the least. Research which is supported by experiment, theory and scientific method is great. The fact that you seem willing to dismiss this simply because you're caught up in the mythos surround it, is pretty silly. |
![]() "Greg Copeland" wrote in message news ![]() On Mon, 10 May 2004 07:28:01 -0700, C J Campbell wrote: The theory does not pan out because it is based on a false premise: that the Bermuda triangle exists. There is nothing supporting the idea that flying or Or you can accept the fact that the triangle is a simple area marked on a map, which has three sides where a great number of missing ships and planes go unexplained. It's not the fact that the accident rate is greater or less than other areas, it's the fact that so many go missing unexplained. The trouble with that idea is that they don't go missing unexplained there with any more frequency than they do anywhere else. In fact, Lake Michigan probably has a higher rate of 'unexplained' accidents than does the Bermuda triangle, and there aren't any methane vents in Lake Michigan. |
On Mon, 10 May 2004 08:22:59 -0700, C J Campbell wrote:
The trouble with that idea is that they don't go missing unexplained there with any more frequency than they do anywhere else. In fact, Lake Michigan probably has a higher rate of 'unexplained' accidents than does the Bermuda triangle, and there aren't any methane vents in Lake Michigan. The problem with your logic is that it assumes that there must be a central cause for all unexplained accidents. Which is, of course, false. Even if it turns out a very small portion of accidents can be directly associated with plane and ship accidents, it still can mean safer routes for planes and ships, assuming the conditions can be fully understood. And, even if a small portion of accidents can be directly associated with this effect, it's impossible to determine, unless someone is doing this research. Just because you willy-nilly ignore the research because it has a stigma of legend or lore surrounding it, doesn't invalidate the research. Good research is good research even if the topic of research is mired in myth. As it relates to this topic, it very, very easily to separate myth from fact. Ignoring all that, you honestly don't find it interesting to find out that it appears a tiny amount of methane can cause an engine to stop? Even incidental observations may have merit which benefit captains and pilots. |
![]() "Greg Copeland" wrote in message news ![]() Just because you willy-nilly ignore the research because it has a stigma of legend or lore surrounding it, doesn't invalidate the research. Good research is good research even if the topic of research is mired in myth. As it relates to this topic, it very, very easily to separate myth from fact. Ignoring all that, you honestly don't find it interesting to find out that it appears a tiny amount of methane can cause an engine to stop? Even incidental observations may have merit which benefit captains and pilots. I suggest you go back and read my whole post. As I said: "There are methane fields in other parts of the world, too, and volcanic vents of all types that release large volumes of all kinds of obnoxious gases. Whether these events are dangerous to ships or aircraft is one thing. They might be and it should be investigated." I simply object to the Discovery Channel's attempt to imply that there is something particularly mysterious or even unique about the Bermuda triangle other than its geographic location. The Bermuda triangle 'problem' is a complete fabrication by one Charles Berlitz, a charlatan who did next to no research, but who published a very popular science fiction book that a lot of people took as factual. There may well be methane bubbles causing ships to sink and airplanes fall out of the sky in the Bermuda triangle. But even Discovery Channel admitted that such events would be so rare that they could never be accepted as an explanation for any known unexplained disappearances. It would be like trying to blame the unexplained disappearances on meteorites. Can meteorites destroy a plane or sink a ship? Sure, but just because a plane went down or a ship sank does not mean it was hit by a meteorite, a methane bubble, or even beamed up into a flying saucer. You know, there is a small chance that the random movement of molecules of air could suddenly cause all the molecules to suddenly migrate to the far side of the room, leaving you to suffocate in your chair. Your death would probably go down as unexplained. People might come up with all kinds of plausible theories of what killed you, and they would all probably be wrong. Seems to me such a death would surely give you some bragging rights in the hereafter, though. :-) As the Discovery Channel noted, there aren't exactly heaps of wrecks lying around these methane vents. In fact, there aren't any at all. |
![]() "Greg Copeland" wrote in message news ![]() Or you can accept the fact that the triangle is a simple area marked on a map, which has three sides where a great number of missing ships and planes go unexplained. Just read a book by a guy who was involved in all kinds of secret DIA and Navy underwater projects during the cold war. He mentions the Bermuda Triangle. Fact is there are less ships and planes on the ocean floor here than in other areas of the world. |
![]() Fact is there are less ships and planes on the ocean floor here than in other areas of the world. That's because they disappeared mysteriously as they were sinking. Jose (and it's "fewer". Less of something you measure, fewer of something you count) -- (for Email, make the obvious changes in my address) |
How high is that cloud? | Tim Hogard | Instrument Flight Rules | 26 | November 29th 04 01:40 AM |
Revisiting lapse rates (From: How high is that cloud?) | Icebound | Instrument Flight Rules | 5 | November 26th 04 09:41 PM |
Flying Cloud FBO ? | Zack Sten | Piloting | 0 | March 29th 04 02:05 AM |
Winter Cloud Tops | O. Sami Saydjari | Instrument Flight Rules | 5 | January 9th 04 08:11 PM |
Manual needed - AN/GMQ-33 Cloud Height Set | Peter Gottlieb | Military Aviation | 0 | November 21st 03 06:11 PM |
