"Andrew Gideon" wrote in message
online.com... Is that likely to work? ATC may, after all, deny the "on top" clearance. As Ditch says, ATC has the authority to deny the clearance, of course. But since it makes their life easier, I don't know why they would. I have never been denied a request for a "VFR on top" clearance. Granted, I fly VFR much more often than IFR, but I just can't see why ATC would ever deny a "VFR on top" clearance. Pete |
![]() "Andrew Gideon" wrote in message online.com... Peter Duniho wrote: the "VFR on top" clearance to resolve whatever issue ATC had, and allow yourself to proceed directly to whereever you were headed. Is that likely to work? ATC may, after all, deny the "on top" clearance. They might in very busy terminal airspace that you are inbound to. They will be gleeful that you want to remove yourself from the separation pool otherwise. |
"Peter Bauer" wrote in message
om... .. when flying under a flight plan (IFR) can i fly routes at my choice ? e.g. take-off under IMC, enroute 10 min under IFR (clouds), 30 min VFR on top, descending to my destination under IMC (through cloúds), landing at destination under VMC (below the lower layer of clouds) .. when reaching IMC after 30 min. VMC ("round trip under VFR") do i have to file a flight plan (IFR) or am i able to fly only by reference to the instruments through an e.g. 300 ft Layer of clouds and after that, when reaching "On Top" fly again under VFR ? You do not say where you are flying, Peter. Others have answered on the assumption that you are flying in the US, I'll give you an answer for Germany. The airspace system in Germany is not very different to that in the US, but there are a couple of differences. Controlled airspace generally starts at 2500 ft agl rather than 1200 ft agl. Flying under IFR in class G is forbidden in Germany. Thus for an IFR flight, if your destination is not an IFR airport surrounded by controlled (or class F) airspace, you usually need to be able to cancel IFR by the minimum instrument altitude which is not below 2500 ft. This makes IFR flights to VFR airports fairly painful. To fly under IFR you need a clearance. Pop-up IFR clearances (if you find IMC on a VFR flight like your second scenario) are troublesome. I've had to dictate an entire flight plan (including the colour of the dinghy cover) to a FIS controller to get an IFR pop-up, despite having filed a VFR plan with almost exactly the same info. "VFR on top" clearances, as Pete described are not used in Germany (in fact they're not used outside the US). But you will find that practical IFR clearances tend to include long direct legs, so it's unusual to be in a situation where a VFR routing will save you a lot over an IFR one. So where are you based? Hope that helps Julian Scarfe |
Hi,
i'm based in Germany with a FAA-PPL ASEL. It's very interesting to read the differences in IFR-Flying in the States and in Germany. Although the two countries are "ICAO-countries" they are not participating in same air work to each other. Well, i think ...when learning for an IFR-Rating you should know before what you are allowed to do with it or not after passing it. I think most "VFR"-Pilots only know about the new ability to fly in clouds without reference of the ground surface. It's very interesting for me to know how the real IFR-flight is working, what problems with ATC you have when flying under IFR, the change IFR-VFR, and a lot of other things....and that....before "doing" the Rating. Thank you all for asking my questions.... Peter |
om... i'm based in Germany with a FAA-PPL ASEL. It's very interesting to read the differences in IFR-Flying in the States and in Germany. Although the two countries are "ICAO-countries" they are not participating in same air work to each other. If you think Germany and the US are different, try crossing the border into other European countries. Of all of them the airspace system in Germany is most like the US, and the UK is probably at the opposite extreme. Here we have mostly class A and class G, with little between. IFR flight in class G is something we do every day -- there's not a lot of choice. Good luck if you choose to do the IR. Julian |
Julian,
most like the US, and the UK is probably at the opposite extreme. Here we have mostly class A and class G, with little between. IFR flight in class G is something we do every day -- there's not a lot of choice. IIRC in the UK you have some sort of "poor-mans-IFR" (no pun intended ;-) called the "IMC" rating, giving you the right to fly under IMC without being "in-the-system". Does that thing make it to JAR-FCL? Best Regards Kai Glaesner |
"Kai Glaesner" wrote in message
... IIRC in the UK you have some sort of "poor-mans-IFR" (no pun intended ;-) called the "IMC" rating, giving you the right to fly under IMC without being "in-the-system". Does that thing make it to JAR-FCL? Still available as a national rating valid for IFR only in the UK. The only difference from the way it used to be is that it no longer gives credit towards an IR. However, an FAA IR gives credit towards a JAA IR, and the instrument time for an IMC rating counts for the time required for an FAA IR. So we have the screwy situation that the usual "upgrade" path is IMC rating - FAA IR - JAA IR. Julian Scarfe |
Routine Aviation Career | Guy Alcala | Military Aviation | 0 | September 26th 04 12:33 AM |
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore | Otis Willie | Military Aviation | 2 | February 22nd 04 03:33 AM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
Wm Buckley on John Kerry | Big John | Piloting | 22 | February 7th 04 02:19 AM |
Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 07:33 PM |
