Transient alternator problem
Old July 8th 04, 01:46 AM
Martin Kosina
Was flying IFR in the clear on top of an overcast layer today. I noticed at
some point that the ammeter was indicating zero, and not moving. The Alt
warning light was not illuminated, except when I pressed the test button. I
started to shut down non-essential electriconics in case this was for real.
After a minute or two, the ammeter needle resumed normal indications, and
stayed that way for the rest of the flight.
Hmmm - I thought the ammeter *should* indicate zero when the battery
is fully charged and the electrical load is not changing ? What is the
"normal" indication you are refering to ?
Old July 8th 04, 02:34 AM
Jeremy Lew
I've never seen our ammeter reading zero before. Doesn't any load on the
battery mean constant discharge and therefore constant charge for the
alternator? Normally, the needle is so sensitive that you can see it
jumping in sync with the anti-collision strobe.
"Martin Kosina" wrote in message
om...
noticed at
Alt
button. I
real.
and
Old July 8th 04, 01:45 PM
Hankal
alternator
Another reason to have an EDM. My voltage is always 12.9 or better.
The only time I glance at my ammeter is after start up when I turn on the left
side of the master switch.
Old July 8th 04, 12:57 PM
Nathan Young
On Tue, 6 Jul 2004 19:05:22 -0400, "Jeremy Lew"
stayed that way for the rest of the flight. The Alt warning light was
properly illumated during low-RPM operations on the ground, as well as
during the engine runup split switch check.
The warning light/ammeter needle discrepancy suggests to me that problem was
in the ammeter, and that the alternator was functioning normally the whole
time. Anyone have any theories as to what would cause indications like
this? Is external RF interference possible?
External RF is not the cause.
Does your plane have a voltmeter? If not, you can get a cigarette
lighter VM to monitor the bus voltage. A VM is a helpful tool to
verify whether or not the alternator/charging sytem is operating.
When the charging system is active, the voltage should be around 14V,
when inactive, the bus voltage will quickly (within a few seconds)
taper off to 13V and then slowly decay to 10V (over the course of an
hour or so) as the battery loses charge. The decay time is dependent
on the battery and the electrical load.
Anyways, if you see a zero on the ammeter, and the bus voltage has
dropped below 14V, there is a good chance the charging system has
failed.
Also, don't be surprised that the system came back to life after a few
minutes. Intermittent contacts are very common on the 30 year old
wiring, circuit breakers, and switches in our planes.
-Nathan
Old July 8th 04, 09:24 PM
While in flight, try adding a substantial load to the system (such as
say the pitot heater or a landing lite) and see of the ammeter shows
the additional alternator load. If it discharges, your alternator has
definitely quit on you.
BTW a bad battery can give all sorts of weird electrical charging
system symptoms. Does your battery have a full volume of electrolyte?
It is vitally important to keep the tops of the plates covered with
electrolyte at all times. Maybe your battery has become nearly dry on
one cell?
Transient alternator problem John Clonts Owning 6 July 11th 04 06:01 PM
Transient visit to the Pacific Northwest sprack Piloting 5 May 5th 04 05:57 AM
