![]() EDR wrote: You have rudder peddles, use them! I don't have any of those, but I *do* have some rudder pedals. George Patterson I childproofed my house, but they *still* get in. |
In article , G.R. Patterson III
wrote: EDR wrote: You have rudder peddles, use them! I don't have any of those, but I *do* have some rudder pedals. Thanks, at least I didn't spell it "petals". |
On Sat, 15 May 2004 19:51:00 GMT, EDR wrote:
You tricycle gear pilots need to learn what your feet are for. You have rudder peddles, use them! You're saying that once in the air, there is some kind of perceptable difference between a taildragger and a trigeared airplane? My experience has been that once in the air, tri geared or not, the required rudder use is no different one from the other. Corky Scott |
"JJS" jschneider@REMOVE SOCKSpldi.net writes:
What would you have done. What did you do? |
A little more background info:
First, without trying to impress anyone, I have been through various industrial medic, first aid, and emergency first responder training sessions repeated over and over for the last 25 years. At least one recurrency training session has been done each year. The air was very rough with at least moderate turbulence. The yokes are so low in the Cherokee that it leaves very little room to twist around in my seat. EDR: I know the rudders are capable of lifting a wing. I've flown two axis ultralights as well as tailwheel aircraft. I'd tried doing this automatically. It wasn't enough to maintain control in the rough air. Nathan: I would imagine that my Cherokee is about the same as any other Hershey bar Cherokee 140 when it comes to handling turbulence. I have plus or minus 500 hours in this particular airplane. Believe me when I say that there was no letting go of the yoke for more than a few seconds before we were in a precarious attitude. I tried it several times. Zippo: For heavens sake, that would probably dislodge the candy when she hit the ground alright, but she's the mother of my two daughters and as pretty as the day I married her 24 years ago. It ain't happening dude! Peter: Excellent suggestion. She tried it. More than once. Didn't work. Bob: Here's what I did. I tried to keep her calm. I was very afraid the candy might be sucked into a position that would totally occlude her airway. As much as she tried, she could not dislodge the candy. She could not talk but she was breathing, albeit strenuously. I hit the nearest key on the GPS, said a prayer and headed directly to the nearest airport. I monitored her closely and made suggestions, (none of which worked). I tried hitting her on the back hard enough that I knew she'd kill me if she lived through the ordeal. She tried sipping small amounts from the water bottle, hoping that it would help melt the candy. That didn't work. I intentionally lost altitude in an attempt to shorten the time to touchdown. Her coughing and gagging went on for what seemed like at least 10 minutes. I thought she might vomit and inhale the vomitus. At the first sign of her starting to have increased difficulty breathing or beginning to loose consciousness I was going to set the airplane down on the interstate or frontage road in record time. On loss of consciousness I might have tried a finger sweep, but it would have been a last resort for fear of pushing the candy deeper into her windpipe. Finally, she coughed up the offending confectionary. Even after all that time it was nearly it's full original size. Her throat was so raw and sore that she was hoarse for two days. Several trips to the ice cream store later, all was forgiven... never to be forgotten! Seriously, this is something that I had never considered happening and since then I've wondered about other airborne medical emergencies more than ever. One thing is for sure. We will put some thought into any snacks we eat in-flight from now on. If you fly with children, it might be an even more important consideration. "Bob Fry" wrote in message ... "JJS" jschneider@REMOVE SOCKSpldi.net writes: What would you have done. What did you do? |
Could SHE have held the yoke while you climbed in back and gave her the
heimlich? I suppose if not the problem would be exacerbated, but it's another reason to consider something along the pinch-hitters thing - enough traning for your wife and kids to land the plane safely if something happend to you. Or in this case, even to her. I'm glad it turned out all right. I can't even imagine how I'd feel if it were me, and it didn't. Jose -- (for Email, make the obvious changes in my address) |
Jose,
Thanks for the suggestion. This might have worked! I doubt I could have climbed into the back seat. But, I may have found a workable position if I hadn't had to keep one hand on the yoke. In her physical state I believe she may have been able to control the airplane for a very short time. I was hoping for some "out of the box" input like this. I was also hoping to get others thinking about situations they may face that they hadn't previously considered. She has been through ground school, and I was hoping to get her through a pinch hitters course but she unfortunately isn't interested. She still likes to fly and we've been through other trips since this long cross country. Every flight an adventure! Tag, you're it! "Teacherjh" wrote in message ... Could SHE have held the yoke while you climbed in back and gave her the heimlich? I suppose if not the problem would be exacerbated, but it's another reason to consider something along the pinch-hitters thing - enough traning for your wife and kids to land the plane safely if something happend to you. Or in this case, even to her. I'm glad it turned out all right. I can't even imagine how I'd feel if it were me, and it didn't. Jose -- (for Email, make the obvious changes in my address) |
"JJS" jschneider@REMOVE SOCKSpldi.net wrote in message
