Andrew Gideon wrote in
online.com: What type of flight plan is required? Composite (IFR through class A, VFR above)? Does Center provide services at these altitudes, or does one fall back on reporting points? - Andrew Was a TFR established around the launch site? |
"Andrew Sarangan" wrote in message
. 158... Andrew Gideon wrote in online.com: What type of flight plan is required? Composite (IFR through class A, VFR above)? Does Center provide services at these altitudes, or does one fall back on reporting points? - Andrew Was a TFR established around the launch site? Yup |
. 158... Andrew Gideon wrote in online.com: What type of flight plan is required? Composite (IFR through class A, VFR above)? Does Center provide services at these altitudes, or does one fall back on reporting points? - Andrew Was a TFR established around the launch site? If I remember correctly, it was 7mi radius centered on KMHV up to FL200. And isn't airspace above FL600 in the US class E? Why the need for a change at that altitude? |
![]() "Tony Cox" wrote in message link.net... And isn't airspace above FL600 in the US class E? Yes. Why the need for a change at that altitude? Well, above some level there's just no need for it to be Class A anymore. The level decided upon was FL 600. |
"Steven P. McNicoll" wrote in message
ink.net... "Tony Cox" wrote in message link.net... And isn't airspace above FL600 in the US class E? Yes. Why the need for a change at that altitude? Well, above some level there's just no need for it to be Class A anymore. The level decided upon was FL 600. Yes, but surely an IFR flight plan would be just as valid when ascending through FL600 as when descending below FL180. Assuming the mode C is properly calibrated, that is. |
Is Space Ship One the first high-wing in space?
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Hubble plug to be pulled | John Carrier | Military Aviation | 33 | March 19th 04 04:19 AM |
Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 05:35 PM |
OT (sorta): Bush Will Announce New Space Missions | Dav1936531 | Military Aviation | 0 | January 9th 04 10:34 AM |
Strategic Command Missions Rely on Space | Otis Willie | Military Aviation | 0 | September 30th 03 09:59 PM |
