Dudley Henriques wrote:
I caught that right after I posted it :-) I had cleaned out OE last night back to four days old and missed the pickup. Thought I had deleted this but obviously it didn't work! Anyway.....it looks to me like the IP needs a complete checkout in this airplane before flying it. His questions just seem way out of line for someone taking delivery of an airplane they are rated and competent to fly! Sorry about the mispost :-) FWIW, I just (today!) completed complex and high performance checkouts. Before I started the actual work, though, I read a fair bit on both the specific aircraft and constant-speed prop use in general. [I even posted some questions here, I believe.] Reading ahead is never a bad idea, in my experience (granted: I don't read many mysteries {8^). - Andrew |
![]() "Andrew Gideon" wrote in message online.com... Dudley Henriques wrote: I caught that right after I posted it :-) I had cleaned out OE last night back to four days old and missed the pickup. Thought I had deleted this but obviously it didn't work! Anyway.....it looks to me like the IP needs a complete checkout in this airplane before flying it. His questions just seem way out of line for someone taking delivery of an airplane they are rated and competent to fly! Sorry about the mispost :-) FWIW, I just (today!) completed complex and high performance checkouts. Before I started the actual work, though, I read a fair bit on both the specific aircraft and constant-speed prop use in general. [I even posted some questions here, I believe.] Reading ahead is never a bad idea, in my experience (granted: I don't read many mysteries {8^). - Andrew Nobody doubts that reading and studying ahead is the right way to go, and I for one would of course encourage that. I also would encourage pilots answering requests for this type of information to include as an integral part of their answering post, the importance of getting this checkout. I assume that since the poster specified he was preparing for a proper checkout, this was why pilots answering didn't elaborate on it. Dealing in flight safety and instruction all my life points any answer I might give to this type of post toward reminding someone that the REAL answers being sought will be found there, and not necessarily in the prep work, which as we both agree, is fine and to be encouraged. It's a matter of personal emphasis. Mine is ALWAYS on the proper checkout as supplying the answers needed and NOT the prep work! Just my style I guess :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
Thanks for your reply, as well as the debate on my actual intentions. "Get
with my instructor" was implying that I will be getting the proper training in this aircraft from a qualified CFI. I simply wanted to increase my knowledge prior to that instruction. "Dudley Henriques" wrote in message ink.net... I don't wish to sound like a smartass here, but what's your problem with getting a full checkout in this airplane from a competent pilot current in the aircraft? It sounds like you might benefit from a bit of complex training here!!! Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt "Greg Copeland" wrote in message news ![]() On Thu, 24 Jun 2004 12:30:03 +0000, EDR wrote: In article , GE wrote: I'm taking delivery today of my first aircraft and it had a constant speed prop. I have only flown fixed props thus far. I want to have as much understanding of the c-s prop as possible before I get with my instructor. I understand the basic difference in what the controls do, but I don't really have a good understanding of the hows and whys of flying with them. Any general information, explanations, and tips would be greatly appreciated. Go to www.avweb.com on the left side of the screen, select COLUMNS scroll down to find THE PELICAN"S PERCH there are articles on fuel injection, manifold pressure, constant speed props, leaning, etc Everything you ever want to know about operating a high performance aircraft engine is in those articles. Great link! I started reading this article, http://www.avweb.com/news/columns/186619-1.html, and have a question. In the Runup section, when he starts to test for proper mag operation, somethings seems odd there. Can someone help explain that? He says, "Are the mags working? The leaner the mixture, the more mag drop you'll see on one mag, and that's normal." He then goes on to say, "The EGTs should rise on the first single-mag operation, stay there for the second, then drop again on the return to BOTH. That rise is proof-positive the entire ignition system is working, and working well, and the leaner the mixture, the more diagnostic it is." Can someone help explain the supporting logic there? If both mags are working properly and you switch to a single mag, why would the EGT go up? After all, in theory, you're producing less spark and thusly, a slightly less effecient ignition of the fuel/air. I would of thought that EGT would stay the same or go down *just slightly* when running off of one mag. Likewise, if one mag is not working, I would fully expect to see a big EGT drop for the given problematic mag, which he does agree with. But, he further asserts that, "If any of them fail to rise or even drop during single-mag operation, there is a problem with that plug, the wire, or the mag." So, why would running on one mag, versus two, always cause higher EGTs? And why would no rise in EGT indicate a bad mag, wire or plug? Anyone? P.S. I cross posted because this seems like good student pilot material too. |
![]() "GE" wrote in message ... Thanks for your reply, as well as the debate on my actual intentions. "Get with my instructor" was implying that I will be getting the proper training in this aircraft from a qualified CFI. I simply wanted to increase my knowledge prior to that instruction. No problem, and I assumed you would be doing that. The reason I didn't handle your post with the information you asked for is because there is a difference between generics and specifics; and for what you will be doing, specifics are called for. The checkout in a new complex is aircraft specific and should be treated as such. Since you didn't state what specific aircraft you were dealing with, I would refrain from offering advice other than pointing you to the checkout procedure. It's my practice that whenever a question like yours comes up without stating what airplane the question is dealing with, I opt to steer the poster to the checkout procedure rather than get into the specifics requested. It's a safety issue with me......a personal preference so to speak. Best of luck with your checkout. I'm sure you'll do fine. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