... [...] I tried hitting her on the back hard enough that I knew she'd kill me if she lived through the ordeal. Ack. Thank goodness you didn't wind up lodging the obstruction in even further. Remember: gravity is at work, even inside your body. Knock something loose that's inside your airway, and the most likely place for it to go is down. The last thing a person having trouble breathing needs is a whack on the back. At least, not until you turn them upside down. I'm surprised with all your emergency medical training, no one's mentioned this. The traditional Heimlich is done from behind, of course, but it seems to me that with a strong enough arm, especially with a partial obstruction, you might have had some luck from the side. Just get your fist in good under her diaphragm (not, not THAT diaphragm...this is serious you guys ![]() push hard and quick, in the same motion you'd use from behind. It would at least be worth a try. Barring success getting the thing out quickly, I can't imagine flying all the way to an airport, even one nearby. You should have appropriate landing sites below you nearly all the time. A passenger choking seems to me to be just as serious as an airplane on fire, and would warrant an emergency descent to an off-airport landing so that proper first-aid (e.g. a real from-behind Heimlich) can be given. Pete |
![]() Ack. Thank goodness you didn't wind up lodging the obstruction in even further. Remember: gravity is at work, even inside your body. Knock something loose that's inside your airway, and the most likely place for it to go is down. That was my concern too, Pete. She wasn't exactly sitting upright, though. She was doubled over, gagging more than coughing. The last thing a person having trouble breathing needs is a whack on the back. At least, not until you turn them upside down. I'm surprised with all your emergency medical training, no one's mentioned this. I'd do it again... you probably had to be there to understand. It is hard to describe her condition and varying positions with words. Sometimes she was bent over like she was about to vomit into a toilet positioned between the yokes. She would have gladly done so if possible. Rember this took place over several minutes. The traditional Heimlich is done from behind, of course, but it seems to me that with a strong enough arm, especially with a partial obstruction, you might have had some luck from the side. Just get your fist in good under her diaphragm (not, not THAT diaphragm...this is serious you guys ![]() push hard and quick, in the same motion you'd use from behind. It would at least be worth a try. Thank goodness it never came to the point that I needed to try it. Your suggested method was on my list. I'd probably have kept trying various things until successful or we were on the ground. Barring success getting the thing out quickly, I can't imagine flying all the way to an airport, even one nearby. You should have appropriate landing sites below you nearly all the time. Landing sites are few and far between in that neck of the woods. If you have a chart of the area and are unfamiliar, take a look. I think Aeroplanner might show the sectional if you want to try that. A passenger choking seems to me to be just as serious as an airplane on fire, and would warrant an emergency descent to an off-airport landing so that proper first-aid (e.g. a real from-behind Heimlich) can be given. I agree and that was my plan if things progressively got worse. The situation wasn't static. A million things ran through my mind. You are correct about the traditional Hiemlich being done from behind but there is also a modified version for a person who is passed out and lying on the floor. You roll them on their back, straddle them while kneeling and force air out of their lungs from the front side of the victim. Pete |
I would have asked her 1) are you choking? and if she nodded yes I would
have asked 2) can you talk? and if she nodded no then I would have intervened. OTherwise as long as shes moving air in SOME form or fashion I would let HER focus on clearing the obstruction and ME focus on setting down somewhere if it didnt immediately clear. If intervention were warranted (assuming a front seat passenger), I would have attempted one or two modified abdominal thrusts (with similar direction and force as a heimlich). One or two thrusts will not cause a total departure from controlled flight in my opinion, and it might provide enough effect to dislodge the obstruction. Thrust or two.. verify the plane is in control.. thrust again.. etc.. if it doesnt clear within a few moments of thrusting then its unlikely you will clear the obstruction in the air with lay skills. At that point, its purely a personal decision what do do next. Dave, RN, EMTP, PPSEL JJS wrote: While flying between Gallup N.M. and Winslow, A.Z., my passenger pulled out a peppermint candy, handed it to me and retrieved another for herself. I popped mine in my mouth, took a gulp from my water bottle and went back to enjoying the view. Shortly thereafter, my passenger starts gagging. When she had tossed the lozenge in her mouth we hit a bit of turbulence and the candy tried to enter her windpipe whole. A look of distress crossed her face as I quickly realized what had happened. Her involuntary gag reflex went into overdrive as she struggled to breathe. A feeling of helplessness crossed over me as I realized we were 35 miles from the nearest airport and it would be several minutes at best before we could land. Even if I set the airplane down on I-40 it would be at least 5-6 minutes. That would lead to me risking the lives of others. With no autopilot and while flying in rough air, an attempt at the Heimlich maneuver would undoubtedly lead to an out of control aircraft over mountainous terrain. What would you have done. |
Emergency Parachute questions | Jay Moreland | Aerobatics | 14 | December 3rd 04 05:46 PM |
Military jet makes emergency landing at MidAmerica | Otis Willie | Military Aviation | 0 | September 1st 03 02:28 AM |
Emergency landing at Meigs Sunday | Thomas J. Paladino Jr. | Piloting | 22 | August 3rd 03 03:14 PM |
First Emergency (Long Post) | [email protected] | Owning | 14 | July 23rd 03 02:46 AM |
