It was serious stuff, folks.
It was a fascinating concept, but they simply couldn't work around the problem of inevitable accidents. "Nuclear Plane crashes -- Thousands Perish!" simply was unacceptable then -- and now. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message news:vxoqc.19775$gr.1626453@attbi_s52... It was serious stuff, folks. It was a fascinating concept, but they simply couldn't work around the problem of inevitable accidents. "Nuclear Plane crashes -- Thousands Perish!" simply was unacceptable then -- and now. Except that thousands don't perish when other nuclear powered things crash, even nuclear weapons. |
![]() Jay Honeck wrote: It was a fascinating concept, but they simply couldn't work around the problem of inevitable accidents. Not true. They couldn't lick the shielding problem. George Patterson I childproofed my house, but they *still* get in. |
In article vxoqc.19775$gr.1626453@attbi_s52, Jay Honeck wrote:
It was a fascinating concept, but they simply couldn't work around the problem of inevitable accidents. "Nuclear Plane crashes -- Thousands Perish!" simply was unacceptable then -- and now. Nonsense. The nuclear airplane project was abandoned because the reactor and the required shielding made the airplane too heavy to be practical. The worst that would happen in a nuclear plane crash would be a very expensive toxic materials clean-up. |
![]() CVBreard wrote: In the 1950s (1960s?), there was a serious USAF project/study to use a nuclear reactor to power a B-36.. No, they used a B-36 to carry a reactor up to run some tests to see how the reactor behaved in flight. There was no proposal to power the B-36 with one. They *did* get far enough along on a design for an atomic aircraft for one of the model companies (Aurora, IIRC) to market a plastic kit of the plane during the early and mid 60s. As part of the research, they also built two huge towers west of Oak Ridge, TN shaped like goal posts. There was a containment building for a reactor core located between the towers. The towers served as cranes to lift the reactor out of it's shell and into the air for studies. Last time I looked, the towers were still visible from the eastbound lanes of I-40 west of Knoxville. George Patterson I childproofed my house, but they *still* get in. |
On Tue, 18 May 2004 15:09:12 GMT, "G.R. Patterson III"
wrote: There was no proposal to power the B-36 with one. Well, of course it wasn't a B-36, but Convair did indeed have a knockoff of the 36 on the drawing board with the reactor behind the crew compartment. Convair was desperate for any engine that would enable it to keep building the 36. The Boeing B-52 was coming along fast. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
"Todd Pattist" wrote in message
... [...] Come to my field any Saturday - there are lots of us flying nuclear powered aircraft. Yeah, but your reactor is 93 million miles away, and unavailable at night. But hey, on the plus side, it's the only practical fusion reactor I know of. ![]() Pete |
CVBreard ) wrote:
: I want a nuclear powered F33A Bonanza. : : In the 1950s (1960s?), there was a serious USAF project/study to use : a nuclear reactor to power a B-36.. : : Talk about long range / flight endurance records! : : It was serious stuff, folks. : http://www.wpafb.af.mil/museum/resea...bers/b3-84.htm Convair NB-36H - US Air Force Museum Bomber Virtual Aircraft Gallery --Jerry Leslie Note: is invalid for email |
On 18 May 2004 13:44:45 GMT, (CVBreard) wrote in
Message-Id: : I want a nuclear powered F33A Bonanza. In the 1950s (1960s?), there was a serious USAF project/study to use a nuclear reactor to power a B-36.. Talk about long range / flight endurance records! It was serious stuff, folks. Hasn't NASA built nuclear fueled Stirling engines? Here's a clue: http://www.grc.nasa.gov/WWW/tmsb/sti...ng_bckgrd.html However, about this time NASA became interested in development of free-piston Stirling engines for space power applications. These engines use helium as the working fluid, drive linear alternators to produce electricity and are hermetically sealed. These 12.5 kWe per cylinder engines were intended for use with a nuclear reactor power system; the Space Demonstrator Engine (or SPDE) was the earliest 12.5 kWe per cylinder engine that was designed, built and tested by MTI. A later engine of this size, the Component Test Power Convertor (or CTPC), used a "Starfish" heat-pipe heater head, instead of the pumped-loop used by the SPDE. Recently, in the 1992-93 time period, this work was terminated due to the termination of the related SP-100 nuclear power system work and NASA's new emphasis on "better, faster, cheaper" systems and missions. http://www.spacedaily.com/news/outerplanets-00a2.html Europa Orbiter was replanned to use a new "Sterling" nuclear generator design which would use less plutonium http://www.cndyorks.gn.apc.org/yspac...heed_offer.htm -- Irrational beliefs ultimately lead to irrational acts. -- Larry Dighera, |
Floridians Are Hit With Price Gouging | X98 | Military Aviation | 0 | August 18th 04 04:07 PM |
Garmin Price Fixing Post from other newsgroup | TripodBill | Home Built | 17 | August 4th 04 10:42 AM |
Garmin Price Fixing Post from other newsgroup | TripodBill | Instrument Flight Rules | 8 | July 16th 04 04:50 PM |
Headsets: "Minimum Advertised Price" | Will Thompson | Piloting | 21 | April 10th 04 11:22 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