The initial poster asking these questions sounds like he might benefit
from a complex checkout, or at least a thorough checkout in this airplane given by a competent pilot current in the aircraft! :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt "Greg Copeland" wrote in message news ![]() On Thu, 24 Jun 2004 12:30:03 +0000, EDR wrote: In article , GE wrote: I'm taking delivery today of my first aircraft and it had a constant speed prop. I have only flown fixed props thus far. I want to have as much understanding of the c-s prop as possible before I get with my instructor. I understand the basic difference in what the controls do, but I don't really have a good understanding of the hows and whys of flying with them. Any general information, explanations, and tips would be greatly appreciated. Go to www.avweb.com on the left side of the screen, select COLUMNS scroll down to find THE PELICAN"S PERCH there are articles on fuel injection, manifold pressure, constant speed props, leaning, etc Everything you ever want to know about operating a high performance aircraft engine is in those articles. Great link! I started reading this article, http://www.avweb.com/news/columns/186619-1.html, and have a question. In the Runup section, when he starts to test for proper mag operation, somethings seems odd there. Can someone help explain that? He says, "Are the mags working? The leaner the mixture, the more mag drop you'll see on one mag, and that's normal." He then goes on to say, "The EGTs should rise on the first single-mag operation, stay there for the second, then drop again on the return to BOTH. That rise is proof-positive the entire ignition system is working, and working well, and the leaner the mixture, the more diagnostic it is." Can someone help explain the supporting logic there? If both mags are working properly and you switch to a single mag, why would the EGT go up? After all, in theory, you're producing less spark and thusly, a slightly less effecient ignition of the fuel/air. I would of thought that EGT would stay the same or go down *just slightly* when running off of one mag. Likewise, if one mag is not working, I would fully expect to see a big EGT drop for the given problematic mag, which he does agree with. But, he further asserts that, "If any of them fail to rise or even drop during single-mag operation, there is a problem with that plug, the wire, or the mag." So, why would running on one mag, versus two, always cause higher EGTs? And why would no rise in EGT indicate a bad mag, wire or plug? Anyone? P.S. I cross posted because this seems like good student pilot material too. |
![]() Greg Copeland wrote: On Thu, 24 Jun 2004 12:30:03 +0000, EDR wrote: In article , GE wrote: I'm taking delivery today of my first aircraft and it had a constant speed prop. I have only flown fixed props thus far. I want to have as much understanding of the c-s prop as possible before I get with my instructor. I understand the basic difference in what the controls do, but I don't really have a good understanding of the hows and whys of flying with them. Any general information, explanations, and tips would be greatly appreciated. Go to www.avweb.com on the left side of the screen, select COLUMNS scroll down to find THE PELICAN"S PERCH there are articles on fuel injection, manifold pressure, constant speed props, leaning, etc Everything you ever want to know about operating a high performance aircraft engine is in those articles. Great link! I started reading this article, http://www.avweb.com/news/columns/186619-1.html, and have a question. In the Runup section, when he starts to test for proper mag operation, somethings seems odd there. Can someone help explain that? He says, "Are the mags working? The leaner the mixture, the more mag drop you'll see on one mag, and that's normal." He then goes on to say, "The EGTs should rise on the first single-mag operation, stay there for the second, then drop again on the return to BOTH. That rise is proof-positive the entire ignition system is working, and working well, and the leaner the mixture, the more diagnostic it is." Can someone help explain the supporting logic there? If both mags are working properly and you switch to a single mag, why would the EGT go up? After all, in theory, you're producing less spark and thusly, a slightly less effecient ignition of the fuel/air. I would of thought that EGT would stay the same or go down *just slightly* when running off of one mag. Likewise, if one mag is not working, I would fully expect to see a big EGT drop for the given problematic mag, which he does agree with. But, he further asserts that, "If any of them fail to rise or even drop during single-mag operation, there is a problem with that plug, the wire, or the mag." So, why would running on one mag, versus two, always cause higher EGTs? And why would no rise in EGT indicate a bad mag, wire or plug? Running on one mag means the fuel air mixture burns slower... so when the exhaust valve opens, its still burning and the flame front travels out the valve (or so ive been told). If you get NO change with a mag check, then the burning characteristics arent changing, that means the mag is not dropping offline.. which means its not groundiing out. I seem to remember this being explained in Deakin's articles but its been a while since I've read them. Dave |
Greg,
All the explanations you got are good. Now for the carb heat check. What happens to the EGTs? FWIW, a while ago I had a too high RPM drop on the mag check with our Lyc O-360. A look at the engine monitor showed one cylinder's EGT going very high. This points strongly to one plug being fouled. A little time of running the engine at high rpm and very lean on the ground cleared the problem, which could also clearly be seen on the engine monitor. These things are worth their weight in gold, even on the simpler engines. -- Thomas Borchert (EDDH) |
PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 04:41 AM |
Constant speed prop oil leak | DP | Piloting | 23 | April 21st 04 10:15 PM |
Why do constant speed power setting charts limit RPM? | Ben Jackson | Piloting | 6 | April 16th 04 03:41 AM |
Practicing SFLs with a constant speed prop - how? | Ed | Piloting | 22 | April 16th 04 02:42 AM |
Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 10:08 PM |
