Yesterday the weather was miserable. There were low ceilings and a line of
strong thunderstorms that ran diagonally across the state. The preflight briefing and a look at the radar indicated that an early departure would get me to the destination ahead of the storms. I took my Baron (radar and stormscope equipped) to a nearby airport for some maintenance, and needed to get a clearance enroute due to low ceilings. There was lightning to the west and both the radar and stormscope showed a lot of activity. I landed just as the rain started. As we worked on the plane the rain became a downpour, and the sky was very dark with low clouds and ceilings. The wind was howling, and there was a lof of thunder and lightning. The hangar was shaking from the winds, and the lights went out for a few minutes from a lightning strike. After about fifteen minutes of this, we all heard a plane do a low approach over the airport, and we ran to the window to take a look. At this point it was clearly lower than the published minimums for the lowest approach, and we were all concerned about a pilot flying around in such terrible weather. We got a glimpse of a Bonanza, which then disappeared. I tuned 121.5 on my radios as well as the CTAF, and heard the FBO call the pilot and ask if they needed assistance. There were no calls or answers from the Bonanza, and we feared the worst, waiting for an ELT signal. However, after a few minutes the plane noises returned and the Bonanza landed and taxied to the FBO. We later met the pilot during a coffee break, who said she was going from a nearby metropolitan area to some property diagonally across the state (a route that clearly put her in the path of the long line of thunderstorms.) She said the weather was so bad that she couldn't even dial the GPS map to find the nearest airport, and her plan was to put the plane down in a field when she came across the airport! I asked myself why anyone would want to scud run ( it was lower than localizer approach minimums) across an entire state and try to fly through a line of thunderstorms enroute. Why not turn around and head east away from the storms when the weather went bad (she said she had hours worth of gas)? If this had happened to most people they would likely have been pretty scared and humbled by the experience, but she was very happy and chatty with the folks at the FBO, as if flying through thunderstorms, scud running, flying in IMC without a clearance, and contemplating a precautionary landing in a field were routine events. She did not seem at all concerned with how close she had come to a serious event, and in fact was very upbeat and carried on a number of light conversations. I departed IFR back to my local airport, and had to shoot an approach to ILS minimums due to some residual low clouds, and I later learned that as she prepared to depart she noticed that a wingtip and leading edge were damaged. Apparently she had struck a tree during her scud running, but had not noticed! Obviously, this episode showed a lot of poor judgment, like lack of preflight planning, as well as poor decision making in continuing on in IMC conditions through thunderstorms rather than turning around. (she was VFR). Amway, she clearly understood the possible implications of her actions, but was either obvlious or did not care how close she came to getting killed yesterday. As a fellow pilot, I was struck by how cavalier an attitude she had toward flying, and how close she had come to crashing. Would anyone have said anything further to her? She already had stated she knew about the weather but had decided to continue VFR, so what else could we do to help her without sounding critical? She clearly wasn't shaken or asking for any help or advice, so what more could be done? It was a very frustrating situation- she had nearly killed herself, apparently knew why it had happened, and seemed to think this was a normal activity of flying (let alone damaging her 1997 Bonanza A-36) I'd be interested in hearing how the group would have reacted to this situation. |
It may seem odd, but this is how people often react when they have been
badly frightened. You would be amazed at how chatty and oblivious soldiers can seem to be immediately after a fight, for example. It sounds to me like she was still on an adrenalin high when you talked to her. |
On Sat, 22 May 2004 12:49:50 GMT, "Viperdoc"
wrote: Yesterday the weather was miserable. There were low ceilings and a line of strong thunderstorms that ran diagonally across the state. The preflight briefing and a look at the radar indicated that an early departure would get me to the destination ahead of the storms. I took my Baron (radar and stormscope equipped) to a nearby airport for some maintenance, and needed to get a clearance enroute due to low ceilings. There was lightning to the west and both the radar and stormscope showed a lot of activity. I landed just as the rain started. As we worked on the plane the rain became a downpour, and the sky was very dark with low clouds and ceilings. The wind was howling, and there was a lof of thunder and lightning. The hangar was shaking from the winds, and the lights went out for a few minutes from a lightning strike. After about fifteen minutes of this, we all heard a plane do a low approach over the airport, and we ran to the window to take a look. At this point it was clearly lower than the published minimums for the lowest approach, and we were all concerned about a pilot flying around in such terrible weather. We got a glimpse of a Bonanza, which then disappeared. I tuned 121.5 on my radios as well as the CTAF, and heard the FBO call the pilot and ask if they needed assistance. There were no calls or answers from the Bonanza, and we feared the worst, waiting for an ELT signal. However, after a few minutes the plane noises returned and the Bonanza landed and taxied to the FBO. We later met the pilot during a coffee break, who said she was going from a nearby metropolitan area to some property diagonally across the state (a route that clearly put her in the path of the long line of thunderstorms.) She said the weather was so bad that she couldn't even dial the GPS map to find the nearest airport, and her plan was to put the plane down in a field when she came across the airport! I asked myself why anyone would want to scud run ( it was lower than localizer approach minimums) across an entire state and try to fly through a line of thunderstorms enroute. Why not turn around and head east away from the storms when the weather went bad (she said she had hours worth of gas)? If this had happened to most people they would likely have been pretty scared and humbled by the experience, but she was very happy and chatty with the folks at the FBO, as if flying through thunderstorms, scud running, flying in IMC without a clearance, and contemplating a precautionary landing in a field were routine events. She did not seem at all concerned with how close she had come to a serious event, and in fact