![]() Peter Duniho wrote: "G.R. Patterson III" wrote in message ... If the engine won't stop with the mixture cut off, it won't stop with the mags grounded. Not necessarily true. What makes you say that? What motivating force are the magnetos providing that keep the engine windmilling with just the mixture cut off, and which is absent when you ground the mags? No motivating force, however the mag switch in most planes works by grounding (short circuiting) the magnetos, not opening a circuit. A grounded magneto has a much greater load than a magneto happily humming around producing a spark. |
"Jack" wrote in message
... No motivating force, however the mag switch in most planes works by grounding (short circuiting) the magnetos, not opening a circuit. A grounded magneto has a much greater load than a magneto happily humming around producing a spark. Are you seriously trying to claim that the additional load will make the difference between the windmilling engine stopping or not? (Even assuming your claim of increased load due to grounding is valid...seems to me, the load is caused by the generation of electricity, which happens either way, to the same degree). Pete |
On Wed, 02 Jun 2004 00:17:09 -0400, Jack wrote:
Andrew Sarangan wrote: Dan Truesdell wrote in news:40BCCA76.8090409 @ceaPLsofAtwNarEe.cSom: All correct. One thing you could have done was just switch off the magnetos rather than the mixture control. This will shut down the engine faster, and Depending on the engine that can still leave fuel going to the cylinders. might cause the prop to stop too when the mags are grounded. Since you won't be restarting the engine anytime soon, there is no reason to not stop the engine with the magnetos. When I pull the mixture, it's like a switch. No slowing, it just quits. Actually that is a good time to reach down and turn off the gas. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() Roger Halstead wrote: On Wed, 02 Jun 2004 00:17:09 -0400, Jack wrote: Andrew Sarangan wrote: Dan Truesdell wrote in news:40BCCA76.8090409 @ceaPLsofAtwNarEe.cSom: All correct. One thing you could have done was just switch off the magnetos rather than the mixture control. This will shut down the engine faster, and Depending on the engine that can still leave fuel going to the cylinders. Right. That's why the normal shutdown procedure is to use the mixture. An airplane engine continues to move fuel into the cylinders after it is shutdown without starving it of gas, in no small part due to the big prop helping to spin it around for a bit. might cause the prop to stop too when the mags are grounded. Since you won't be restarting the engine anytime soon, there is no reason to not stop the engine with the magnetos. When I pull the mixture, it's like a switch. No slowing, it just quits. Actually that is a good time to reach down and turn off the gas. Agreed. |
Mooney Engine Problem in Flight - Advise | Paul Smedshammer | Owning | 17 | December 21st 04 06:39 AM |
Landing a Mooney | Jon Kraus | Owning | 42 | November 16th 04 07:00 PM |
F/A-22 Drops JDAM Successfully | Otis Willie | Military Aviation | 1 | September 15th 04 06:49 AM |
Mooney M20 K on Grass ? | Andrew Boyd | Owning | 0 | August 13th 04 03:00 PM |
Cirrus vs Mooney | Charles Talleyrand | Owning | 6 | July 8th 03 11:35 PM |