was very upbeat and carried on a number of light conversations. I departed IFR back to my local airport, and had to shoot an approach to ILS minimums due to some residual low clouds, and I later learned that as she prepared to depart she noticed that a wingtip and leading edge were damaged. Apparently she had struck a tree during her scud running, but had not noticed! Obviously, this episode showed a lot of poor judgment, like lack of preflight planning, as well as poor decision making in continuing on in IMC conditions through thunderstorms rather than turning around. (she was VFR). Amway, she clearly understood the possible implications of her actions, but was either obvlious or did not care how close she came to getting killed yesterday. As a fellow pilot, I was struck by how cavalier an attitude she had toward flying, and how close she had come to crashing. Would anyone have said anything further to her? She already had stated she knew about the weather but had decided to continue VFR, so what else could we do to help her without sounding critical? She clearly wasn't shaken or asking for any help or advice, so what more could be done? It was a very frustrating situation- she had nearly killed herself, apparently knew why it had happened, and seemed to think this was a normal activity of flying (let alone damaging her 1997 Bonanza A-36) I'd be interested in hearing how the group would have reacted to this situation. Well, if she wasn't rattled, she's probably been doing this for a while and built confidence to the point where she does not see anything wrong with it. I doubt anything an unknown bystander would say would influence her. Not good flying weather in N. Illinois / S. Wisconsin lately. Looks like it will continue through the weekend ![]() -Nathan |
![]() "C J Campbell" wrote in message ... It may seem odd, but this is how people often react when they have been badly frightened. I bet she wasn't frightened. I know two people on my field who are exactly the same way, always have been. |
apparently knew why it had happened, and seemed to think this was a normal activity of flying (let alone damaging her 1997 Bonanza A-36) Last week, on another aviation forum, a new pilot was happily relating his first successful cross country flight with his family -- a 500 mile trip that took him into some complex airspace on the East coast of the U.S. As I was reading along, filled with the glow of remembering *my* first long trip, I was astounded to read that he had run a fuel tank dry on final approach! Almost in passing he casually mentioned that he was forced to quickly switch to the fullest tank, and the engine re-started. He landed normally. I couldn't believe that anyone could treat a complete engine failure on final with such utter disdain, but this very low-time pilot spoke of it as if this sort of thing were normal and an expected part of flying. It was no greater part of his story than his description of the FBO's on-field restaurant. I guess some people are just less risk averse than others? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
apparently knew why it had happened, and seemed to think this was a normal activity of flying (let alone damaging her 1997 Bonanza A-36) This sounds like the type of person who ends up killing her passengers or people on the ground, walks away unscathed, and then gets rich by sueing the aircraft manufacturer. Larry aka: "Mr Optimism" "Get off a fast first shot...Make the second one count!" TIGER |
In a previous article, (LF TIGER) said:
It was a very frustrating situation- she had nearly killed herself, apparently knew why it had happened, and seemed to think this was a normal activity of flying (let alone damaging her 1997 Bonanza A-36) This sounds like the type of person who ends up killing her passengers or people on the ground, walks away unscathed, and then gets rich by sueing the aircraft manufacturer. Oh, you mean Steve Wozniak? -- Paul Tomblin http://xcski.com/blogs/pt/ Better to teach a man to fish than to give him a fish. And if he can't be bothered to learn to fish and starves to death, that's a good enough outcome for me. -- Steve VanDevender |
![]() "Viperdoc" wrote in message ... I'd be interested in hearing how the group would have reacted to this situation. Incidents and pilots like this are unfortunately not uncommon at all in aviation. I've seen this from the lowest levels of aviation to the highest levels. You learn after a while in this business that all you can do is make an attempt to keep someone like this from killing themselves...and that's all you can do. In the end, flying is a lot like being alone with yourself on the golf course. If you cheat, you're only cheating yourself. The only difference is that if you cheat at flying you can kill other people as well as yourself. Flying, and the responsibility that goes with it is one of the most intensive self motivating endeavors I can imagine. The laws are the established laws of physics and aerodynamics that govern the environment we have chosen to live in up there. The rules have been placed there by us, for us to follow so that we have a fair chance to survive our use of the laws. The problem is that unfortunately there are those among us, and always will be those among us, who not only bend the rules, but bend the laws as well. You generally don't make it through the entire way to a natural death by doing this. So where does this leave us as pilots when we are witness to some idiot hell bent on bending the rules and defying the laws? If we're decent people, and most of us are, we make an attempt, directly or indirectly, to help straighten someone out; but basic intelligence should tell us that this is the extent of what we can do. If the idiot can't see the problem as self correct, it's a fool's burden to carry the weight of their failure on our shoulders. You do what you can to make people safer as you pass through, but you can't pick up their failure to comply as a failure by you to change them if this isn't possible. Trust me on this one. I have first hand experience! Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
![]() "Paul Tomblin" wrote in message ... Oh, you mean Steve Wozniak? How many times did Wozniak crash? |
Woz managed to make a little money from Apple as well.
Michael "Paul Tomblin" wrote in message ... This sounds like the type of person who ends up killing her passengers or people on the ground, walks away unscathed, and then gets rich by sueing the aircraft manufacturer. Oh, you mean Steve Wozniak? |
Homebuilt Airplane Crash | Harry O | Home Built | 1 | November 15th 04 03:40 AM |
Bizzare findings of Flight 93 crash in PA on 9-11 | Laura Bush murdered her boy friend | Military Aviation | 38 | April 12th 04 08:10 PM |
AF investigators cite pilot error in fighter crash | Otis Willie | Military Aviation | 0 | January 9th 04 09:55 PM |
Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 04:34 PM |
Homemade plane crash | Big John | Home Built | 9 | October 17th 03 06:45 PM |
